I need to replace my 2022 Prius Prime Limited front grille. There are two grille options that fit my car: 53101-47150 53101-47160 One is 200 more expensive. What's the difference? PS: I can't post links.
You should probably do a parts search using your VIN to ensure you get the correct part. Both parts you've indicated, stated 'no paint req.' I know the exterior front end is painted plastic, so the pictures probably isn't inductive of the actual part. Possibly a sub-assembly that snaps onto or behind the painted surfaces. There's also that smoked translucent assembly that covers a good portion of the part pictured. Hope this helps.......
