Inside smells really bad
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by cool_prius, Mar 26, 2025.
  1. cool_prius
    cool_prius Junior Member
    66
    United States
    2025 Prius
    I've had my 2025 Prius LE for less than a month and it started developing an odor inside that smells like wet dog. A quick search tells me it's mold from either the doors or AC system, and that checks out because I'm sensitive to mold and have been having unexplained migraines, nausea, and my neck is so stiff I can barely turn my head.
    I'm going to take it in for service and see what Toyota can do, but anyone here have any insight? As far as I remember, I make sure to turn off air re-circulation at least once per drive because I can feel the stale air. Maybe it's because I never turn the fan on past 2 levels?
  2. Mendel Leisk
    40,471
    You’re mostly not using outside air? AC always on? Can you disclose your location more specifically? How’s the weather been?
  3. bisco
    51,028
    If they are able to clean it up, always shut off a/c at least 5 minutes from your destination, but leave the fan on
  4. cool_prius
    66
    United States
    2025 Prius
    I am in the west coast. Weather has been pretty rainy this month.
    Yes correct I am mostly not using outside air because of smells like from dirty lakes. Also on the freeway I tend to turn on recirculation so I don't get exhaust inside that makes my eyes sting.
    I don't use the AC a ton. Just when it's humid or really hot out.
  5. Mendel Leisk
    40,471
    Yeah heed @bisco's advice, about turning AC off before destination. The AC's "radiator" (aka evaporator?) is like a glass of ice water on a hot day, water vapour in the air condenses on it. If you shut down without giving the system time to blow off that moisture, it sits there, and eventually get's colonized by various molds.
    Not sure if it's a factor, but you're not the first to mention running the system in recirc, a lot of the time. I'm the opposite, only hit recirc momentarily, say stuck behind a diesel or similar.
    I mostly use AC in the rain, to avoid fogging up. Not sure if it's still thus, but with our gen 3 if you set vent mode to heat/defog, it surreptitiously uses AC, a modest amount I think. AC light does not go on, but you can see if monitoring with something like ScanGauge II.
    #5 Mendel Leisk, Mar 26, 2025
    FLCL likes this.
  6. rjparker
    9,512
    5,822
    That might be advice for northern climates where ac is optional and not used all year but the solution that works and is recommended by Toyota is to clean the evaporator. After it is sanitized and not just dried waiting for the fungus to get wet again, it can go for several years with ac used long and hard. No ridiculous "drying" necessary.
    You inject the foam into the condensate line from below. It's easier than an oil change. The smaller fragrance spray is optional and routinely disgarded.
    daisy555 likes this.
  7. Mendel Leisk
    40,471
    There you go, ridiculous and pragmatic, take your pic. :)
    PrimeDan likes this.
  8. PriusCamper
    PriusCamper Senior Member
    11,982
    4,872
    Pacific Northwest, USA
    The Toyota Stealership is going to be worthless. Don't even bother. If I were you I'd get your car professionally detailed by someone with experience cleaning an interior for someone with health issues and uses non-toxic products. Also buy a cabin air filter with carbon in the filter, which will work way better than the crappy overpriced paper filters without carbon that the stealership uses.
    As for the source of the wet dog smell, the AC would make sense if your car was many years older than it is. But I disagree with others in this thread that a brand new AC would get smelly that quickly.
  9. Hammersmith
    Hammersmith Senior Member
    1,965
    1,970
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Strongly recommend you watch this entire video: (only 17min long)
    If I were you, I'd get the A/C system cleaned(or do it yourself), switch to a charcoal filter, then try to use outside air all the time instead of recirculate. Hopefully the charcoal filter will take care of the outside smells that have been bothering you and forcing you to use recirculate.
  10. soft_r
    soft_r Active Member
    160
    113
    Beverly Hills
    2024 Prius
    Hit the air recirc button before shutting off the car. I don't know what it sets it by default to or if it does it automatically on shut off but if i park in front of certain fragrant bushes, even if i never had the air on, the car will strongly smell of them when i get back. I noticed that just this month and will be hitting the air recirc button when i park near them again.
    Charcoal cabin filter like some said. It's cheap, do it. Replace often.
    Get some damp rid as well to absorb the moisture in the air. Put it somewhere where it won't slide around or tip. I've kept one in my car during rainy season ever since my previous car had a leak. Now I just do it out of habit. You'd be surprised how much it pulls from the air of your car as it sits for a couple days.
