Car totaled by hail. Keep or relinquish?
Discussion in 'Gen 3 Prius Main Forum' started by Grandfield, May 14, 2025.
  1. rjparker
    9,486
    5,810
    You should take it to a Paintless Dent Removal (PDR) shop and see what they would charge. Ask for the non-insurance price.
    I once had a hail damaged car that was totaled because the cost to fix at a conventional body shop was well over $7k. PDR guy did it in 3 days for $2k.
    #21 rjparker, May 15, 2025
    Brian1954 and Grandfield like this.
  2. Mendel Leisk
    40,457
    You're likely on the cusp of head gasket failure, maybe best to fold.
    Unless the EGR system is fully cleaned, at least every 50k, head gaskets tend to fail, around 150k typically.
    Grandfield likes this.
  3. frodoz737
    frodoz737 Top Wrench
    4,503
    2,426
    33
    With $7,000 you can buy a new car "payment" or...keep driving your current as-is "beater" for $7,000 minus the buy-back. The GEN III's are not bad cars, but they just require maintenance...something a lot of Prius owners think "should-not-be". Either option, you "will be" buying a new or replacement car...now or in a year or two. Consider this...will you have $7,000 to put down on a replacement later? That's the decision you have to make. I can't speak your to financials, age or current status in life, but you did state you can't fix cars.
    Best wishes whatever you decide.
  4. bbrages
    bbrages Member
    162
    47
    St. Louis
    The $7000 is irrelevant, OP gets it either way. Only question is if the car is worth $1400 as-is. Since you can't buy much for $1400, I say yes.
    None of us really know what the average mileage for HG failure is. We don't even know why it happens.
  5. ASRDogman
    ASRDogman Senior Member
    7,109
    3,713
    If all you have is a few dents, why would it degrees the value? Does it still run and drive the same?
    And it's dependable? WHY would you get rid of it? Why have another car payment? And higher insurance rates?
    If you're really worried about the dents, take it to a body shop, they can likely pop them out.
    And you have $5600! Minus whatever it costs to pop those dents out.
    And you can save that money toward the head gasket kit!
  6. ETC(SS)
    6,903
    Concur.
    The 'totaled' car is worth $1400 just in parts.
    The tyres and rims probably didn't get damaged by the hail and my guess is that the battery is still as good as it was before the storm.
    If nothing else, the op can put a "for sale" sign on it as-is, where is and get $2000 in a flash since the car is able to move under its own power.
    That's a $600 profit for the price of a Sharpie and a hunk of cardboard.
    No brainer, actually.
    Don't really concur with that. ;)
    The G3 head gasket failures are due in about equal parts to design failures in Aichi, Japan and the fact that many people who drive Priuses follow a 'closed hood' maintenance philosophy - which is expressly encouraged by the dealers.
    If your car is "dealer serviced" this is NOT the same thing as being 'properly maintained' UNLESS of course you take the car to the dealership every 30 days or 1,000 miles in Freedom units.
    About 1600 clicks elsewhere.
    Deets are in the Warranty and Maintenance Guide that came with the car and (unusually, for Toyota) are available for free as a download.
    Head Gaskets are like fuses.
    If they were like circuit breakers then you would not have to replace them. ;)
    They're designed to fail in order to protect something more costly - like the bottom end or heads.
    UNFORTUNATELY it doesn't really work out that way in the real world where mechanics can charge hundreds of dollars per hour of labour and you can barely see the engine when you open the car's hood.
    Long oil change intervals = dirtier oil.
    Low friction rings = more oil blow-by = a smaller volume of even dirtier oil - not detectable until the "change owner" light starts to flicker.
    Low sump volume = more of the same.
    Add in an EGR cooler and you can just about predict that you will hear the famous "Prius Death Rattle" before 160,000 miles.
    I had 2 2010 Company Priuses that each went beyond 220,000 miles JUST BY changing the OCI to 5,000 miles instead of 10K.
