No takers so far
Discussion in 'Gen 5 Prius Technical Discussion' started by Paul Gregory, May 16, 2025.
  1. Paul Gregory
    Paul Gregory Senior Member
    1,357
    355
    Alberta
    2024 Prius Prime
    XSE
    For the first few weeks I had the car, a dead 12V battery was almost a daily occurrence. I went through all the normal courses of action, and reached the conclusion that parasitic draw was highly variable and unpredictable. The best solution I found was a battery maintainer, plugged in every time I was parked near an outlet.
    The absurdity of this problem, which should escape no one, is that when the 12 V battery falls to about 11.5 volts, the car is disabled with a message, "battery too low" and your only recourse is a boost or a service call. This is absurd, considering the large amount of reserve power in the hybrid battery. Most people would not expect this.
  2. frodoz737
    frodoz737 Top Wrench
    4,502
    2,425
    33
    There is something wrong with your car or the 12VDC battery. You need to fix this.
    I had a 2006 car that I passed down to my Son as his first and started having battery problems with it. I took a good electrician at the dealership to find out it was the car's "factory" amp shorting the hot batt buss to ground.
    Mods don't fix broke.
  3. Paul Gregory
    1,357
    355
    Alberta
    2024 Prius Prime
    XSE
    I ruled that out the first week with the dealer, It tested well within factory specifications.
    No critical thinking skills or just poor reading comprehension?
  4. frodoz737
    4,502
    2,425
    33
    I know two guys at work with GEN 5s and they have no problem with theirs...and we are Mechanics that work on $50 million dollar aircraft for a living.
  5. frodoz737
    4,502
    2,425
    33
    Mods...it's duplicate posting again.
    #25 frodoz737, May 16, 2025
  6. Paul Gregory
    1,357
    355
    Alberta
    2024 Prius Prime
    XSE
    Yep, it's the critical thinking skills.
  7. frodoz737
    4,502
    2,425
    33
    ...and you wonder why you are getting negative returns? I wish you the best with your vehicle. I'm clear all actives. You have a nice day.
    #27 frodoz737, May 16, 2025
  8. Paul Gregory
    1,357
    355
    Alberta
    2024 Prius Prime
    XSE
    Excuse me for responding to your post, but it was dumb.
    I can't help you with that.
  9. Brian1954
    Brian1954 Senior Member
    1,698
    663
    South Central PA, USA
    Toyota will not be offering a retrofit like this for your 2024 car. It will not happen.
    If you want this incorporated in new Toyota models, you would be better off contacting Toyota directly with your idea. I do not think that anyone at Toyota Corporation is reading PriusChat looking for ideas for future models. Posting this idea in the forum is not very productive.
  10. frodoz737
    4,502
    2,425
    33
    Back at ya. Bye-bye.
  11. Paul Gregory
    1,357
    355
    Alberta
    2024 Prius Prime
    XSE
    Opinion noted.
    But not for much.
    Brian1954 likes this.
  12. Brian1954
    1,698
    663
    This is another one of your many threads and posts that you create because you seem to enjoy arguing with people and wasting people's time.
    I knew I should not have been suckered into posting in this thread. Shame on me. It will not happen again.
  13. frodoz737
    4,502
    2,425
    33
    Fred's House of Politics is where he wants to "play". This kind of behavior is encouraged there.
  14. Blackat
    Blackat Active Member
    398
    263
    Colorado
    2023 Prius
    Limited AWD-e
    LoL. “Getting attacked”
    This is one of the most polite car forums.
    On most other car forums you would be left whimpering in a corner.
    frodoz737, ETC(SS) and bisco like this.
  15. ETC(SS)
    6,903
    We have an 'ignore user' feature in this forum that works quite effectively.....
    I only use it against one person and only because this person is excessively profane and does not know how to use a computer very effectively.
    Concur.
    You have to ask permission to get into FHOP_P which risks not only a rejection of your request but also ACTUAL rebuttal of one's opinion which some feel is......an 'attack.'
  16. ChapmanF
    17,174
    I've seen it sometimes cause as many problems as it solves, because it works so effectively you don't see anything ever written by the member you've ignored ... including in other posts where people are replying to what that member wrote, and nothing shows that it's a reply to that person and it's easy for someone else to mistake for a reply to them.
    I rely more heavily on the 'ignore' feature provided in my brain.
  17. rjparker
    9,484
    5,804
    On one of your many threads where you asked for a solution, I gave you one. It was not a jump starter. You dismissed it and attacked.
  18. Paul Gregory
    1,357
    355
    Alberta
    2024 Prius Prime
    XSE
    Not only here; I have been called stupid for talking about this idea.
  19. bisco
    51,013
    elsewhere?
  20. Blackat
    398
    263
    Colorado
    2023 Prius
    Limited AWD-e
    No doubt
