URGENT: how bad to drive with P0607?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrPete, Apr 30, 2025.
  1. MrPete
    MrPete Active Member
    500
    190
    Colorado, USA
    We are driving near Dallas.
    Torrential downpour and big shallow flooding (3-6 inches.)
    Made it through, no issues.
    Stopped for lunch.
    On restarting, I have a permanent P0607... And 4 hours of driving left today.
    I assume something got wet. For now I intend to keep going.
    Is it dangerous or harmful to drive with this DTC?
  2. ChapmanF
    18,204
    By that, do you mean it is shown only as a permanent code, and not as a current code? Is the check-engine light now on?
    If it's only a permanent code, I'd assume that something got wet, and is not now. Maybe worth checking the heated oxygen sensor wiring when convenient, see if there's a reason its water-resistance might be less than designed, or a way to improve it.
    What inspired you to scan for codes after lunch?
    Brian1954 likes this.
  3. PriusCamper
    PriusCamper Senior Member
    12,764
    5,173
    Pacific Northwest, USA
    Pretty sure he had a check engine light on restart after lunch.
    Maybe try this thread: Well.... my annual P0607 is back (Calling the Gurus) | PriusChat
  4. MrPete
    500
    190
    Colorado, USA
    Thanks...
    It is historical and current. Doesn't clear. Check engine light-inspired...
    Continuing south. Maybe sunshine in Waco?
  5. PriusCamper
    12,764
    5,173
    Thanks for entertaining us at your expense...
  6. MrPete
    500
    190
    Colorado, USA
    Mid-day yesterday, the check engine light went out on its own. About 24 hours after the flood->code incident.
    I'm going to assume it was Big Splash --> P0607 -> Dry Out Over Time -> All's Well. :-D
    PriusCamper likes this.
  7. PriusCamper
    12,764
    5,173
    I hope you don't run out of things to worry about...
  8. MrPete
    500
    190
    Colorado, USA
    What Me Worry - Alfred E Neuman img_1130.png :)
    Back home, got a big splash, this time a different code set... Now I'm suspecting a specific problem:
    * Got P0138 O2 Sensor code, plus P0607
    * Next morning, clearing codes worked
    This is now a painful intermittent thing. I've heard that sometimes water can impact the emissions system???
    I'm about to jack up the car and take a look-see... but (assuming there's nothing obvious like a damaged cable) this sounds like a potential time drain to diagnose.
    Does anyone have experience diagnosing issues that only show up when the car has been recently drenched? Any hints would be mucho appreciated.
  9. ChapmanF
    18,204
    Start with a visual check of the wire insulation integrity near where the wires connect to the heated oxygen sensor under the car.
    MrPete likes this.
  10. ColoradoBoo
    ColoradoBoo Senior Member
    1,241
    829
    Monument, Colorado USA
    I've never seen it, but heard the O2 sensors can go out if they get wet. For a 2011 Prius, Toyota wants around $173 but O'reillys has Denso's for $137
  11. MrPete
    500
    190
    Colorado, USA
    I've heard that too. Sounds a bit crazy, since the device is exposed to the under-car environment (of course the sensor itself is not, or shouldn't be...
    Rock Auto has a variety of compatibles for under US$100, if it comes to that. We shall see!
  12. MrPete
    500
    190
    Colorado, USA
    Pretty sure that was it. I don't know if this is "normal" but there's a tight zip-tie on the O2 sensor cable. It cut through the insulation over time. :(
    Since a complete replacement is ~~$100+...
    As an Electrical Engineer myself, comfortable with making and rebuilding cables for decades...
    • Is it reasonable to attempt a repair? (I'm thinking: disconnect each wire from the big connector, use high quality waterproof / adhesive shrink tubing to seal it up, and reassemble.) OR
    • Is it likely the water intrusion has caused some kind of harm to the sensor itself, and it's just not worth trying to save $100... buy a replacement.
  13. ChapmanF
    18,204
    I would fix the wires and call it a day, unless a problem persists after.
    MrPete and Brian1954 like this.
  14. MrPete
    500
    190
    Colorado, USA
    Also got a response from my local many-decades ASE mechanic friend (usually too busy to respond but this question got him going!)
    He strongly recommended replacement (and recommended Denso, NOT Bosch). Apparently some OEM O2 sensor models use the cable itself as part of the method for collecting outside air, so if the cable sheath has been damaged it can cause wonky trouble. He's not saying that's a certainty in any particular case, but he's seen it enough times that he's learned to just replace if the OEM cable sheath is damaged.
    The Denso replacement comes with a bunch of documentation; it's pretty clear that the replacement at least uses a different method.
    Having read up on this more, I'm cautious about this actually solving the problem. I sure hope I'm not getting into replace-the-cat-converter territory...
  15. ColoradoBoo
    1,241
    829
    Oh no, the catalytic convertor prices are nuts here in Colorado. My co-worker needed one in her old Jeep, $2,500. But she took it up to Wyoming and only paid $300. (Something to do with our Colorado Crazy emission laws...they are trying to be as extreme at California)
    Many years ago, I had a dusty engine in my old Scion so I was washing the car and decided to pop the hood and hose off the engine bay area. Not a good idea. Started the car afterwards and got a bunch of warning lights. Turned it off and let it dry all the way and it was fine. Didn't do that again!
    MrPete likes this.
  16. MrPete
    500
    190
    Colorado, USA
    @ChapmanF FTW :)
    Something chewed through the O2 sensor signal (blue) and ground (white) wire insulation. No wonder getting wet caused issues!
    Fixed... hopefully for a long time to come.
