What is the Best "Low Cost" scan tool that can bleed brakes?
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by LesPaulTomFL, Mar 5, 2024.
Tags:
  1. LesPaulTomFL
    LesPaulTomFL Junior Member
    I have an awful scan tool - must have cost me all of $30 back in the day. it's time for me to upgrade.
    I just purchased and am waiting for a 2024 White Gen 5 Prius LE - so I need a scan tool should work on both my gen 5 and my Gen 3 - 2013 V model.
    Of course it needs to be able to properly bleed the brakes on the 2013 and hopefully work as well for the needs of the 2024. Not expecting to be working on the 2024 for years to come :)
    Autel Scanner MaxiCOM MK808S keeps coming up and I cannot afford Snap On.
    Question is am i wasting my money on this $500 model? Is this a good scan tool?
    Any other suggestions on the best tool for keeping my 2 Priuses on the road?
    Thanks
  2. Jack90210
    Jack90210 New Member
    Virginia
    2025 Prius
    Autel is responsive to emails, iirc. I'd reach out to them and ask.
    Is this for engaging the ABS circuits during fluid flushes?
  3. ETC(SS)
    7,169
    #3 ETC(SS), Mar 17, 2025
  4. Hammersmith
    Hammersmith Senior Member
    2,315
    2,347
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    You don't need a scan tool to bleed brakes or replace brake fluid. Just follow the sections labeled "When not using Techstream/GTS".
    Mendel Leisk and ETC(SS) like this.
  5. Mendel Leisk
    41,485
    MAX2 likes this.
  6. ChapmanF
    18,236
    This is not the first post on PriusChat to have mixed up brake bleeding and brake fluid replacement, which are different procedures.
    From the first attachment in that exact post:
    That means exactly what it says.
    From the second attachment in that post:
    The brake fluid replacement procedure is the only one that has both a Techstream and a "When not using Techstream" procedure.
    You are doing brake fluid replacement if all the following are true:
    • The system is already full of fluid and completely bled.
    • You are adding new fluid at the reservoir and letting old fluid out at the bleeders.
    • You are absolutely careful to let no air be sucked in anywhere.
    If that is what you're doing, you can use the non-scantool fluid replacement procedure.
    It may still be prudent to have on hand Techstream or another scan tool that can do brake bleeding, just in case any air is allowed in the system during your fluid replacement. Because if that happens, you are not doing fluid replacement anymore, but brake bleeding.
  7. Hammersmith
    2,315
    2,347
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Okay, then let's say that the non-GTS instructions work just fine if you're doing standard brake maintenance(calipers and flex lines) and traditional brake bleeding(the lines, not the ABS actuator). If you're doing big things like replacing major system components like the ABS actuator, you ran the reservoir dry, or you think you had a leak somewhere for a long time, then you need to use a scantool in order to fully bleed the actuator in addition to the lines.
    Does that sound about right?
  8. ChapmanF
    18,236
    Pretty much. If you've only done work out at the ends of the lines and a small amount of air got in only there, you have ok chances of getting away with a non-scantool procedure.
  9. douglasjre
    douglasjre Senior Member
    2,181
    720
    Null, NL
    Don't plug Chinese junk into this car. If you do you'll remember but never admit I told you so. Techstream only. Bootlegs are cheap on fleabay. Install into a burner computer
