"Maintenance Required" screen frozen
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by victordejo, May 19, 2025 at 11:34 PM.
  1. victordejo
    victordejo New Member
    Monday
    I can not delete the "Maintenance Required" screen to reset the oil change. Is there any way to do it?
  2. ChapmanF
    17,044
    In my owners' manual those instructions are toward the back under a heading like "after changing the engine oil". Have you followed those steps, or tried to?
    Brian1954 and BiomedO1 like this.
  3. BiomedO1
    2,651
    1,419
    SacTown, Ca
    That's what happens when your ignore the "maintenance required" message during startup. It becomes a semi-permanent fixture about 500 - 1000 miles beyond it's due service. The first iteration of that lamp lights up 500 miles before it's actually due, to give you time to make an appointment for service.
    Hope this helps......
  4. victordejo
    Monday
    that's what happened and now I can't perform the oil change reset procedure because I can't change the odometer screen to trip A screen....my trip and display buttons are not functioning
    I can't follow those steps because the frozen screen doesn't let me change from odometer screen to trip A screen
    #4 victordejo, May 20, 2025 at 5:44 PM
  5. PosauneGuy
    PosauneGuy Member
    119
    89
    California, here I come...
    2025 Prius
    I would guess you need to replace the clock spring to get the trip/display button to work. (You could also try pressing the button as you turn the steering wheel.) Have you tried doing the other steps of the reset procedure, skipping the trip A step (i.e. press and hold the km/h button while pressing the start button, with foot off brake)?
    BiomedO1 likes this.
  6. Grit
    Grit Senior Member
    6,390
    4,174
    Wilkes Land
    Yank the 12v battery positive cable from the terminal?
  7. BiomedO1
    2,651
    1,419
    SacTown, Ca
    Last I checked, you need to be on the main odometer screen to reset it; NOT trip-A. I made that mistake with my old Prius C and spent an hour banging my head against the wall....
    Hope this helps...
  8. ChapmanF
    17,044
    In my 2010 gen 3 it's TRIP A.
    That's why I really suggested looking in the owners' manual, in case the details might be different between years or models.
    Danno5060 and BiomedO1 like this.
  9. BiomedO1
    2,651
    1,419
    SacTown, Ca
    Yep; that's what my manual stated too - but that didn't work. This DID... Made notes in my maintenance log and never had an issue since. Note: DO NOT RELEASE the trip button during the count-down; otherwise it won't clear. FWIW, mine was a 2012 Prius C. My current ge4 is way easier to reset.
  10. ChapmanF
    17,044
    Weird! In my car, TRIP A is what actually works.
  11. Danno5060
    Danno5060 Active Member
    337
    172
    Wyoming
    Trip A is what I use on my Gen 3.
