My 2023 Prius surprisingly wouldn't start today.
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by WayneZ, Sep 23, 2023.
Tags:
  1. bisco
    51,895
    it seems so obvious, especially after the gen 4 fiasco
  2. Gokhan
    Gokhan Senior Member
    6,187
    2,444
    Paramount CA
    The Gen 4 fiasco that exists only as an imagination in your mind.
  3. bisco
    51,895
    and in priuschat
  4. Gokhan
    6,187
    2,444
    Paramount CA
    My Gen 4 Prius Prime's 12-V battery hasn't had a single issue in three years of my ownership; yet, I left my car undriven for up to over six weeks with a full Toyota Connected Services subscription at times.
  5. Trollbait
    12,519
    You live in a mild climate.
    The issue can easily only affect some cars or batteries. Not every Prius in the inverter recall had it die.
  6. Gokhan
    6,187
    2,444
    Paramount CA
    No, it gets very hot here sometimes. We had several weeks in a row of 100-plus-degree weather in the late summer of 2022, during which I owned my car. Heat is harder on a 12-V battery than cold.
  7. Fenichel
    Fenichel Junior Member
    30
    West Vancouver, BC
    2023 Prius Prime
    XSE Premium
  8. Trollbait
    12,519
    My point is that your experience is anecdotal.
  9. Gokhan
    6,187
    2,444
    Paramount CA
    On the contrary, the battery failures reported on this forum are anecdotal.
    Gen 4 (and Gen 5) Prius Prime has a dedicated battery multisensor to optimize its life. There is nothing in the car that would compromise the life of the battery as long as the owner uses the car properly; however, many owners don't. I posted over and over what I meant by that (not leaving the car plugged in for longer than overnight, having frequent long trips, not sitting in the car unless it is in the READY mode, also not having battery-draining accessory devices connected, etc.) So, yes, in that sense, the Prius Prime 12-V battery is not foolproof, as the car is demanding on the small 12-V battery (the owner's manual warns about the minimum-capacity requirement), and the owner must be aware of the 12-V battery precautions I listed.
    Owning a car is challenging, and owning a BEV (or a PHEV) is even more challenging, as there is an extra level of complexity, which may further bother non-tech-savvy owners.
    #29 Gokhan, Feb 15, 2024
  10. Trollbait
    12,519
    I wasn't commenting on the reported failures, just you using your individual experience as an example.
  11. Gokhan
    6,187
    2,444
    Paramount CA
    And the reported failures here are also individual experiences.
  12. CruisnGrrl
    CruisnGrrl Active Member
    149
    128
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Why would having frequent long trips be using the car improperly?
    Because I will go days with out driving I have since taken to connecting a battery maintainer that I leave plugged in when the vehicle is parked at home. I've also been making the effort to unplug the traction battery after it's charged.
    Still the fact that the car can't be left plugged in until ready to go seems like an oversight on the design. I would have set up everything to use the AC connection when available for all the connected services and other features that drain the battery when it's not running. I would have also built in a battery maintainer that uses the AC power to maintain the 12V battery.
    soft_r and Gokhan like this.
  13. Gokhan
    6,187
    2,444
    Paramount CA
    It is probably a safety thing by Toyota that they don't want to have the systems up and running when the car is off. Moreover, to have the systems up and running at all times could shorten their lifespan, as electrolytic capacitors and such have limited lifespans.
  14. Mr.Vanvandenburg
    1,352
    571
    2020 Prius Prime
    The days before I learned here about the cheap and effective battery monitors. Problem solved. I know where the battery is at, as much as I want to know. No more guessing.
  15. Ngenovesi
    Ngenovesi Member
    51
    27
    Pittsburgh
    2023 Prius Prime
    2023 Prius Prime. My battery died on me this morning. Got it towed to Dealer. I charged it up full on Wednesday . I unplugged the charger right after full. I did not drive it all day Thursday. When I went to go to work this morning Friday the battery was dead. All the lights came on blinking and the wiper blades turned on but ran very slow. The tower had to charge my car up for 5 minutes before I could start it and drive out of the garage to but on the flat bed. Not sure what happened but the dealer said everything is checking out as good. They are keeping it overnight for observation.
    I’m glad I left it overnight. Battery was dead again. They are putting a new battery in. Since closed Sunday I will have to pick up on Monday.
    Approximate Pseudonym likes this.
  16. Diane Stachowski
    Diane Stachowski New Member
    CA
    2023 Prius
  17. Diane Stachowski
    CA
    2023 Prius
  18. Diane Stachowski
    CA
    2023 Prius
    12VOLT REPLACEMENTS
    My 2023 Prius xle has had 3 12volt batteries replaced and the abs component replaced. Been to 2 dealerships. Only 1 error code ever surfaced. Only 11k miles. Nothing but problems.
    Gokhan likes this.
  19. Gokhan
    6,187
    2,444
    Paramount CA
    How often and for how long do you drive your car?
  20. DOHCtor
    DOHCtor Member
    162
    93
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    Toyota dealer parts guy here.. 2023+ Priuses, all BZ4X and a ton of hybrid Siennas have their 12v changed. Happens in 4th gen aprimes too as they are beginning to get old but far less often or with a lot more years/milleage on it.. don't know why. My 12v lasted a week in my 2024, never touched the one in my 2021... just changed the one in my sister's 2021 though..
    douglasjre likes this.
