Prius THREE Upgrade to Intelligent Parking System
Discussion in 'Gen 3 Prius Accessories and Modifications' started by capflyer1, Feb 9, 2016.
  1. capflyer1
    capflyer1 New Member
    Maryland
    I have a 2015 Prius Three, not III because only 2010 used uppercase roman numerals for model designation, and was wondering what was in the realm of the possible for buying OEM or Aftermarket parts to add the intelligent parking system (look up intelligent parking system on wikipedia)
    I know I'd need to add the sonar system first, then whatever other comptuers/motors that turn the steering wheel/display the overlays on the camera, etc.
    I found this part on Ebay which I'm guessing is only one part of the puzzle: (sorry I can't put links, but look up
    PARKING ASSIST ADAPTIVE CRUZ 86792-47160 TOYOTA PRIUS 10-13 on Ebay).
    If I can't install the entire system, it'd be nice to at least put the sonar system in. I've seen some universal kits, but OEM would be the best.
    Has anyone done this? I'm assuming the car is already pre-wired, but would just need to computers/sensors to get it all up and running.
    Thanks for reading! Hopefully someone can provide some advice :)
    Dylan Doxey likes this.
  2. mrbigh
    3,686
    699
    Long Island, NY
    I doubt about it, to all.
    It will not be as easy as you think, and considering you will be able to get all the hardware together, more likely that the vehicle will need a software upgrade to make it operational.
  3. bisco
    51,011
    i have never read about anyone doing it. we have trouble with home link mirror installs.
  4. capflyer1
    Maryland
    I would think the parking sensor system would be plug and play since there are already pre-marked spots on the bumpers where the sensors go.
    Do any models of the Prius (before 2016) have the intelligent parking system? Or is that a European/Asian market thing?
  5. bisco
    51,011
    don't know for sure, but i don't recall anyone ever talking about it.
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    You need to find a 2010 V-AT. It was dropped from the 2011. Some of us played around with it for a bit but it isn't very useful.
    Toyota isn't going to absorb the cost for installing parts that aren't going to be used. You may be able to modify a bumper cover to accommodate the sensors but I'd be surprised if you'll be able to plug them in. If the sensors can be plugged into the ECU does the ECU have the programming to interpret the signal? The IPA used the rear camera & the nav screen.
    My guess is that any V-AT that needs enough avionics to return functionality to the package will be a total loss.
  7. Joeski831
    Joeski831 New Member
    Monterey county
    Has anyone made an attempt. It seems that there should be a way to blend used parts or used cars in order to accomplish park assist. I am also wondering if anyone has information on self driving after market systems
  8. ChapmanF
    17,180
    The cars with parking guidance had a separate ECU, the parking assist ECU. There's an empty space for it in the ECU motel behind the glove box, I think.
    The nav unit (at least the 7" screen one) has both a composite video input and a GVIF input. In cars without the parking assist, the backup camera plugs right in to the composite video input of the nav unit. With parking assist, the camera plugs in to the parking ECU's input, and the parking ECU adds its guide lines and such, and sends GVIF video over to the nav unit.
    You might be the first one to really try to transplant the system. A lot of the wire harness wires are probably missing and would need to be transplanted also.
  9. Mendel Leisk
    40,457
    Oh heck just realized this is a resurrected thread.
    @Joeski831 how long have you had the car, and what’s the miles on it?
  10. MAX2
    MAX2 Senior Member
    1,436
    481
    101
    Third planet from the Sun
    I don't trust these automatic gadgets.
    At the most inopportune moment, a stoned pizza delivery guy on a bicycle will jump out from behind you, and if you're distracted, he'll end up under the wheel of a car.
  11. Joeski831
    Monterey county
    4 years it’s got 160,000 miles
  12. Joeski831
    Monterey county
    Thanks. I think you are correct it’s a bit to big of a project
  13. Mendel Leisk
    40,457
    Sorry, can’t remember why I asked. Maybe to nag about EGR cleaning. :)
