P0A80 replace battery pack vs P0A80 Battery ECU error
Discussion in 'Gen 3 Prius Main Forum' started by Kriss015, Apr 28, 2025 at 9:55 AM.
Tags:
  1. Kriss015
    Kriss015 New Member
    Monday
    Poland
    I'm new user,
    Best Regards from Poland
    I can't find answers for my questions
    Question is about AurisII but I think is the same as Prius3.
    It have NI-MH battery.
    Hello I have a question about the P0A80 error because I found two descriptions of this error on the internet.
    1. Replace battery pack
    2. Battery ECU error.
    I'm writing from memory, so maybe not exactly like that, but you know what I mean. I'm digging into the topic because something doesn't suit me. I found information that it is a problem with the cells and I don't know if the same problem has been edited differently in different models/years, or if they are two different problems. Now it occurred to me that various applications can also have an impact. Dr. Prius points out problems with specific cells, but after replacing them with newer ones and changing the order of all cells, the problem is still with 3 and 12 or 12 and 13. Is it possible that the battery controller is dead and crashes after about 200km of driving? I unfasten the clamp and continue riding. I know that the battery is also weak, but the previous owner has already replaced the cells and I think he gave up because of it. The CarScanner app does not see the error at all. Thank you.
  2. MAX2
    MAX2 Senior Member
    1,335
    418
    101
    Third planet from the Sun
    Can you post scans of the Dr.Prius reports?
  3. ChapmanF
    16,943
    If you look in the repair manual (which is the right place to look :)), you only find the correct one, (1).
    Gen 3 no longer has a thing called a battery ECU. In earlier generations there was one, and it was an ECU in its own right, separate from the HV ECU up near the dash.
    In gen 3 there's still a little box with wires back there, but it's been demoted to "battery smart unit" or "battery pack sensor module" and it's pretty much just a remote-sensor annex of the power management control ECU in the dash.
    There is a P0AFC code for a problem with the sensor module, and a P0A1D code for a problem with the power management control ECU. But P0A80 is a judgment on the condition/performance of the pack. All of these codes are in the P0 range where codes are standardized industry-wide by SAE, so Toyota doesn't get to play with their meanings.
  4. Kriss015
    Kriss015 New Member
    Monday
    Poland
    I can't add a link
  5. Kriss015
    Kriss015 New Member
    Monday
    Poland
    Thanks, that's important news
  6. Kriss015
    Kriss015 New Member
    Monday
    Poland
    Those reports are in Polish but I think its understandable.
    #6 Kriss015, Apr 28, 2025 at 3:55 PM
  7. MAX2
    MAX2 Senior Member
    1,335
    418
    101
    Your high voltage battery has problems. If you simply swapped modules around, it won't solve the problem. It may fool the high voltage battery computer for a short time, but after a while it will fail.
    On this screenshot (Screenshot_20250428-205231_Dr Prius.jpg) in the fifth pair of modules there is a problem with one module. The voltage difference between adjacent modules is more than 1V. This happens when one of the six cells in the module is damaged and then the module has a voltage of not 7.2V, but 6V. The battery ECU measures the difference between adjacent pairs of modules and when this difference reaches more than 0.3V, it generates a battery error code.
    On this screenshot the problem is in the 12th pair of modules.(Screenshot_20250428-004929_Dr Prius, Screenshot_20250428-005438_Dr Prius, Screenshot_20250428-205205_Dr Prius)
    Tech Tips
    DTC P0A80-123 is stored when a malfunction is detected in the HV battery or battery voltage sensor. If the HV supply battery is malfunctioning, the malfunction may not be reproduced when the condition of the HV supply battery changes due to difference in driving load (amperage), battery SOC and battery temperature. Therefore, use the freeze frame data when performing a repair.
    • When the HV battery is malfunctioning:
      • Voltage of one or a few of the battery blocks has dropped. (voltage difference from that of the next block is 1 V or more)
      • Voltage of all battery blocks is output randomly with no certain pattern.
    • When the battery voltage sensor is malfunctioning:
      • Differences in battery block voltages have a certain pattern.
    • In order to ensure HV battery performance, appropriate cooling performance must be maintained. Perform the following as necessary:
      • Make sure the air intake port is not blocked.
      • Make sure there are no gaps between the connecting parts of the ducts.
    INSPECTION PROCEDURE
    Battery repair consists of diagnosing all modules for their residual capacity, internal resistance and self-discharge (voltage reduction). Then, rejecting faulty modules and replacing them with serviceable ones.
    #7 MAX2, Apr 28, 2025 at 11:01 PM
  8. Kriss015
    Kriss015 New Member
    Monday
    Poland
    Thank you, colleagues, for your help. I already know that this battery needs to be replaced, but... Can someone explain to me how it works, that after swapping the cells, DrPrius shows the problem all the time in the same places? If the application shows a broken block, e.g. no. 3, then after replacing it with number 5 it should show a problem with number 5. Why is there a problem with the same places all the time after changing the order???????
    I use the Hybrid Asistant on a daily basis. Today I compared, for example, the percentage of charge. I'm posting screenshots from this morning. I see huge differences.
    The car did 300km, after about 50km when going downhill it braked with the engine, I thought that the HV system error would pop up again. I stopped, turned it off and on again, I didn't disconnect the battery. Only restart. The next 250km without problems. Fuel consumption on the screen 4.3L. Driving around the city without traffic jams.
  9. MAX2
    MAX2 Senior Member
    1,335
    418
    101
    Hybrid Assistant can also test the battery.
    Click the wrench symbol and select battery test.
    The Hybrid Reporter report will show a graph by module pairs, a graph of the largest discrepancy between low and high voltage, and a table with the parameters of the high-voltage battery.
    On the high-voltage battery, it is worth inspecting the condition of the test leads that connect to each pair, as well as the orange connector on the block in the battery where the test leads come in.
    Corrosion can introduce error in the measurements.
    Brian1954 likes this.
  10. ASRDogman
    ASRDogman Senior Member
    7,007
    3,668
    ??? You say you know the (?hybrid?) battery needs to be replaced, then continue on that you
    replaced cells....???? Are you saying you are playing wack-a-mole?
    Or did you replace the whole pack? Did you balance the pack? Did you reset the computers?
