2010 Prius II 155k - what to watch for or unload now?
Discussion in 'Gen 3 Prius Main Forum' started by DC2010, May 4, 2025.
  1. DC2010
    DC2010 New Member
    Bufflalo NY
    I’ve read some of the posts on this topic but am wondering if I should unload it while mechanically good. 155k miles and has been the best car for reliability ever. In 15 plus years, fixed A/C and a rear brake line. Body is mostly very good, couple small dings and minimal rust. What’s it realistically worth?
    By winter, I’ll need the next set of brakes and tires, 12v battery etc. It passes inspection ok. If anything breaks, it’ll add a couple thousand. So it’s conceivable that I’ll dump 5k into it within a year.
    Should I be afraid of it? Too old to do my own work so everything is long price. What if I could get $5k for it, plus $4k off a used later year Prime and get a much newer car for a net $10k?
    if anything major breaks, afraid it’ll be a boat anchor. Right now, best car ever.
    Grandfield likes this.
  2. PriusCamper
    PriusCamper Senior Member
    11,880
    4,820
    Pacific Northwest, USA
    Out here on the West Coast people are still getting $10K or higher for 2010 in your condition... If you wanted to take a vacation out here, the extra money you'd make selling it would more than pay for the trip. Of course that's assuming you've done everything possible to prevent corrosion from salt on the roads.
  3. bisco
    50,860
    you're at a high risk point. have you ever cleaned the egr circuit?
    potential failures: head gasket $2-8,000., brake actuator $3-4,000., battery $3-4,000.
    here's one for sale here:2010-toyota-prius-iii.255060
    Grandfield and Brian1954 like this.
  4. PriusCamper
    11,880
    4,820
    As someone who consistently gets more than a decade out of every car I own, it pains me to have to agree with you. I'd disagree if it was Gen2 Prius or a Gen4 Prius, but not a Gen3.
  5. bisco
    50,860
    or even if one can diy these things
  6. PriusCamper
    11,880
    4,820
    This guy in Oklahoma is rebuilding Gen3 engines and getting way more power and reliability out of them and if I ever find a good price on a Gen3 I'll put one of his engines in becuase his prices are super affordable: https://www.instagram.com/skimmilkhybrid/
    But in OPs case, being older and no longer doing DIY, that would be more trouble than selling before putting more money into it.
    Grandfield and bisco like this.
  7. Brian1954
    Brian1954 Senior Member
    1,638
    636
    South Central PA, USA
    Since you live in the Rust-belt, 15 years is all that you can expect from any car. Sell it as fast as you can before something else goes wrong with it.
    Grandfield and PriusCamper like this.
  8. Grit
    Grit Senior Member
    6,384
    4,170
    Wilkes Land
    Best car ever, until something costly breaks and needs to be repair. That can be applied to a home, job & etc. I say keep it since the history of maintenance is unknown
    Grandfield and MAX2 like this.
  9. DC2010
    DC2010 New Member
    Bufflalo NY
    Got me scared about egr now. All maintenance was done at dealer, oil every 5k, plugs at 120k, fluids etc. Runs like new so maybe mine is one that’ll go another year. 8k miles per year. Simple test for egr about to cause issues? Saw something about an obd scan. Passes inspection every year.
  10. bettergolf
    bettergolf Active Member
    468
    355
    Sanford NC
    That's what they're here for!
  11. bisco
    50,860
    i think there is a tech stream egr test. you might need a baseline though, i'm not sure.
  12. Mendel Leisk
    40,287
    Easy: if the odometer reads over 100k miles, and the EGR has never been cleaned, it'll need it. By your miles, it'll really need it.
    Considering you're in the rust-belt, and a good chance the head gasket is just about to let go, I'd sell.
    Grandfield and BlizzMPG like this.
  13. Grit
    Grit Senior Member
    6,384
    4,170
    Wilkes Land
    Egr pipe can be taken off easily, check the interior pipe for the layer build up. If it’s got a good thick layer then your egr circuit is most likely layered up throughout.
    Mendel Leisk, MAX2 and ASRDogman like this.
  14. DC2010
    DC2010 New Member
    Bufflalo NY
    Ok I’m definitely getting spooked about keeping this. Although running great, I’ll need tires and brakes, never know when another $2k brake line, 12v battery and the $1000 for the egr stuff. Keeps passing inspection but not sure how long struts last. I guess 5k worth of fixes would keep it going a couple years but it lacks new safety features and decent headlights.
    So next question….since my wife loves her Prius, what year Prius would be a good one to upgrade to under $20k? At some point they changed the battery technology so not sure newer is better. Plug in can get me a rebate but it’s not a huge gas saver with that range.
    What are the golden years under $20k?
  15. bettergolf
    468
    355
    Sanford NC
    With the plug in, after the charge is used it becomes a regular hybrid so it still does very well on gas.
  16. BlizzMPG
    BlizzMPG Junior Member
    This was me just a few weeks back. Did the intake manifold full clean, PCV valve, and the EGR cooler full deep clean. EGR was the biggest pain but definitely doable. Watch a few videos (Nutsaboutbolts, Merve) to prepare you. If you have the tools, I would say go for it.
  17. Mendel Leisk
    40,287
    Mechanical issues aside, if there was only the hail damage, there's something inherently wrong, totalling a car for cosmetic reasons. Guess it's a case of whatyagoingtodo.
    Oh also, I keep thinking: was any glass damaged?
