Lane Departure Assist and Steering Wheel grip
Discussion in 'Gen 5 Prius Main Forum' started by thompsam, Apr 16, 2025.
  1. thompsam
    thompsam Junior Member
    Raleigh
    Just purchased a new GEN5 and tried out all the driver assist features yesterday on the highway. Everything seems to work as expected except for an annoying problem that seems to be caused by the LDA feature. I keep getting frequent "Keep Hands on Steering Wheel" type messages even though I do have my hands on the wheel, but apparently I'm not gripping the wheel hard enough. I don't want to disable LDA because it is a valuable safety feature, but I'd like to be able to adjust the sensitivity of the wheel sensor so that it will recognize my hands are on the wheel but not in a "death grip". I've not seen any customization setting for this, but is it possible to do this and if so, how?
  2. Hammersmith
    Hammersmith Senior Member
    1,963
    1,967
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    You must have a regular Prius and not a Prius Prime.
    Lane Tracing Assist(LTA) can use two systems to monitor the driver. First is a set of capacitive touch sensors in the steering wheel. Second is sensing steering input via the steering angle sensor. The Prime has both systems while the regular HEV only has the second.
    So you need to get in the habit of slightly moving the steering wheel when the alert comes on. You don't have to apply enough force to actually alter the course of the car, just fight the automatic steering barely enough to let the car know you have your hands(or knee) on the wheel. You'll get it pretty quick with a bit of practice. Since there are no capacitive touch sensors in your steering wheel, it doesn't matter how hard you grip it, nothing is going to happen.
    For the record, swapping the regular HEV steering wheel with that of a PHEV steering wheel adds the touch function without any other modification. But it's prohibitively expensive to buy a new steering wheel from Toyota. I got mine from a salvaged Prime for $150 because I converted my interior over to the red/black "sporty" Prime interior and the steering wheel was part of that. Getting access to the touch sensors was just a nice bonus.
    Also, the reminder is on a 15sec timer. If you do a lot of highway driving, you'll get to the point where you'll start to automatically bump the wheel every 13-17 sec.
  3. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    347
    269
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    I don't believe your steering wheel cover is hampering the "hands on the wheel" detection. I believe the car is looking at the resistance to a force applied to the wheel by the lane assist function. If it cannot turn the wheel with a tiny force applied, then it assumes your hands are on the wheel. If the wheel moves more than a tiny amount, it assumes your hands are not on the wheel. I do not know this for a fact - just sayin'
  4. tovli
    347
    269
    Boynton Beach, FL
    2023 Prius Prime
    XSE
  5. thompsam
    Raleigh
    Thank you. I should have been more specific, but yes, I have the standard hybrid Prius. I think I just assumed that the steering wheel was sensing my hands weren't on the wheel since that's the gist of this message that gets displayed. I'm guessing when I squeezed the steering wheel a bit, I actually moved the steering wheel a bit and thus reset the 15 minute timer.
    Guess I'll have to see if I do indeed get used to this as I drive it.
    PS: My wife refers to these features as "Jesus takes the wheel", the name of a song by Carrie Underwood
    daisy555 likes this.
  6. BiomedO1
    2,725
    1,456
    SacTown, Ca
    I hate to say that doesn't surprise me. I know that I've gotten a bit lazy when using adaptive CC. I still have a car w/o it, and have to remind myself; THIS CAR WON'T SLOW DOWN; when approaching another car.
    Now someone whose grown up driving with all these bells and whistles are much less aware of their surroundings while driving. Add to that cell phone and tablet distractions. I find a lot more people are changing lanes without looking. I know some people used to do that in the past, but it seems much more prevalent now.
    tovli likes this.
  7. Hammersmith
    1,963
    1,967
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm not saying it's wrong, but the Adaptive/Dynamic Cruise Control conclusion comes from a single report from a Dutch insurance group. I wouldn't want to draw sweeping conclusions from a single data point.
    Personally, I found Toyota's implementation of Dynamic Cruise Control in TSS 3.0 to be a huge safety improvement to me in my visits to Chicago and Minneapolis. I found myself one-pedal driving in congested traffic with me controlling acceleration and letting the car control braking(all the way to a complete stop). I felt far safer using this system than I did with my old 2010 Prius in trips to Minneapolis and Portland
    #7 Hammersmith, Apr 16, 2025
    tovli likes this.
  8. BiomedO1
    2,725
    1,456
    SacTown, Ca
    While there's a mixture of cars with and without the adaptive cruise control option, and an inattentive driver that's only driven in adaptive cruise control cars and suddenly finds themselves behind the wheel of a non-adaptive cruise control system or no blind spot monitoring - I can see an issue with that.