  11. daisy555
    daisy555 Senior Member
    1,644
    691
    CT
    I would be concerned that there is an accumulation of water somewhere. Someone else mentioned an accumulation of water in one of their doors.
    How could the AC be moldy after only one month of use? I’m allergic to mold too. I had no idea it was recommended to turn the AC off before arriving at destination. I’ve owned a 2009 Prius for 10 yrs and have never shut AC off early. I also use a carbon cabin air filter but there isn’t enough carbon in those filters to do much of anything.
    You would need a very thick/dense carbon filter to block environmental odors. For example my portable apartment filter has an 18lb carbon filter.
    #11 daisy555, Mar 29, 2025
  12. fotomoto
    fotomoto Senior Member
    5,628
    3,802
    So. Texas
    Get an ozone generator. I use it a minimum of once a year on each vehicle (a/c on, fan high, recirc on, windows closed) for about 20+ minutes, then allow to air out if possible. Just used it on our Sienna after a 2,700 mile road trip.
  13. PriusCamper
    11,982
    4,872
    Only use them when you are not in the vehicle! The ozone they generate is harmful to humans. But in this case I'm going to continue to insist that OP doesn't have an AC problem after a month, they have a never cleaned their car problem and if they don't know how to clean the inside of their car properly they need to pay someone to do it.
  14. PriusCamper
    11,982
    4,872
    It's a brand new car... This is ridiculous. OP clearly hasn't cleaned their car, or doesn't know how to clean it. Part of cleaning a car regularly is tracking down sources of bad smells, wet spots, etc...
    What's worse a Toyota Stealership couldn't properly clean their way out of a paper bag so they're gonna be worse than worthless at solving this.
  15. Mendel Leisk
    40,471
    Any kids in the equation? Maybe some food slipped down between the seat and back? Try to zero in on the location of smell.
    daisy555 and PriusCamper like this.
  16. daisy555
    1,644
    691
    CT
    I’ve owned my new car for a month and haven’t even thought about cleaning it yet. It looks and smells brand new. I know of someone else who had a brand new Toyota that smelled like a combination of strong chemicals and rotten animal. Dealership wouldn’t do anything about it so the person had to treat the car with natural odor neutralizers and wear a respirator for two months until the smell dissipated. Anything is possible.
    #16 daisy555, Mar 29, 2025
  17. daisy555
    1,644
    691
    CT
    Sorry you are dealing with this. Reactions to mold are can have a detrimental affect on your health. Do you notice the smell increasing when you turn the air on? I would check under the seats and floor mats for dampness. Check the cargo area too especially under the styrofoam below the cargo area. I would be feeling for dampness and smelling each area carefully.
    #17 daisy555, Mar 29, 2025
  18. Hammersmith
    1,965
    1,970
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I don't remember if this tip is in the video I linked or a different video, but it wouldn't hurt to check the passenger floor for dampness forward and near the center console; basically where your left foot would be when sitting in the passenger seat. If the A/C drain was clogged or not fed through the floor properly, that would dump a good bit of water onto and under the carpet. That could lead to a smell developing very quickly.
    Trollbait likes this.
  19. cool_prius
    66
    United States
    2025 Prius
    I drove approximately 1500 miles the past 2 weeks with recirc off the entire time. The first 500 miles I had the fan on full blast as well. I read this would dry up any dampness inside the AC system but it did not help, nothing did.
    Before my trip, the Toyota dealer checked the doors for moisture and the AC system and passed them both. They put in their notes that they noticed no odor. Shortly after driving out of the service center, I started smelling the wet dog smell.
    I also noticed that it's not all the time. It happens randomly and I can't figure out the cause. It happens with any settings, and AC on or off. So I guess Toyota didn't run it long enough or the tech has a poor sense of smell.
    Regarding the comments of cleanliness inside the car, there is no dirt or anything that would cause the smell. I don't have dogs. The car has never had any passengers before the smell started occurring and I am a very clean person. I have also cleaned and vacuumed the inside of the car twice in March, once by a professional detailer.
    Though something that I'm noticing that seems unusual is the amount of dust inside the car. I thought it was from some particularly linty paper towels, but that was one time and the dust reappears everyday after my daily wipedown with a microfiber cloth.
    Could this be mold?
  20. bisco
    51,028
    i don't think so. have you checked the cabin filter?
