The dreaded P0401
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CollinTurley, May 14, 2025.
  1. CollinTurley
    CollinTurley New Member
    Flagstaff, AZ
    I recently bought a used 2012 Prius and everything was working great until the EGR code went off, I talked with the last owner and the car has recently had the EGR replaced, and a little bit before that the intake manifold. I opened up everything in the car today and the intake and EGR were really quite clean, there was some buildup on the intake valves to the engine and cleaned those up some but I am still mystified why the error code and check engine light is still happening. Is there something else that could cause the code? Maybe a sensor that could be bad? I'm relatively new to working on cars and very new to Prius so any help would be great.
  2. CollinTurley
    Flagstaff, AZ
    I'm getting the code for the EGR valve and replacing hybrid battery pack as permanent codes, does this mean they are actual issues? Or are these more of the things to look out for since it's a Gen 3 Prius? Both the EGR valve, intake manifold, and hybrid battery have been replaced so I'm not sure what to make of this.
  3. Brian1954
    Brian1954 Senior Member
    2,137
    828
    South Central PA, USA
    Code P0401 description is "Exhaust Gas Recirculation Flow Insufficient Detected". The code does not mean the EGR valve is bad. This means that there is not enough flow through the EGR system when the ECU opens the EGR valve and does a test of the system.
    When you inspected the EGR system, did you have the cooler removed and use a flashlight to look through the cooler to see how clean or dirty it is?
    Edit: I just read post #2 again. Are you saying that the P0401 code is a permanent code and that it is not a current code? If it was only a permanent code, then the check engine light would not be on OR you have other current codes that your scanner is not detecting. What scanner are you using?
    #3 Brian1954, May 15, 2025
  4. CollinTurley
    Flagstaff, AZ
    Its appeared as both a permanent and current code now, I'm using just a cheap Walmart scanner cause that's what I can afford, I didn't specifically look into the EGR cooler because that was replaced with the valve, it's still shiny and new looking. Today I'm going to try to clean the intake on the engine more so I'm hoping that will fix it.
  5. Mendel Leisk
    41,301
    What's the miles.
    Wondering the same.
  6. CollinTurley
    Flagstaff, AZ
    It's a high mileage car it's at 322876 right now.
  7. Brian1954
    2,137
    828
    Are you sure the previous owner of the car had the cooler replaced? Maybe only the valve was replaced. You need to remove the cooler and check to see how clean/dirty the inside is.
  8. CollinTurley
    Flagstaff, AZ
    I removed the cooler, cleaned it out as best as I could, it was more clogged than I thought, I need to do more cleaning because you still can't see through half the holes, I had to reinstall it so I could drive where I needed to the next day, when I start the engine now there's a knock and the engine pulses, is this still the EGR cooler? I haven't messed with anything else so I assume it is but I don't know for sure
