2010 Prius still shakes after head gasket job and EGR + intake cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by infinitepub, May 7, 2025.
  1. rjparker
    9,378
    5,724
    There is no direct egr step position status or feedback. But the egr step test uses the map pressure as a good indicator.
    A lot of this assumes your previous egr block test was successful. I would block the flow manually again and drive it 15 minutes in normal mode (not maintenance mode) and verify the engine runs good with a full warmup. If it does not continue to run smooth you have to reevaluate your focus.
    Egr step test with Techstream
    Run the egr step test procedure while watching the map pressure. The engine must be placed in maintenance mode to force continuous running. The procedure wants you to warm up the engine. You will see map pressures at idle changing as you command the egr open using Techstream.
    When the egr is closed at step 0, the map pressure usually reads about 4 psi absolute. As the egr step opens the psi will increase causing idle roughness around step 15-20.
    Later you should be able to watch the map pressure under normal conditions and significantly understand what the egr is doing. Remember, the egr should be closed at idle and low rpms. The egr valve is also closed at wide open throttle.
    #41 rjparker, May 24, 2025 at 12:51 AM
    Brian1954 likes this.
  2. rjparker
    9,378
    5,724
    You can check the power and wiring continuity with a meter.
  3. ChapmanF
    17,053
    I'm not sure about using MAP under normal conditions for info on what EGR is doing, because under normal conditions the MAP is so strongly affected by throttle position and engine load that the effect of EGR will be hard to tease out.
    The car does a self-test of its own for EGR, where it uses the MAP reading, but only at moments when the car is decelerating, the throttle is closed, and the engine is spinning without fuel. Under those specific conditions, it is able to interpret the MAP reading as a test for EGR.
    The result from the last time the car ran that self-test can be viewed on any scan tool that can show "mode 6" results.
