B1498 Communication Malfunction A/C Inverter Local
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Deep, Apr 27, 2017.
  1. Mongolian prius
    Mongolian prius New Member
    Yesterday
    Mongolian
    Hello. My 3rd Prius A/c pump is not working. I replaced the pump and it is the same. The high voltage fuse and the small black connector port inside the inverter are clean. What should I check now?
    #21 Mongolian prius, May 23, 2025 at 10:49 PM
  2. ChapmanF
    17,053
    You seem to be a new poster on this thread. Do you have the same trouble code mentioned in the title? Or, what trouble code(s) do you have? Have you followed any of the troubleshooting steps in the repair manual for the code(s) you have?
    Toyota Service Information and Where To Find It | PriusChat
    If you have, what results did you see?
