Please tell me, what should the ECU data flow and EGR be like?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by wukong sun, May 7, 2025.
  1. wukong sun
    wukong sun Junior Member
    65
    Does this mean the EGR valve is stuck?
    Idle, maintenance mode, let the water temperature rise, the cooling fan starts running, and the EGR data does not change
  2. wukong sun
    65
    What is your normal data?
  3. wukong sun
    65
    EGR Valve Position/Duty Cycle:
    At idle and low load: The EGR valve is normally partially open, allowing a small amount of exhaust gas to recirculate into the intake manifold to lower combustion temperatures and reduce the production of nitrogen oxides (NOx). You may see a non-zero percentage or a value indicating that the valve is partially open.
    At high load and acceleration: The EGR valve is normally closed. At this time, as much fresh air as possible needs to enter the engine for maximum power output. You may see a duty cycle close to 0% or a value indicating that the valve is closed.
    When cruising: The EGR valve may open moderately depending on engine load and speed.
    When accelerating hard or at full throttle: The EGR valve should be fully closed.
    For the 2014 Toyota Prius, here are a few things to keep in mind:
    The hybrid system in the Prius may have a specific control strategy for the operation of the EGR system.
    Carbon deposits are a common problem in the Prius EGR system, especially at higher mileage. Carbon deposits can cause the EGR valve to stick or the EGR passage to become clogged, which can cause EGR_ERR related fault codes.
    When you see EGR_ERR, it usually means that a diagnostic is needed to determine the specific cause of the problem. Diagnostics may include:
    Reading Trouble Codes (DTCs): An OBD-II scanner can provide more specific fault codes to help narrow down the problem.
    Common EGR related fault codes include
    P0401 (not enough EGR flow),
    P0402 (too much EGR flow),
    P0403 (EGR circuit fault), etc.
    Check the EGR valve: Check if the valve is sticking and if it can move smoothly.
    Check the EGR passage: Check if there is any blockage due to carbon deposits.
    #3 wukong sun, May 7, 2025
  4. Tombukt2
    11,992
    2,119
    You can see the flow in HG in Toyoda software.
  5. Brian1954
    Brian1954 Senior Member
    1,698
    663
    South Central PA, USA
    Where did you get the information from that you wrote in your post?
    At idle, the EGR is fully closed on the Prius.
    MAX2 likes this.
  6. wukong sun
    65
    I only have a small OBD device.
  7. wukong sun
    65
    This is what I found on Google. I don't know what the value should be, so I'm posting this to ask for advice.
  8. Brian1954
    1,698
    663
    The information that you found on Google is not correct.
    If you are looking at live data for the EGR valve when the engine is idling, you will not see any change in the data because the EGR stays closed at idle.
    What are you trying to do with the EGR?
    wukong sun likes this.
  9. Tombukt2
    11,992
    2,119
    You'll get that taken care of at some point
  10. wukong sun
    65
    EGR_ERR: This data is the difference between the expected EGR and the actual EGR
  11. Brian1954
    1,698
    663
    I have no idea what your scan tool is showing for the EGR data. Maybe someone else can help you.
  12. ChapmanF
    17,174
    That scan tool seems not to even know what kind of a car it is talking to. A gen 3 Prius does not report EGR information in that way.
    Perhaps there is some way to get that tool to show the result of the mode 6 noncontinuous monitor (module ID 0x31 test ID 0xBD) that the Prius uses. It should look like examples you see in this thread.
  13. Mendel Leisk
    40,454
    You’ve got 3 threads going now, essentially the same topic. You’ve got a recently acquired 3rd gen, it’s got over 200k miles:
    Help Engine shaking and abnormal noise are not EGR problems | PriusChat
    Next post you disclose code P0301.
    I’d start checking for head gasket failure, and cleaning EGR system, in that order. More info in my signature (on a phone turn it landscape to see signatures).
    Brian1954 likes this.
  14. Brian1954
    1,698
    663
    The scan tool that he is using is a very basic, generic, inexpensive one that I did an online search to get some information about. I could not find who the manufacturer is. It is a generic scanner made in China.
  15. MAX2
    MAX2 Senior Member
    1,436
    481
    101
    Third planet from the Sun
    All universal scanners are made in China.
    Brian1954 and wukong sun like this.
  16. Tombukt2
    11,992
    2,119
    Universally bi-directional capability and all of that fancy stuff has not fully taken hold and the scanner market yet so therefore you still have these cheap glorified reader only can do nothing else type of devices that are like 20 to $34 or something you just want to get a cut above that to like an ap200 there are other things like the ap200 now I don't have all the names that can bleed the brakes and set the linear valve offset this is not rocket science I think before years ago this is the kind of stuff that you were stuck into subscriptions to be able to make happen or you worked at the dealership and had their equipment now we've zoomed past that most of this software is pretty much free it just has to be harvested and exploited I'm not buying that Toyota or Chevrolet does anything too fancy with their software once it gets out in the wild it's just out there who cares apparently they do a little bit or something because they keep making nonsensical changes to the nothingness. Just to keep people buying which is predominantly shops people that are going to work on up to four or five year old junk all the stuff that's failing they need that to make their money thank God I don't.
  17. ChapmanF
    17,174
    Lots and lots of scan tools, even cheap ones, should be able to do Mode 6 queries, which is a standard OBD-II thing.
    The one the OP is using seems to be more wackadoodle than most.
  18. Tombukt2
    11,992
    2,119
    Yes even my Iinova 3100 we'll get some basic freeze frame data usually not hella useful but it does do it and it reads codes that it can identify puts them on the screen but doesn't know anything about it just has the number but I would expect that. But now we're so far past that put another $25 with the money you're spending and you can bleed the brakes and set the linear valve and a few other things for like 68 bucks I mean you got to be kidding a lot of these things I think people find in the trunk and Dad's old toolbox and stuff like that
  19. wukong sun
    65
    I ordered a VCI obd cable.
    Now I can only wait. Let's take a brief look at the data that can be seen with this simple OBD.
    The data is meaningful.
    For example, vacuum has a reasonable fluctuation range.
    For example, EGR shows a deviation of 100%.
    This is the basis. More advanced software will make a comprehensive assessment and then tell you if it passes.
  20. Brian1954
    1,698
    663
    The data that your scanner is showing about the EGR valve is not meaningful.
    I will ask again. What are you trying to do with the EGR valve?
    If you just want to see if it opens, take a look at post #12.
    If you want to check if the EGR valve is not closed and it is causing the engine to run rough at idle, then remove one of the two screws on the pipe downstream of the valve. Insert a putty knife to block any possible flow. If you search on YouTube, you will find a video about this.
