Help Engine shaking and abnormal noise are not EGR problems
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by wukong sun, May 3, 2025.
Tags:
  1. wukong sun
    wukong sun Junior Member
    57
    No reduction in coolant
    The car does not shake when it is cold, but it will rattle once it starts charging the high voltage battery. Even if it is not charging, it will rattle when the engine temperature rises.
  2. wukong sun
    57
  3. rjparker
    9,364
    5,719
    If you asked me where you could get the most unreliable hybrid information from the least qualified people, I would say Autozone.
    Replacing 1, 2, 3 or 4 expensive coils would be a waste of money. You said you were replacing spark plugs; they do have a defined lifespan of 120,000 miles, Toyota allows 150,000 miles in some states and many use them longer.
    If you had one misfire the standard no cost test is to swap the coil or plug with a cylinder that is not recording a misfire. OEM coils rarely fail.
    The idea four coils would fail at the same time is ludicrous.
    I would certainly do the block egr flow test (again?) - if that clears it you have a sticking egr valve. It's hard to keep up with what you have done or not tried when your posts are spread out everywhere.
    The Autozone disclaimer in small print:
    "The information provided within this report is intended to supplement, not replace, regular automotive maintenance programs or advice by a qualified automotive technician. Neither AutoZone nor any of its subsidiaries or affiliates assume any liability for the completeness or correctness of either the report or its content. Always seek the advice of your personal mechanic, dealership, or an ASE Certified automotive technician prior to attempting any repairs to your vehicle.
    This is a free service offered by AutoZone to our customers and there are no fees or charges associated with this service... Based on the error codes retrieved..., a "most likely solution" is indicated."
    Video with egr block flow test
    #23 rjparker, May 19, 2025 at 7:16 PM
    Brian1954 and wukong sun like this.
  4. wukong sun
    57
    Ignition coil and spark plugs were replaced
    Injectors were all repositioned
    EGR system, valves, coolers, intake manifolds were cleaned
    Unplugged EGR and tested, no change
    Removed EGR valve solenoid
    Press manually and the engine speed will drop immediately
    It becomes rough. Press again, the engine is almost shut down
    Release hand and it will return to normal
    The fault still exists
    Only the circuit has not been checked
    Leaving overnight, cold start does not shake
    Battery level 2, it shakes when charging
    Shakes at 15-40 mph
    No shaking can be felt at 40-70 mph on highway
  5. rjparker
    9,364
    5,719
    egr block flow test?
  6. wukong sun
    57
    Unplugging the EGR power plug
    It's like using a shovel to block the EGR pipe
    There's already a post
    Many people unplug the EGR power
    I took down the entire electromagnetic part
    Manual test, smooth in and out
    EGR valve closed by default, normal idle
    Press it down to reduce the speed
    Press it again and the engine will almost shut down
    There are many roads to Rome
  7. rjparker
    9,364
    5,719
    No that is not true. Unplugging the egr power plug just leaves it in the position it was in. If the valve is sticking open it will continue to be sticking open. See the video above.
    Brian1954 likes this.
  8. wukong sun
    57
    I removed the electromagnetic part of the black housing of the EGR valve.
    Keep the power plug on the EGR.
    Press the valve manually, and it goes in and out smoothly.
    Start the engine in maintenance mode.
    The EGR valve is closed by default, and the idle speed is normal.
    Press the valve slightly, and the speed will decrease.
    Press the valve again, and the operation is rough.
    Press the valve again, and the engine is about to stall.
    Release your hand and it will return to normal.
  9. ChapmanF
    17,034
    While you have that electromagnetic part removed, which example here does it look like on the inside?
    (The difference is in the little "ski jump" part down inside. The one on the right has a rut worn through it.)
    #29 ChapmanF, May 20, 2025 at 9:18 AM
  10. ChapmanF
    17,034
    #30 ChapmanF, May 20, 2025 at 9:18 AM
  11. wukong sun
    57
    Maybe it's more like the one on the right. I just look at the glue. There's no difference in other aspects?
  12. wukong sun
    57
    The latest progress is to fix the ABS cable failure. My ABS failure often occurs on bumpy roads, and occasionally occurs on good roads. I replaced the ABS cable with a shield layer above the right front wheel to solve it.
  13. ChapmanF
    17,034
    If there is a rut through that stop, it's no good. The valve won't actuate accurately.
  14. Mendel Leisk
    40,308
    Too bad you can’t just replace that bucket.
    I had it in my hands last time around, but was mainly focused on cleaning. It’s cast metal, rotates in there due to surrounding electromagnetic field?
  15. ChapmanF
    17,034
    I've never figured it for cast metal. seems more like some sort of thermoplastic resin, but magnetized, so probably containing metal particles or something. Like those plasticky bendable fridge magnets.
    It's a stepper motor rotor. It has some number of magnetic poles (another poster said 12 pairs, I guess if you put some paper over it and scattered iron filings you could count them), and the stator has electromagnet windings magnetically linked to the metal fingers (48 of 'em?) you see inside the stator. Each time the ECM switches the magnetic field direction between the fingers, the rotor makes one little step around to align with the new fields.
