Mystery Part ! Please help ID
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by guuunks, Apr 25, 2025 at 11:38 PM.
  1. guuunks
    guuunks New Member
    New York
    I have a mystery part question. Thought someone might be able to help me solve it.
    I found a random part not attached to anything just resting on the frame of my Prius just behind the lower motor mount.
    I was down there replacing some rubber exhaust hanger and seeing if I could reattach this lower heat exhaust manifold heat shield that came off when it rusted off around the bolts. Side question, don’t know if I can easily get it back on there…how important is it to try and get back on? (see this companion post: Exhaust Manifold Heat Insulator #2 | PriusChat)
    Here are the photos of where I found the part, both with the part sitting there and not:
    For the life of me I can’t tell where this thing came from and it didn’t seem to fall from above. So strange.
    Here are some photos of the part by itself:
    My hunch is that someone at a shop I took the car to at some point took this part off and placed it on this spot in the frame as they were doing work only to forget it was there when they lowered the car.
    My records for the car show the following service being done at different shops:
    - 11/2019 - Replaced Hub Assembly on Front Wheels
    - 08/2020 - Replaced Front Ball Joints
    - 11/2022 - Replaced Front and Rear Struts
    Curious what your thoughts are, are you able to ID this part?
    Car seems to be running very smoothly for the past few years, no major issues.
    Thanks!
  2. pasadena_commut
    pasadena_commut Senior Member
    2,104
    619
    Southern California
    Rubber on top and metal on the bottom? Looks like some sort of shock absorbing mount, and the bolt/stud which had passed through it, and through the hole below where it sat, is gone now. The shape and size is sort of similar to a ball joint but the pictures I found online of the front ball joints on the Prius didn't look like that. Perhaps under the outer rubber they do?
    guuunks likes this.
  3. PriusCamper
    PriusCamper Senior Member
    11,838
    4,796
    Pacific Northwest, USA
    Take it to the shop and ask... My guess is that this part fell into that spot and the shop had those pieces on hand and simply used a new one rather than looking for the old one. Pretty sure if this part wasn't in place with a new one that you'd have noises and other symptoms.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,921
    1,887
    NJ-USA
    I will guess that was some type of "tuned vibration damper" that came apart because of rust.
  5. MAX2
    MAX2 Senior Member
    1,335
    418
    101
    Third planet from the Sun
    12313-21030 Engine Mount Adjuster Bracket (For Transverse Engine Mounting).
    This part has come loose from the bracket.
    See how it should look.
    Brian1954 and PriusCamper like this.
  6. PriusCamper
    11,838
    4,796
    Nice work recognizing that! Only remaining question: is this from the existing mount, or previous mount?
  7. MAX2
    MAX2 Senior Member
    1,335
    418
    101
    Judging by the photo, the bottom of this bracket is not very fresh. Corrosion has eaten away a fair amount of metal, so this part that fell off is most likely from the bracket in the first photo.
