2008 Prius making loud noise-help
Discussion in 'Gen 2 Prius Technical Discussion' started by SSantra, May 6, 2025 at 10:44 AM.
  1. SSantra
    SSantra Junior Member
    NC
    Hello all
    I have 2008 Prius 200K+Miles.
    My Prius making loud noise when I turn on the AC. It mostly happening when the Car is slowing down or standing in traffic or parking. I am unable to diagnose due to the loud noise which will disturb neighbors . I have already changed the blower motor. Car is cooling when AC is on. Noise is on/off that mean it comes and goes every few seconds and it is very loud.
  2. MAX2
    MAX2 Senior Member
    1,390
    449
    101
    Third planet from the Sun
    It is possible that the noise comes from the fans on the car radiator. When the coolant temperature is high and the radiator is clogged, they turn on more often. Have you checked the temperature when they turn on?
    SSantra likes this.
  3. Tombukt2
    11,594
    2,047
    You should be able to know very quickly with your ears and your eyes if that noise is coming from that electric compressor with the orange cable going to it which you can put your hand on while it's running and nothing can hurt you there's no belt to rip your hand off or anything that's on the alternator a bit of ways from the air conditioning compressor you could unplug the fans for a second and see if the noise magically goes away the fan noise is going to sound like a lot of cards stuck in the spokes of bicycles usually the compressor noise if that's what it is is going to be a lot more whiny and squealy type of noise as there's nothing driving the compressor except an inverter inside of that big hunk of aluminum there's no belt there's nothing externally spinning usually these compressors don't make a lot of racket when they go out they just literally smoke and that's pretty much it they usually wind themselves out to death trying to spend or pump nothing. Sounds to me like something else maybe making the noise record a sound bite on YouTube and put it up wherever you post those kinds of things somebody will be able to tell you within seconds probably
    SSantra likes this.
  4. ChapmanF
    16,977
    If you spin the fans by hand (with the car off! and cooled down), do they make an unusual noise?
    Has a prankster taped a playing card to them?
    SSantra likes this.
  5. SSantra
    NC
    Thanks all for your response.
    I am unable to upload link of the video due to eligibility
    Yesterday, Time 6.30PM after 30 min drive without AC and window open, Climate control set - 73 Degree F, Fan speed Medium,
    I touched the low line and found that the line is little hot, Inside the car cold air flowing though. At this time, the sound was bearable. But
    It become very very loud depending on the outside weather, time of the day, climate control settings.
  6. MAX2
    MAX2 Senior Member
    1,390
    449
    101
    I guess the ace of spades.:)
  7. ChapmanF
    16,977
    If that's what it turns out to be, you'd better have an alibi.
  8. Tombukt2
    11,594
    2,047
    The low line is the fat silver line That's supposed to be cold when the compressors running no matter what's happening inside the car if the air conditioning is on or the defroster is on or what have you that fat silver line that runs in between the engine and the transmission with the gray cap that says l on it I think that's your suction or low pressure side that's the side that gets cold the little skinny line way over there where the sight glass is that's the one that's bringing the heat out of the car that's going to be warm hot so if you're fat silver line is warm or body temperature or anything like that you're about 80° too hot so it sounds like your air conditioning compressor should not even be coming alive when you push the button with the yellow line above it you shouldn't even hear it spin up would seem to me and if it is I wouldn't run it like that because you're inverter is going to try and run into Oblivion 8,000 RPMs trying to pump nothing you don't want to be that guy you want to be pumping something gas refrigerant gas to be exact.
    SSantra likes this.
  9. SSantra
    NC
    So compressor is already gone? I have checked the LOW line (L written on the cap, I know this line because few years back I filled with new Freon). I hear the sound after opening the hood, but not sure the exact location, it is more like coming right side of the engine bay.
  10. SSantra
    NC
    Will check
  11. SSantra
    NC
    Sorry did not get it
  12. ChapmanF
    16,977
    There's only a 1 in 52 chance that MAX2 would correctly guess which playing card if MAX2 wasn't the prankster who put it there.
  13. Tombukt2
    11,594
    2,047
    Standing in front of the car the right side of the engine bay would be the driver side headlight the air conditioning compressor is over where the passenger side headlight is and way down at the bottom of the engine so that's at the opposite side of the car kind of doubting that noise is coming from your air conditioning that's low on Freon it shouldn't even be coming on the fans might come on but the compressor probably doesn't it's a safety feature.
