2003 prius runs suspect transmission problem
Discussion in 'Generation 1 Prius Discussion' started by William s, Apr 14, 2025.
Tags:
  1. William s
    William s Junior Member
    Ann arbor michigan
    2003 Prius
    The other day car was fine. Stopped to get food and red triangle came on..turned car off..got food and started car and red triangle still there.
    Put it in reverse and no movement. In addition the little square indicator that shows what gear you are in was and is not present...now in all gears. Had car towed home..checked trans fluid and filled..about 1/2 quart..started car and as above its still won't move..or go in gear..
    Couple sidenotes..main screen failed about a year ago so no help there, car still starts and runs great
    My suspicion is trans may be toast..please help..I have access to standard obd2 reader
  2. Brian1954
    Brian1954 Senior Member
    1,563
    606
    South Central PA, USA
    The red triangle comes on when certain trouble codes have been triggered. The first thing you need to do is use Techstream or other compatible scanner to retrieve the codes that the car is trying to tell you about.
  3. William s
    Ann arbor michigan
    2003 Prius
    At this time I do not have access to techstream
  4. ChapmanF
    16,941
    That's the first problem to solve. Doesn't have to be Techstream, can be any scan tool capable of reading all the trouble codes from a gen 1 Prius. And you don't have to have access to it yourself, if you have access to somebody who has access to it.
    If the "standard obd2 reader" that you have is showing you any trouble codes, by all means post those here. That'll be a start.
    There's a good chance that reader may not show the trouble codes we need to see. Because there are so many possibilities, it really is more productive to get them read than to try to guess.
  5. William s
    Ann arbor michigan
    2003 Prius
    Small update..car has been setting for a few hours now..nothing else has changed.
    Just started car again..now goes in gear and moves BUT did not right after topping up fluid.and red triangle has gone away..
    Question is. After filling fluid back up..why did it not move right away and after about 2 hours...it appears to have MAYBE resolved
    No techstream used or codes pulled
  6. ChapmanF
    16,941
    or answers found
  7. dolj
    dolj Senior Member
    8,108
    4,124
    Wellington, New Zealand
    Having all the codes read would be the most helpful thing to do when this reoccurs.
    #7 dolj, Apr 14, 2025
    Brian1954 likes this.
  8. MAX2
    MAX2 Senior Member
    1,335
    418
    101
    Third planet from the Sun
    Why did you choose transmission fluid?
    The amount filled indicates that the fluid was disappearing.
    Have you had any problems with fluid leakage before? Or is there something else you are not mentioning?
  9. William s
    Ann arbor michigan
    2003 Prius
    I have this car about 5 years..love it..no issues ever except replacing wheel bearing on front,both sides. I only assumed trans fluid cause trans appeared t not be working..filled it in fill hole til it began to leak...on level ground...I do not believe there is a fluid leak..no signs..but car is 22 years old..I have no history if trans fluid ever changed.
  10. MAX2
    MAX2 Senior Member
    1,335
    418
    101
    If you do not know whether the transmission fluid has been changed in 22 years, it is necessary to replace it completely by removing the pan and cleaning it from the dirt that has accumulated over 22 years.
  11. Brian1954
    1,563
    606
    The problem with your car is not related to the transaxle fluid. It seems to be more related to something overheating. That is why the car started and moved after it cooled down for 2 hours. The problem with the car will occur again, so be ready to scan for trouble codes.
  12. William s
    Ann arbor michigan
    2003 Prius
    Let me clear up a bit..car trans stopped 8 days ago..I finally checked fluid 3 days ago and refilled..
    Car sat almost a week before I checked fluid..but I started car multiple times to see if it was a glitch in that week..
    Car only began to move AFTER topping up fluid and it setting..
  13. dolj
    dolj Senior Member
    8,108
    4,124
    Do you mean sitting? If you really mean setting, what was set?
  14. William s
    Ann arbor michigan
    2003 Prius
    I meant sitting
