P0AA6, 526, and 612 with +B 11.79V can this be the Aux battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by khaledme, Apr 29, 2025 at 8:29 AM.
  1. khaledme
    khaledme New Member
    Tuesday
    Dallas TX.
    Hello All,
    New to the forum and need help....
    I have red triangle of death, I used Techstream and I have these codes and I dont know if I should open the hybrid battery or it could be the aux battery causing the red triangle. a few months a go I fixed a leaky module and I am not sure if this could be the same issue or aux battery issue
  2. Tombukt2
    11,561
    2,031
    Your 612 is the detail code I believe that you're interested in doesn't that put you back in the battery case in the back the HV battery not the 12 volt this is not the hybrid isolation fault? And that detail code I thought put you in the battery case in the back of the car not the cables running to the inverter or the inverter converter itself or the AC if I'm not mistaken so if that code is active that puts you back looking for more leaks so it seems like you've got modules that are at their limit and when they get heat looks like they're discharging more than they should or whatever. You haven't noticed your fan running or anything like that? Interesting it's getting about that time of the year most places
    khaledme likes this.
  3. MAX2
    MAX2 Senior Member
    1,344
    423
    101
    Third planet from the Sun
    Code P0AA6 indicates a high-voltage circuit current leak. The 12V battery has nothing to do with it. Check this message. You have problems in the high-voltage battery area again (subcode 612)
    P0AA6, detail 526, and 612 | Page 2 | PriusChat
    khaledme, Brian1954 and dolj like this.
  4. dolj
    dolj Senior Member
    8,111
    4,127
    Wellington, New Zealand
    It is a hybrid vehicle (HV) battery fault for sure (INF 612), so yes, you will need to open the HV battery again. While the 11.79 V shown for B+ is not great (at a minimum, that 12 V battery needs a full charge), it is above the 10.5 V threshold the RM uses as the tipping point. Even so, I would fully charge that 12 V battery while working on the car.
    It is the same issue. A physical leak of electrolyte is not what is meant by leak in the context of P0AA6-612, although, if present, it contributes to the electrical voltage leak (to chassis ground).
    When you replaced the leaking module previously, did you thoroughly clean the battery case of all leaked electrolyte? If not, this could be your problem. Or, you have another module that is leaking. Replace all leaking modules and thoroughly clean the case to remove all traces of electrolyte before reassembling the battery.
    [EDIT] MAX2 beat me to it, LOL.
    khaledme and Brian1954 like this.
  5. khaledme
    khaledme New Member
    Tuesday
    Dallas TX.
    Thank you all for the responses. I appreciate your input. I will open the the battery again and report the findings
    I do have a couple of questions:
    How can I tell if the fan is turning on and off?
    When I cleaned the residual leaks from the previous module, I only wiped it off. Should I use a wire brush to polish the steel or a chemical?
  6. Tombukt2
    11,561
    2,031
    It's usually one of those 56 little tiny screws that hold the modules to the tray base all you need to do is put your test meter to ground and run the positive lead across each one of those little machine screws and each one where you get a reading mark it with a red sharpie they need to be dealt with whether you put a dash of goop where the little screw was supposed to go or change the module whatever something has to be done about that screw hole. And then usually in the middle of the pack where all the heat is happening that's where the prismatic modules tend to leak the most in the middle hence you see all the traces of the white stuff mid pack generally
  7. khaledme
    khaledme New Member
    Tuesday
    Dallas TX.
    thanks, yes that is how I found the leaky module the last time, I had to remove all the bus bars before taking measurements, I assume that is how it is supposed to be done, correct?
  8. Tombukt2
    11,561
    2,031
    I'm talking about the 56 little machine screws that hold the modules to the base plate when they're racked together all assembled ready to go doesn't really have much to do with the bus bars but to unrack everything generally you take all the bus bars and nuts loose but to check this real quick you don't really have to do that you could just flip the battery assembly on its side and measure from ground to each one of those 56 screws anything that lights up the test meter gets a red mark that means the screw is going through the plastic and the electrolyte is getting to the tip of the screw thread and of course getting to the case of the battery because the screw is going through the case and into the module many times after rebuilding you'll see a bunch of those screws missing been left out on purpose this is probably why
  9. pasadena_commut
    pasadena_commut Senior Member
    2,113
    622
    Southern California
    When cleaning up electrolyte in general, any battery that doesn't have toxic components (that is, not lead acid or NiCd, those need other steps) wear gloves and use a water dampened cloth, paper towels, even a sponge to remove all the chemicals. Treat it like a liquid spill even if it has dried. Afterwards, wipe the surface dry and wait. If no crust or "dried stuff" mark forms then it is clean.
    Don't use a wire brush on dried electrolyte because that will throw specks of it up in the air and it might end up in your eyes or lungs.
    If the electrolyte caused rust that must be addressed do so after removing all the spilled/dried electrolyte.
    Unplug the battery or batteries involved first!
  10. ChapmanF
    16,951
    Toyota's docs have suggested using a boric acid solution when cleaning up the NiMH batteries. It will help neutralize the highly alkaline electrolyte.
  11. khaledme
    khaledme New Member
    Tuesday
    Dallas TX.
    I am a little confused, can you explain how do you measure it? all of the 56 screws are connected together via the case, if I try to measure the voltage between any of them and the battery case (ground) they will measure as one unless I remove the 56 screws or the bus bars.
  12. MAX2
    MAX2 Senior Member
    1,344
    423
    101
    Read message #3 again and follow the link to proceed.
  13. Tombukt2
    11,561
    2,031
    I guess if you didn't want to unwrack completely you could just take the little screws out of the base plate and lift away the base plate leaving the module squeezed up the bus bars and nuts and all that in place and then you can just measure all of those threaded holes but the base plate off from the whole to a grounding point all of them any of them where you're picking up voltage make a Mark and I need to be dealt with now you see how you get to three grand with a new battery pretty quick I guess.
  14. pasadena_commut
    2,113
    622
    Southern California
    Why boric acid and not vinegar? While technically acetic acid is a much stronger acid than boric acid, the vinegar people generally have on hand is pretty dilute. Maybe they suggest this because boric acid is so weak it does not rust ferrous metals as quickly?
  15. khaledme
    khaledme New Member
    Tuesday
    Dallas TX.
    thank you all for your help. I have another question. Are those modules going bad because of the age or is it caused by overheating and can someone tell me how to check if the fan is turning on and off? Is there a procedure for that can I use Techstream to run a test
  16. Tombukt2
    11,561
    2,031
    Now I keep 30% vinegar here. Use it quite a bit .
  17. Tombukt2
    11,561
    2,031
    With Toyota tis software you can call up the fan in the back as you want to so you can see that it runs and is capable of running when it's called up by the computers in the car or you sitting in the seat with it laptop and a piece of software there are plug issues in the back that can create spotty problems with the fan they need to be addressed when you're doing all this at the same time generally yes the batteries are doing this because of many cycles they're just getting worn out like when your batteries go out in your D cell flashlight when you're the security guard at the plant you go down to the CVS drug store and you buy a four pack of D cell batteries for your foot long D cell mag light right? You don't put the batteries in the refrigerator you don't try to dissect them and run them through many cycles and discharges and what have you no you throw them in the trash and you go get new ones well eventually that's what's going to happen to the prismatic modules in your battery case at some point they're going to be needing to be replaced with ones that are new not renewed but new at least in my world
  18. ChapmanF
    16,951
    Techstream, by the way, is the name of the software; TIS (technical information service) is the name of the website (though it isn't the URL, that's techinfo.toyota.com). Clear as mud, I know.
