Is telling people to clean the EGR system a prank?
Discussion in 'Prius v Main Forum' started by Dan H, Apr 24, 2025.
  1. Dan H
    Dan H Junior Member
    35
    Miami FL
    2015 Prius v wagon
    Is telling people to clean the EGR system and intake a prank that the senior members like pulling on people? I ask jokingly. That is one heck of a job, so I hope it was necessary. My 2015 v has 107k miles and I was hoping that mine is on the safe side of the blown head gasket fix issue? But I noticed, only twice for about 2 seconds, a different sound from the engine after the first start of the day. So I'm hoping that was nothing. But if it was, that this saved the engine from serious damage and further repairs. It was fairly dirty in there, but I didn't see anything completely clogged and liquid cleaner flowed unobstructed through the cooler. IMG20250423112631.jpg IMG20250423112552.jpg IMG20250423112542.jpg IMG20250422155926.jpg
    I followed these YouTube videos as they are pretty entertaining.
    My car has been out of commission for a whole week as I've had to wait for different tools to make the job easier, and now I am waiting for a 14mm thin wall spark plug socket, and plugs from Toyota as I already have the windshield wiper assembly out. I figure at 107k miles they are probably due. Is there anything else I should look into doing while I have it apart?
    51,011
    it's definitely an issue, but hard to quantify, as there is no proper testing data to look at. so people have different experiences, and it's unknown as to why that is.
    did you clean the tiny intake manifold ports? they are very important.
  3. ChapmanF
    17,180
    Did you happen to take before and after flow measurement, as seen in this thread?
    That's one way of approaching the "was it necessary" question with a bit of hard data. It's also helpful for other people to see if you add the before/after numbers to that thread.
  4. Silas Wentworth
    Silas Wentworth New Member
    2011 Aqua
    Not a prank—cleaning the EGR and intake is a smart move at 107k miles. It helps prevent head gasket issues and rough starts. Since it's already apart, good call on replacing spark plugs. Also check the PCV valve, clean the throttle body, and inspect the intake for oil. You’re definitely on the right track!
  5. Dan H
    Dan H Junior Member
    35
    Miami FL
    2015 Prius v wagon
    I didn't take any flow measurements as I don't have the gear for it. And yes I did clean the small intake ports with small bottle brushes.
  6. Mendel Leisk
    40,457
    I asked similar, again jokingly, about physicists and their "string theory". A "fly on the wall scenario":
    A meeting of physicists, all file into a conference room, close the door, sit around a table, and the chairman asks: "are we all physicists here? Good. Ok, we can drop that "string theory" nonsense." Chuckles abound...
    But EGR cleaning, not so much mirth; see attached.
    It's not that hard. There are tactics that help:
    1. Remove EGR cooler lower bracket nut and stud, in advance of the "big day". This can be done with out removal of anything else, and can be left off permanently. Besides getting a troublesome fastener out of the way, it also means you can leave the cooler's rearmost pair of studs on. This saves time, and ensures the gasket there won't drop down as you pull the cooler out. Also helps to align when reinstalling.
    While you're at it, remove the EGR valve's lower nut and stud and upper bolt, put a light patina of anti-seize and reinstall (see top link in my signature for torque info; on a phone turn it landscape to see signatures).
    2. Assuming you're not doing a coolant change at same time: o avoid coolant spillage when removing EGR cooler, preemptively drain two quarts of coolant from the radiator drain spigot, into a clean container (return to reservoir after completion). Note: you do NOT need to remove the throttle body's coolant hoses.
    3. Deal with the EGR cooler first. Get it out, one end corked and propped up in a corner of a laundry sink or rectangular bucket, with a carbon-eating solution. For light accumulations oxi-clean versatile stain remover will do, or escalate to lye.
    4. Stay organized with everything you remove, lay stuff out sequentially, use labels.
    5. Budget a weekend for this; you don't want to rush.
    6. Pay very close attension to the direction the egr's metal gasket's central holes "dimple". Most go one way, one the other way. I've got a pic somewhere, but most expedient is to just note during removal.
    #6 Mendel Leisk, Apr 24, 2025
    douglasjre and PriusCamper like this.
  7. Dan H
    Dan H Junior Member
    35
    Miami FL
    2015 Prius v wagon
    Thanks for those photos, mine was nowhere near that bad
  8. Mendel Leisk
    40,457
    Yeah that's 200kish. Keep in mind though: the EGR cooler namesake is not trivial, and even a modest coat of carbon, while not impeding flow, is reducing the cooling ability. Too, while overall clogging may not be bad, the EGR passasge at cylinder one on the intake manifold will lead the pack in clogging.
  9. MAX2
    MAX2 Senior Member
    1,436
    481
    101
    Third planet from the Sun
    Not everyone has Techstream. AUTEL AP200 or other scanners can extract this data from the ECU?
    Or only a step-by-step test for the EGR valve?
  10. ChapmanF
    17,180
    The scan tool has to be able to get "mode 6" monitor test results. That is a standard OBD-II feature so many scan tools can do it, AP200 included. The thread linked above has examples contributed by a lot of people with a lot of different scan tools.
    On the AP200, as it is a standard OBD-II and not manufacturer-specific feature, you find it in the "Eobd" screens of the app, not the Toyota ones.
    douglasjre and Brian1954 like this.
  11. MAX2
    MAX2 Senior Member
    1,436
    481
    101
    I'll try to check this on the Prius V.
    The EGR system is the same.
  12. rjparker
    9,486
    5,811
    Car Scanner easily reports the noncontinuous monitors. My v routinely is around 20.8 kPa but varies between 19 and 22.
    cat and egr
    douglasjre likes this.
  13. tony_2018
    tony_2018 Member
    225
    66
    Def worth cleaning or swapping out to one thats cleaned.
  14. schmegma_swiller
    schmegma_swiller Junior Member
    17
    2016 Prius v wagon
    Those videos you posted as well as the tips given above by Mendel Leisk got me through the job. I needed to buy a thin walled deep 12mm socket for the lower stud on the cooler, I had a deep socket but it was too wide, so be ready for that. The only things I'll add is that I used lye solution at the advice of the members here and it worked remarkably well. Only 2 ~30 minute soaks and my cooler was spotless inside. The other thing I found necessary was removing the heater core hose from under the cooler to get it out of the way. It makes accessing the nut and swinging your ratchet a piece of cake. Overall not that difficult of a job but time consuming.
  15. Mendel Leisk
    40,457
    That's good to know. I started advocating a lye solution, without having tried it myself (I've been using Oxi-Clean, a couple of times now). But it seemed sensible. Several members here had mentioned oven cleaner, which is basically a modest level of lye plus some other surfactants. A DIY mixed lye solution can be more powerful though.
    Moot point for me, having left both the nut and stud off at that location, but good to know.
  16. schmegma_swiller
    17
    2016 Prius v wagon
    It's clearly doable without removing it since no one one else seems to do it, but I drained all the coolant anyway, and I was really struggling until I pulled off that hose and it made all the difference for me.