    One got taken out in an accident before 250k and the other one was destroyed by an ID10T tech who never checked the oil level......at 260K.
  7. ASRDogman
    7,109
    3,713
    I only went 301,000 before the head gasket failed.... What do I know???
    City drivers seem to have head gasket failure sooner than highway drivers....
    At least according to what drivers have stated mileage wise when they failed, on prius chat.
    Under 175,000 for mostly city drivers, and well over 225,000 for highway drivers.
    So you can predict when a head gasket could fail, at least roughly.
  8. ASRDogman
    7,109
    3,713
    I would take the car in a heart beat, if you were closer....
  9. DC2010
    DC2010 New Member
    Bufflalo NY
    Assuming no glass damage, how many dents? I’ve had all my cars in for paintless dent/ding removal. The result is great and for a reasonable number of them, not that costly. I had a Lexus with over a thousand hail dings. All fixed for $1500 and can’t tell. So if it’s just a couple dozen, maybe see what it would cost. If you like the car and $700 or so fixes it, why not?
    Grandfield, ETC(SS) and ASRDogman like this.
  10. Mendel Leisk
    40,457
    You knew the EGR needed cleaning.
  11. BlizzMPG
    BlizzMPG Junior Member
    I feel like a picture of the dents would add a lot of value to this thread
    Grandfield, ETC(SS) and Mendel Leisk like this.
  12. rjparker
    9,486
    5,810
    I think anybody that gets 300k on one of these engines is doing preventative measures that are demonstrated to work.
    #32 rjparker, May 16, 2025
  13. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    Usually totaled is when repair costs are beyond the cost of total car value of kbb. There must be holes blown thru the hood and rooftop along with wind shield and back window shattered. Unless car had half a million miles with kbb value of $200 I’m poor condition.
  14. ETC(SS)
    6,903
    ^ Not necessarily.....
    The OP said something to the effect that the damage didn't seem to be all that bad.
    And there's a decent bet that the glass is intact.
    Unlike most car OWNERS, insurance companies are usually pretty good at math.
    That's why they have to dump excess cash into football stadium naming rights and goofy commercials.
    Insurance companies will total out a car when the repair costs reach a percentage of the car's actual loan value, which is a pretty good number to use because as it turns out..........bankers are pretty good at math too. ;)
    The OP lives in cheese-head country - so let's play the percentages and say she or he didn't want to admit to living in the city.
    That puts this particular G3's value at around $4500, more or less.
    More behind the tinsel curtain.
    Less in red-dirt country.
    Un-dimpling the roof, hood, and deck might actually BE roughly 60% of the car's street value - or whatever the math nerds (soon to be AI) say is the 'right number' for an elderly Prius.
    Also the car might be the OPs only insured vehicle.
    If they have claims in their file, then their underwriter just might want to get this particular customer off of their books.
    The tell of the tape here will be if they renew the customer for liability in the car after they pay off the hail claim.
    The OP has an opportunity to drive an ugly car for a few years....maybe a LOT of years, and save up for a decent car payment - which is a 100% down payment on a decent car!
    My advice:
    Do that!
    #34 ETC(SS), May 17, 2025
    bettergolf likes this.
  15. bbrages
    bbrages Member
    162
    47
    St. Louis
    Body work is expensive. My son's second gen was totaled by hail. Just a cracked windshield (I think it was actually already cracked!) and dents all over. He kept the car and is still driving it, similar situation to the OP.
  16. frodoz737
    4,503
    2,426
    33
    @Grandfield The real question is...Do you want to replace your car now...or later? You are going to be spending money...either way.
    Good luck.
  17. Grandfield
    Grandfield New Member
    South Central Wisconsin
    No, the damage is so minor it won't even photograph properly. I was shocked.
  18. bisco
    51,011
    2010 prius, i'd replace it before you have a real problem
  19. bettergolf
    bettergolf Active Member
    473
    358
    Sanford NC
    It's a free car now...drive it till it drops.
  20. Mendel Leisk
    40,457
    Crazy.
