Prius 2014 with VERY low mileage, dealer wants to do maintenance...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DNAgent, Jun 5, 2025.
  1. DNAgent
    DNAgent Junior Member
    New Orleans, LA
    Hi everyone,
    I haven't posted here in a very long time, still a newbie, so go easy on me...
    I'm obviously past the 10 year mark with my 2014, but have extremely low mileage... I just don't drive much. How low are we talking? About 12K (!).
    Dealer is saying they want to do the following (prices in parentheses):
    Inverter coolant flush ($215)
    Engine coolant flush ($215)
    CVT transmission oil ($305)
    Tune-up ($324)
    Oil change ($65)
    ... does it really need all this? My understanding from reading the manuals is that the inverter coolant replacement isn't needed until the 15 year mark.
    They also want $175 for a diagnostic on a problem with the master door switch, which I'm pretty sure is a very simple problem and I could replace myself.
    I am NOT up for doing coolant/oil replacements, I'm fine with letting them do these (if they're really needed), but... these prices seem steep - and depending on how much of this it really needs, I'm wondering if it makes more sense to do a trade-in.
    What say you all?
  2. Tombukt2
    13,004
    2,330
    All that can be done for much less gonna be needing to clean EGR system soon I'm sure. Or else . Not keepers especially not driven.
  3. rjparker
    10,161
    6,316
    Find an independent shop with good references and ask how much to do everything with Toyota parts and fluids.
    The coolant changes are drain and fill which is easy on a gen3 especially when done with an oil change.
    The parts for everything is about $250. The spark plugs take some time because the wiper assembly has to be removed. Still $300 of labor might get it done saving half.
    Any mechanic doing the egr cooler and valve is going to charge $700 or more. Not worth it with 12k on the odo.
  4. DNAgent
    New Orleans, LA
    Hmmm. They didn't mention anything to me about EGR cleaning or replacing spark plugs...
    Would you all recommend just doing the trade-in?
  5. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Go to kelly blue book website to get an estimate value of your car. Then use the price if it’s worth maintaining or trade it in to a dealer or private sale. Id go with private sale as is because the hv bat could be on it way out with super low miles.
  6. DNAgent
    New Orleans, LA
    Kelley Blue Book estimated it as about $11K... I'm sure the dealer would offer a lot less, but I don't know that I feel like dealing with a private sale.
  7. rjparker
    10,161
    6,316
    The tune up is changing spark plugs.
    Trade in? Yes if you can afford $700-$900 a month for four or five years. If that's not difficult every month then go for it.
    Of course one month payment takes care of the current maintenance.
    I suggested not doing egr which was brought up earlier.
    Private sale will probably net you $4k-$5k more than the real trade in value a dealer gives you. Dealers won't keep a 11-12 year old car and will send it to the wholesale auction. The dealer knows the value they will get is maybe 60% full retail. They might make you think you are within $2k of Blue Book but will not discount your new car much or give you higher interest rates than your credit warrants.
    It is an easy way to trade, so if you are flush then no big deal.
    I have private sold my cars for more than 25 years. When you have a desirable car in great condition and very low miles, it is really easy. You know the value and allow $500 negotiation and that's it.
    No personal checks or cash. You meet them at their bank and get a cashiers check you verify immediately. You have a Bill of Sale ready to go with full ids exchanged and noted. You also get copies of their drivers license and insurance card and fill out a notification of sale to the state.
    #7 rjparker, Jun 6, 2025
  8. Danno5060
    Danno5060 Active Member
    388
    200
    Wyoming
    Some of those fluids also have a time interval, but all of those prices, except the oil change seem very high to me. Changing these fluids yourself isn't really that hard, but there are areas where it's harder to find someplace to take the old fluids. Around me, the landfill has a hazardous waste disposal area and will take all of those for free.
    With only 12K miles, I would think you can go another decade without having to service the EGR.
    Changing the coolant takes a bit over a gallon per system (it's the same stuff), so three gallons at about $25 per gallon instead of the $430 is a no-brainer for me. I'm not sure you'd have to do the inverter coolant as it isn't exposed to as hostile an environment, but maybe changing the engine coolant wouldn't be out of the question.
    The eCVT fluid is about $12 per quart, and you'll need 4 quarts for that as well as a couple crush washers. It's a pain getting the new fluid into the fill hole, but the hardware store sells tubing by the foot and funnels. That lets you thread the tube down from the top and into the fill hole. After doing that job a couple times (my Gen 2 and my Gen 3), it's also a no-brainer for me. With only 12K though, I don't think you'll need to really change that fluid for another decade.
