Show Me Your Aftermarket Rims Wheels
Discussion in 'Prius v Accessories and Modifications' started by jrod81, Dec 19, 2014.
  1. Marguerite14
    Marguerite14 New Member
    singapore
    Camry wheels typically have offsets ranging from +35 to +45, which are generally suitable for the Prius v. If the offset is too high, you might need spacers to achieve the desired stance. Additionally, ensure that the center bore of the new wheels matches or exceeds that of the Prius v; if it's larger, hub-centric rings can be used to fill the gap.
