Bleeding when pushing the front brake's pistons
Discussion in 'Gen 2 Prius Main Forum' started by Prius2006GuitarGuy, Apr 30, 2025 at 9:37 PM.
  1. Prius2006GuitarGuy
    Prius2006GuitarGuy Junior Member
    62
    Sweden
    Hey!
    I am planning on doing my front brakes: changing the pads and rotors.
    Watched around 25 videos including troubleshooting and when things go wrong just to know what I can expect.
    One video gave me something to think about (
    around 22:47) ,the guy says when pushing the piston back (using a piston brake tool) I should also open the valve to bleed that brake a bit as there might be debris there that would get pushed back up into the brake line if I do not open the valve when pushing the piston back.
    He was doing it on a non prius car so I'm wondering if that's standard on all cars, including the prius?
    Thanks!
  2. BiomedO1
    2,571
    1,381
    SacTown, Ca
    If this is your first time doing brakes, I'd strongly suggest having a EXPERIENCED friend; who knows what they're doing help you out for your first time. Brakes are a pretty important component of your car and needs to function properly!!! If you don't have a friend like that, take the car to a professional. You don't know, what your don't know!
    NO you DO NOT crack the bleed valve on your calibers! That's a surefire way of getting air into your braking system. There shouldn't be any junk behind your caliber piston, if you properly maintain your braking system. Brake systems flush-out every 3-5 years; Toyota doesn't recommend it but other OEM's like VW & Honda do.
    I can watch plenty of videos on how to defuse a bomb; but that doesn't mean I would want to - the stakes are too high.....
    Just my 2-cents.......
    #2 BiomedO1, May 1, 2025 at 12:47 AM
  3. PriusCamper
    PriusCamper Senior Member
    11,846
    4,799
    Pacific Northwest, USA
    I disagree... Brake systems are very simple and straight forward and the fear related to them causes so called "Professionals" to charge hundreds of dollars for something that's a super easy 20 min job once you've done it enough times. It's not much different then changing batteries in an expensive machine.
