OK to remove metal heat shield?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by WienerMobile, Apr 10, 2025.
  1. WienerMobile
    WienerMobile Junior Member
    29
    Madison, WI
    My mechanic recommended leaving the heat shield (see attached photo) off my 2015 Prius. A few days ago I noticed the shield hanging down, so I asked them to check it while the car was in for an oil change.
    They said I could buy the plastic fasteners from Toyota if I wanted it reinstalled, but that the shield wasn't necessary. I searched several threads on PriusChat, and some said it was OK to leave it off.
    I live in a cold climate, and can avoid parking over combustible dry grass, etc.
    Any consensus? Thanks!
  2. Madmommymelinda
    Madmommymelinda Junior Member
    42
    Lexington, KY
    2014 Prius Plug-in
    I removed mine a while back. No issues whatsoever
    Tombukt2 likes this.
  3. bisco
    51,023
    don't drive over anything flammable
  4. BiomedO1
    2,725
    1,456
    SacTown, Ca
    Sure, no problem - OEM manufacturers love to hang useless, redundant equipment on their mass produced lines. It just adds to the cost and the customers will pay for it anyways.......:(:rolleyes::sleep::whistle::censored:
    If you didn't get it, that was sarcasm........ There was a purpose for it. Will it effect the operations, unknown......
    It's your car, do whatever you like with it....
  5. Dave1UK
    Dave1UK Junior Member
    51
    London, UK
    Active
    Probably won't have a negative impact on the car itself assuming the heat transfer now doesn't impact neighbouring areas that the heat shield would of prevented/limited.
    Also depends on how you like to take care of your car. If it was a question of a few clips/screws which are pennies you don't need OEM parts. I personally would just replace them and secure it. No one is going to look after your property the way you do.
    Also why the hassle of having a thought in the back of your mind not to park in high dry grass or park here and there etc as you don't have a heat shield, seems counterproductive.
  6. Tombukt2
    12,010
    2,123
    All mine in trash loooong time I drive in tall foilage almost daily . Quietly alongside deer, bears on tar river. Etc
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,343
    2,337
    Taylors, SC
    I replaced mine with an aluminum anti-theft catalytic converter shield.
  8. Mendel Leisk
    40,467
    To answer the title question:
    No.
  9. PriusCamper
    PriusCamper Senior Member
    11,980
    4,870
    Pacific Northwest, USA
    If you're ever driving through death valley or some other super hot place, take a different car.
