Codes up tha Wazoo
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Colton Nelson, Mar 25, 2025.
  1. Colton Nelson
    Colton Nelson Junior Member
    Southaven
    2013 Prius v wagon
    I checked for exhaust gas in anti freeze using a tester. It did not change color from blue to yellow
    . Is it possible the coolant pump is causing the knocking??
  2. Mendel Leisk
    40,471
    3rd gen head gasket failures are usually coolant leaking into combustion chamber(s) (per post 20). That test is for carbon monoxide, which may eventually happen, but in the later stages.
    borescope inspection of the combustion chambers is the usual DIY diagnostic, preferably with coolant system pressurized, to accelerate leakage. The morning after a drive is opportune time too, gives coolant leaks time to accumulate. You’re looking for exceptionally clean piston top(s), pooling coolant atop piston(s), and coolant tears commencing at the head gasket seam.
    MAX2 likes this.
  3. Brian1954
    Brian1954 Senior Member
    1,705
    665
    South Central PA, USA
    A negative result for the exhaust gas test in the coolant does not mean the headgasket is not going bad. Early headgasket problems will not result in a positive test result. Exhaust gases will only be detected after the headgasket leakage has advanced further along.
    A bad coolant pump will not cause the engine to knock. The knocking is caused by the misfires in the cylinders.
    My guesstimate is the engine coolant pump has been getting progressively worse over a farely long period of time. This caused the engine to repeatedly overheat, which caused the headgasket to start to leak. The only true way to check for a bad headgasket is to pressurize the coolant system and use a borescope to check for coolant seepage in the cylinders of the engine. This usually occurs in cylinders #1 or #2 on these Gen 3 engines.
    Your car has 220k miles on it. If you confirm that you have a bad headgasket, I would be looking to replace the car rather than put any money into it.
    PS, Mendel responded as I was composing this post. We both are saying the same thing.
    #23 Brian1954, Mar 31, 2025
    MAX2 likes this.
  4. Mendel Leisk
    40,471
    I’m not 100% in harmony regarding the cause of the head gasket failure though: while failing water pump may well be a factor, carbon-clogged EGR would be my first concern.
    Brian1954 likes this.
  5. Leadfoot J. McCoalroller
    7,828
    7,294
    Pennsylvania
    2018 Prius c
    7 Ways a head gasket can fail (Haynes link)
    Those 1.8L engines seem to be suffering type 7 on that linked list. Easiest to spot with a temporarily pressurized cooling system and a good borescope camera in the spark plug hole.
  6. Mendel Leisk
    40,471
    Missed this (from post 13). Pretty much guaranteed to be head gasket.
    Danno5060 likes this.
  7. Colton Nelson
    Southaven
    2013 Prius v wagon
    I have temporarily resolved my engine knocking by disconnecting my EGR. Recommended through the following link.
    This is only to isolate the problem... since the engine knocking went away I believe residual carbon is in the intake manifold.
    Can i soak the intake manifold in gasoline?
    Of course , out of caution, I will follow through with checking for a blown head gasket.
  8. ASRDogman
    ASRDogman Senior Member
    7,118
    3,719
    You can soak it in gas, but it would be stupid to do so!!!! Extremely dangerous!
    You can use Gunk, and a .22cal bore brush in a drill to clear them out.
    You'll need to clean out the egr cooler also. No point in doing half the job.
    And check to make sure the egr valve is functioning correctly.
  9. Mendel Leisk
    40,471
    I’d put that first on the agenda.
    Have a look at the top two links in signature. (On a phone turn it landscape to see signatures)
  10. Brian1954
    1,705
    665
    I think that you linked the wrong video. The one you linked does not even mention the EGR. Did you only disconnect the electrical connector from the EGR, or did you use a putty knife to block off the flow of exhaust gas from the EGR valve to the intake manifold?
    You never described in your previous post exactly when the engine knock is occurring. Does it occur in the morning when the engine is cold, and then it clears up after 15 to 60 seconds of running? Does it only occur at idle, or partial throttle, or full throttle after the car has warmed up? Give us a description of when the engine knock is occurring.
  11. Danno5060
    Danno5060 Active Member
    351
    180
    Wyoming
    It sounds like you may have something wrong with the EGR actuator motor or the electrical connection. (I'm assuming the test you did was to temporarily block off the EGR with the putty knife trick.)
    Did you replace the EGR valve, get one off of eBay or something like that, or get one from Toyota?
    You seemed to eliminate the connections to the ignition coils and injectors, but it's still worth checking these, as those would also cause cylinder misfires. (Do you have an OBD scanner capable of looking at the cylinder misfire counts?)
    #31 Danno5060, Apr 2, 2025
  12. rjparker
    9,509
    5,822
    Every engine, no matter how good, can blow a head gasket from overheating.
    Asking for the symptoms rather than the miles is far more important.
    Car Care Nut HG Borescope at 660s
    Car care Nut Egr video with block tube test
  13. Colton Nelson
    Southaven
    2013 Prius v wagon
    Total miles is about 220,000. I have not replaced the egr valve, I only cleaned it. I did notice this morning exhaust gas from the tail pipe, which is unusual.
    Rough idle begins in the morning. after sitting at a traffic stop, rough idle begins during acceleration.
    I have been on the interstate without issues. I generally travel 65mph.
  14. rjparker
    9,509
    5,822
    Typical of head gasket causing major rattles fooling the misfire detection.
    It bothers me when egr cooler cleaning is recommended to fix knocking. Blocking the egr flow is easy and will rule out egr work.
    It is common for this test to give a false negative.
    If it's white it's getting serious.
    Classic head gasket symptoms. I would expect loss of coolant very soon.
    MAX2 likes this.
  15. Colton Nelson
    Southaven
    2013 Prius v wagon
    Well, I bypassed the compression tester and the leak down test. Even though I had rented a compression tester from auto zone, about $45, it lacked the correct adapter to be used on a Prius.
    The remedy was to purchase a 30$ leak down tester on Amazon. KUNTEC Cylinder Leak Down Tester Engine Compression Diagnostics Test Tool Kit for Piston Ring, Valve, Head Gasket
    https://a.co/d/6qnStuG
    Instead of using these tests, I removed all spark plugs and with the help of my dad he held folded white paper against the cylinder holes the spark plugs were removed from.
    After starting the car, Basically, coolant squirted out of the engine.
    Brian1954 and Mendel Leisk like this.
  16. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    Third planet from the Sun
    Is the volume splashing out large or small?
    From which cylinders is the coolant splashing out?
