Carpet holes
Discussion in 'Gen 2 Prius Main Forum' started by Has Raf, May 17, 2025.
  1. Has Raf
    Has Raf Member
    180
    43
    Stoke-on-Trent, England
    Does anyone know where I can get these rings for the floor carpet, or a part number? I’ve bought the hooks for the mat, but my floor carpet is missing the rings, it just has 2 holes. Thanks.
  2. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    It likely is not sold separately. You might just have to hunt around a hardware shop and try and find a fabric reinforcing ring (two-part press fit) that will fit the hole in the carpet.
  3. Has Raf
    Has Raf Member
    180
    43
    Thank you. I found some on Amazon, that I can screw together, so no need to access the carpet from both sides!
    sydney2008 and dolj like this.
  4. Tombukt2
    13,036
    2,336
    Yes and at Walmart mart they have the bang together like used on tarp edges so either way make sure the same or similar ID and OD you need for finished hole .
