Noise from transmission area
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Colton Nelson, May 9, 2025 at 8:05 AM.
  1. Colton Nelson
    Colton Nelson Junior Member
    Southaven
    2013 Prius v wagon
    Any ideas if this is low trans fluid or something else?
  2. Mendel Leisk
    40,272
    I “think” this pic is at driver’s side, front wheel well, wheel and plastic liner removed, looking in horizontally?
  3. Colton Nelson
    Southaven
    2013 Prius v wagon
    There is a rattle when start it.
  4. Tombukt2
    11,631
    2,059
    Yeah you don't need to be looking down there you're not looking at anything that needs to be seen that's just the side or the end of your transmission nothing's happening there stand up and look right in between the engine and the transmission put your hand in there if you like there's nothing moving you'll just feel vibration what's your feeling is an imbalance between the engine and the torque plate and more than likely the torque plate springs are slamming completely compressed and that's the rattling that you're hearing I do believe it's pretty common in this system it's a bunch of cow dung you can spend a whole bunch of money to keep the car if it's really nice but if it's got regular generation 3 problems probably not a thing to be doing but that's a personal choice I can't help you with.
  5. Mendel Leisk
    40,272
    Any follow up on this?
    Brian1954 and Tombukt2 like this.
  6. Colton Nelson
    Southaven
    2013 Prius v wagon
    How does something like that happen with an imbalance and torque springs slamming when compressed?
  7. Brian1954
    Brian1954 Senior Member
    1,605
    620
    South Central PA, USA
    Is this the same car that had the bad head gasket that Medal linked to in post #5?
    If it is the same car, did you replace the head gasket or replace the engine?
  8. Colton Nelson
    Southaven
    2013 Prius v wagon
    Same car, and haven't changed head gasket, that's what I was about to do. Torque Converter could be bad. If so I may just take the whole engine out.
  9. Brian1954
    1,605
    620
    There is no torque converter in a Prius. What you do have is a damper between the engine and the transaxle. The damper springs could be damaged on your damper due to continued usage of the car when you have a bad head gasket.
  10. ChapmanF
    17,008
    or continued usage with misfiring going on, whatever the cause
  11. Tombukt2
    11,631
    2,059
    And if you keep on it will throw a rod so how long have you been driving with this condition going on and if you could take a guess how many hours do you think the engine has run rattling ours didn't make 4 hours maybe total over quite some time and this is trying to think about this properly and make an accurate estimate is by no mean scientific so your engine is shaking itself to death every time it rattles it is putting a pretty good load on connecting rods and things internally so if this has been going on for some time don't even waste time with the head gasket business pull the engine out of the car flip it over bust it apart take a look inside if not find a replacement engine which is tricky just because of the popularity and it's in America everything you're going to find in the state is going to have over 100,000 miles on it almost guaranteed so there's always that I don't know how a new engine assembly would go block and head from who Toyota itself I can't even imagine five grand who knows certainly wouldn't seem to be worth it for the car's base value but that's in the eye of the beholder I guess
  12. Colton Nelson
    Southaven
    2013 Prius v wagon
    Damage from continous use of a bad head gasket is likely, and not recommended. The engine sounds the same, except the rattling from what is apparently the dampener. My biggest fear would have been a hole busting out of the engine block from a piston seizing. If it had busted a hole I wouldn't have even been able to hear my engine.
    Fortunately, it's the dampener. What would really suck is replacing the head gasket only to have the dampener then go out too, after digging into the belly of the beast and stiching Frankenstein back together.
    And further more, I never considered checking the transmission fluid bc there is no reservoir on the topside, it's likely it's never been changed in the last 12 years. But it will be.
    I am able to shift gears so I suspect there is no damage to the transmission. My earlier posts did indicate a head gasket repair was needed, however, I did have loss of rpm while driving and I lumped that in with head gasket failure. Apparently. The loss of rpm was more due to a failing dampener.
    I have driven the prius for nearly 5 months with a bad head gasket, lol.
  13. Brian1954
    1,605
    620
    Engine replacement time or a different car time.
  14. ChapmanF
    17,008
    A first for a Prius! When did that start happening?
  15. MAX2
    MAX2 Senior Member
    1,423
    465
    101
    Third planet from the Sun
    Some drivers know little about the planetary gear and think that they mechanically change gears by moving the joystick handle with the letters D, B, R and if the joystick moves, then "Oh! I can still change gear!"
