ABS Actuator and Accumulator Replacement, Still have soft pedal
Discussion in 'Gen 3 Prius Technical Discussion' started by MypriusV5, Apr 15, 2025.
  1. MypriusV5
    MypriusV5 New Member
    US
    I replaced the abs actuator and accumulator on my prius v.
    I followed the steps with my topscan scanner with this video.
    But I still have a soft pedal. When I bleed the front brakes the brake fluid doesn't come out as strong as the rears.
    Anything else to check?
    Thanks
  2. Mendel Leisk
    40,457
    Maybe the two components on the firewall ok, but still some air in the lines? Try another "Brake Fluid Replacement Without Techstream"? There's a link in my signature*, my workflow, @NutzAboutBolts video linked, and reference excerpts from Repair Manual.
    * On a phone turn it landscape to see signatures.
  3. MypriusV5
    US
    I tried it a few more times with the topscan scanner.
    It said Air Bleeding has Failed.
    Please check vehicle condition and try again. If problem persists please refer to repair manual.
    All the components are new from Toyota. No leaks.
    Thanks
  4. JC91006
    JC91006 Senior Member
    16,651
    8,501
    You can manually bleed the brakes, you don't have to use a professional tool to do it. After you bleed, you need to do a linear valve calibration. That's really all you need to do
  5. MypriusV5
    US
    I purchased the cable for techstream and I will try a Bleed with that program.
    After watching this video it says to release the parking brake before the linear offset is calibrated.
    I never did that. I bet that is why it kept failing.
    Hopefully it works with techstream today.
    Thanks.
    #5 MypriusV5, Apr 16, 2025
    Brian1954 likes this.
  6. JC91006
    16,651
    8,501
    Many times the linear offset will fail if your 12v battery is not charged up. Since you're doing it with the engine off, the 12v battery has to provide enough power for the system to do the entire calibration
  7. Mendel Leisk
    40,457
    Good to have the car on a charger for stuff like this.
  8. MypriusV5
    US
    Yes, the first time I did it was without a charger. My battery was toast after not using the car for a few months.
    I have installed a fresh 12v battery with a charger on it now.
    Trying it today.
    Thanks
  9. ChapmanF
    17,180
    During the linear solenoid offset learning, the car tries a sequence of different control values for the valve and observes the brake pressure response. Having the parking brake applied keeps the rear calipers applied mechanically so the pressure responses would be wrong, and the learning procedure doesn't proceed in that condition.
    If I remember right, if you are using the non-Techstream procedures, Toyota used the same jumper-wire actions to select one of two different calibration procedures depending on the parking brake state. You get the linear solenoid learning if the brake is off, and some other calibration of some other thing if the brake is on.
  10. MypriusV5
    US
    I finally finished the job.
    The brake was still going to the floor, as I finished the abs brake bleed procedure.
    I was going to drive it to the local mechanic's, but I didn't need to.
    The brakes where perfect when I put the wheels back on.
    I guess I was not used to how little throw the pedal has. The car stops on a dime with little force on the pedal.
    Thanks for all the help!
    wukong sun and Brian1954 like this.
