jumpstart a dead Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by highmilesgarage, Feb 2, 2025.
  1. highmilesgarage
    highmilesgarage Active Member
    427
    155
    Kansas City
    car wasn't driven for more than 2 weeks, tried starting it and all the dash lights are on like a Christmas tree with the RTOD. Very dim and I said, "crap battery is finally gone".. several attempts and turned the dash into nothing.. no lights are on.. time to jumpstart. If you use another car to jumpstart you don't need to crank/start the car. The 12v will boot up the computer on the Prius and the HV battery will take over..
    https://youtube.com/shorts/xrtWWgxt4q4
  2. Mendel Leisk
    40,472
    I'm guessing this works better than incantations, prayers and burning incense. I'll have to give it a try.
  3. pasadena_commut
    pasadena_commut Senior Member
    2,218
    661
    Southern California
    If you can, read the voltage on the 12V before you jump start it. If it is 10.0 V or something dreadful like that (below 0% charge on the AGM SOC table), it tells you that buying a replacement battery ASAP would be a good idea. They are not hard to install yourself. The only tricky part is the bolt head for the ground lead at the negative terminal, which is awkwardly located (faces the rear of the car) and requires a very small ratchet or similar device.
  4. highmilesgarage
    427
    155
    Kansas City
    Battery is fine after driving for 30 mins, just shows that starting it up for 5 mins doesn't really maintain the charge on the 12v battery especially on cold weather days.
  5. dolj
    dolj Senior Member
    8,186
    4,168
    Wellington, New Zealand
    In reality, just starting it for five minutes probably does more harm than good.
    pasadena_commut likes this.
  6. highmilesgarage
    427
    155
    Kansas City
    took a long vacation and battery is dead again... sign that I need to replace my 12v battery.
  7. Mendel Leisk
    40,472
  8. Brian1954
    Brian1954 Senior Member
    1,705
    665
    South Central PA, USA
    How old is your 12v battery?
    It may be time to replace it.
  9. highmilesgarage
    427
    155
    Kansas City
    almost 2 weeks
  10. highmilesgarage
    427
    155
    Kansas City
    no idea no sticker on when it was bought (I bought the car last year) I will start fine if used within a week.
  11. dolj
    dolj Senior Member
    8,186
    4,168
    2 weeks is not long for down time. Your 12 V battery is toast.
    Brian1954 likes this.
  12. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    Third planet from the Sun
    For a 12V battery, in addition to voltage, I recommend using the concept of "internal resistance of the battery".
    The lower the internal resistance, the better the battery copes with its duties.
    This is due to Ohm's law. U = I * (R + Rin)
    U = I * R + I * Rin
    In this formula, the first product is the useful load, the second product is the parasitic part, which is uselessly spent and only heats the battery from the inside.
    And since the initial voltage of the battery will not change, the second part takes away the battery capacity, preventing the car from starting.
    Internal resistance is the health of the battery.
    The lower its value, the better the battery.
    On the market, testers allow you to show the battery voltage and its internal resistance.
    #12 MAX2, Mar 19, 2025
