Front license plate options?
Discussion in 'Gen 5 Prius Main Forum' started by cool_prius, Mar 22, 2025.
  1. cool_prius
    cool_prius Junior Member
    66
    United States
    2025 Prius
    The front license plate mount appears to be designed for Japanese license plates because it's 13" wide and so are Japanese plates. I'm wondering if anyone knows of a US license plate frame that is 13" wide, or figured out another way to hide the rectangle
  2. hill
    8,619
    Our Chevy Volt head 13-in. Different manufacturers do dorky things with mounting holes
    #2 hill, Mar 22, 2025
  3. cool_prius
    66
    United States
    2025 Prius
    Looking a picture of the Chevy Volt front license plate mount, it's the perfect size for US plates. Also this isn't about mounting holes at all.
  4. cool_prius
    66
    United States
    2025 Prius
    Here's what I'm pointing out. The mount sticks out half an inch on each side upload_2025-3-23_1-45-58.png
    Whereas in Japan, it has a flush look that's way better upload_2025-3-23_1-46-56.png
    Size difference:
    #4 cool_prius, Mar 22, 2025
  5. schja01
    schja01 Senior Member
    1,814
    1,205
    Chicagoland
    2024 Prius
    Limited AWD-e
  6. Tom Zebrasky
    Tom Zebrasky New Member
    youngstown ohio
    2024 Prius
    I couldn't stand the buck tooth front license plate bump. I made a 3 dimensional mold and then thermoformed a polypropylene plate the same thickness as the bumper cover to bond to the bumper cover after I cut off the front license plate buck tooth. Bye bye buck tooth! I also made an aluminum moulding to cover the wide gap in the rear hatch where all the wind noise comes from, it's now as quiet as my Lexus LS 500. I trashed the foam in the trunk and lowered the floor 6 inches. I covered the front end noise speaker with duct tape and muffled the sound. I added 2 horns, hi/low and got rid of the squeaky horn. Then painted the lower sill cover to match the wheel opening black which gives the impression of a narrower car shape.Then added the stainless steel window mouldings and lower chrome trim, tinted the windows and blacked out the rear window since I have the digital rear view window. All this was done when I had 42 miles on the odometer!
    Cheers
  7. GcinFl
    GcinFl Junior Member
    34
    2024 Prius
    That looks really good. Not to be a downer but what happens if you ever need to put a front plate on it. Here in Florida they're trying to pass a law requiring front plate. I can't believe Toyota didn't just make that "tooth" removable.
  8. Mendel Leisk
    40,466
    I wouldn't doubt something will happen at the mid-gen-refresh. If it doesn't that'd be telling too.
  9. Tom Zebrasky
    youngstown ohio
    2024 Prius
    The original black plastic plate holder can be screwed back on in place over the bumper cover as the contours are exact.