  9. Prodigyplace
    12,395
    11,676
    Central Virginia
    On my 2025 Camry (hybrid). the ada[tove cruise control braked too suddenly for a hybrid, IMO. I just gradually brake, which turns off the cruise control
  10. BiomedO1
    2,725
    1,456
    SacTown, Ca
    Have you tried extending the 'follow' distance? I've notice that if there's a large difference in speed and the car in front of you is moving very slowly - it will hit the brakes hard. If you creep up on the car in front of you, it just shuts down the engine and switches to regenerative braking. Once the car has a safe distance, everything will re-engage. Unfortunately if someone slides into your safety zone, the adaptive CC will also brake hard, depending on the distance. I rarely use adaptive CC in traffic like that, mostly on the open road.
    The system is limited by it's programming and sensor sensitivity. I still get the dash board turning red, buzzer, and BRAKE alarm on occasions. This happens when a car in front of me is making a right or left turn into a pocket and I'm approaching them too fast. If I don't blip the brake pedal or let off of the accelerator pedal; the cars' ECU thinks I'm "asleep at the wheel". Nanny - back-seat driver's mode.:(
    It took me a long time to trust the cars' adaptive cruise control; but it also took me a long time to trust regular cruise control.
    #10 BiomedO1, Apr 16, 2025
  11. Prodigyplace
    12,395
    11,676
    Central Virginia
    When i did my test, it was at maximum follow distance. I find adaptive CC works MUCH better on the 2025 Camry than it did on my 2017 Prius Two. Perhaps it is because of all the added sensors since I have most all the safety features on the Camry, including panoramic view The adaptive CC does not brake for a vehicle in the neighboring land and actually senses & displays when someone cuts in front of the car.
  12. sclevine
    sclevine Active Member
    142
    145
    NE Florida USA
    2024 Prius
    After much use, I learned that it is not about gripping the steering wheel, it is about just moving the steering wheel slightly. Give it a light tug every 10 seconds or when you see the warning pop-up, and it will go away. Hands on steering wheel but no movement of wheel, and you will the warning and then chime. Just a very light tug is all that is needed, not hands on wheel.
    silvertounged devil likes this.
  13. Prodigyplace
    12,395
    11,676
    Central Virginia
    IMHO it is good but the behavior was designed for ICE only and should be tuned more efficiently for hybrids.
  14. Paul Gregory
    Paul Gregory Senior Member
    1,376
    356
    Alberta
    2024 Prius Prime
    XSE
    I had the same problem until I learned how to use it properly. It's activated by signaling a lane change, and it will engage after a few seconds if the lane to be entered is clear. It will disengage if you force the steering wheel in any way. That's what I was doing wrong; just signal the lane change, and keep your hands lightly on the wheel. it will then do its job.
    Prodigyplace likes this.
  15. Hammersmith
    1,963
    1,967
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Number one, that's not what there're asking about(where do they mention lane changes?). Number two, it probably doesn't apply to them. The auto lane change function is only installed on Primes in the US. The regular HEVs don't have it.
    Traffic Jam Assist, auto lane change, and front cross traffic alert all rely on a set of sensors in the front bumper. For whatever reason, Toyota decided to only mount those sensors in the US Prime/Plug-In and not in the regular HEV. Although my experience fitting a Prime steering wheel to my HEV makes me wonder if adding auto lane change and FCTA to the HEV is theoretically possible. I plan to have my hood and bumper resprayed in a few years to get rid of the rock chips I'm building up(and then PPF them); maybe I'll try to source a Prime front bumper at the same time to see if it's possible.
  16. Prodigyplace
    12,395
    11,676
    Central Virginia
    On my Camry they call that Lane Change Assist (LCA).
  17. Mendel Leisk
    40,463
    Some likely looking, but not seeing the car there due to forest of head rests, raised belt lines and thickened C-pillars, maybe compromised further by aftermarket tint.
  18. Prodigyplace
    12,395
    11,676
    Central Virginia
    And my local salesman said that is BECAUSE Toyota concentrates on safety features, IMO what you mentioned ARE low cost safety features,
  19. Mendel Leisk
    40,463
    More succinctly, Toyota is concentrating on crash- mitigation features, at the expense of traditional safety features (visibility).
    They’ll all be like subs, soon enough. :LOL::cry:
    Withoutadoubt my least favourite maneuver is lane change to the right (North American).
  20. Prodigyplace
    12,395
    11,676
    Central Virginia
    One reason I bought my 2008 Corolla was because i saw the new body style in Japan that was coming with the higher rear doors, restricting visibility for the driver. I think it actually hit the US in 2010.