    The tune up really shouldn't be that necessary, maybe add some injector cleaner to a full tank of gas and actually drive the thing until you use up a couple tanks of gas. Unless you're misfiring, I wouldn't change the ignition coils or plugs. Check the cabin and engine air filters. These probably need to be replaced.
    Unless you've left it out in the sun and there's been some serious hail in your area, or you've let the car sit for long periods of time without driving it at all, you'll never get what this car is worth because of the way used cars are priced. There is something to how a car might degrade with time, even if it doesn't have the miles. The traction battery needs to be charged from time to time, and if the car sat for long periods of time without use, there will be a certain amount of degradation. Depending on the type of gas that's been stored in the tank, there's a possibility that it could have broken down some.
    If you want to get rid of the car, take your time to sell it and don't trade it in. It will be like giving it away. I wouldn't do that if I were you, but I know from personal experience selling a used car can be a pain in the nice person. Make someone pay you for the low miles. At least find a college student, young person just starting out in ther lives within your family to sell the car to for what the dealer would give you in trade. Maybe put it on a schedule to drive it 50-100 miles at least once every other month.
  9. Leadfoot J. McCoalroller
    8,092
    7,574
    Pennsylvania
    2018 Prius c
    I say get an independent to do the coolant flushes and an oil change. Those are worth doing now.
    Skip the spark plugs and transmission oil for now.
    Overall the Prius doesn't age terribly well, regardless of the miles you (don't) put on it.
    The economics underpinning the price of any used car tends to break down at age 15 because banks won't write used auto loans on cars that old. That's when the prices you can get really fall down, regardless of condition. So even if you keep it for now, it's time to make a plan.
    If you're comfortable with buying another car now, go for it. The economics of doing so are not likely to improve between now and your car's 15th birthday.
  10. Mendel Leisk
    41,483
    This one is very telling. If I had a dealership style lift, I'd for sure have it done in under an hour. It's no more complicated than an oil change, and the 4 quarts of Toyota ATF WS plus replacement drain/fill bolt washers retail for about $50 USD. $100 USD for this service would be more than fair.
    douglasjre and Danno5060 like this.
  11. ASRDogman
    ASRDogman Senior Member
    7,599
    3,915
    ????????????????????????????? :confused::eek:o_O(n)(n)(n)
  12. bisco
    51,966
    i would follow the time interval in the maintenance schedule. no point in trading a garage queen, ignore the egr until 50k.
    if you do trade, get a regular gasser, the hybrid isn't saving you anything at that mileage
    Danno5060 likes this.
  13. pasta4breakfast
    109
    52
    Anaheim, CA
    2020 Prius Prime
    In your situation, The only thing I think is worth doing right now is the oil change and coolant replacement. The engine coolant replacement is due at 10 years old. For the inverter coolant, Toyota uses some confusing double talk. On my prius C's warranty and maintenance guide it says to replace engine/inverter coolant at 10 years/100,000 miles, but then there is a foot note that says the following:
    "Initial engine coolant replacement at 100,000 miles/120 months. Replace every 50,000 miles/60 months thereafter. Initial inverter coolant replacement at 150,000 miles/180 months. Replace every 50,000 miles/60 months thereafter. Refer to “Engine/Inverter Coolant” in the “Explanation of Maintenance Items” section in the back of this guide for more information."
    So, yes, I think you are correct that the inverter cooloant isn't technically due until 15 years. However, I don't know why the inverter coolant would last 5 years longer before the first change, but then need to be replaced at the same interval thereafter.
    A hybrid shop just did My 2013 prius C's 2nd engine coolant replacement for $140 and 2nd inverter coolant replacement for $70.
    The spark plugs ("tune-up") are not due until it is 12 years old. With your low miles, I think the hybrid battery will fail at least once before there are any issues with the transmission. From what I've read, the hybrid battery does not like to sit undriven and the eCVT transmissions on toyota hybrids are one of the most reliable transmissions available. If you plan to keep the vehicle another 10 years and you are okay with budgeting for 1 OEM battery replacement or 2+ remanufactured battery replacements, it might possibly be worth doing a transmission fluid repacement, but I doubt the transmission will be the limiting factor in keeping this car reliable until the wheels fall off.
    #13 pasta4breakfast, Jun 8, 2025
  14. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    I've done inverter coolant flush, engine coolant flush, oil and the other services myself. You can too. You'll save a lot more. The NutsandBolts vids pretty much got you covered.
    But since you don't want to do them, and that's fine, I'd seek out an independent shop. For the actual work required those prices are very steep. But that's the way of the dealer. You are going to pay for the "convivence".
    douglasjre likes this.
  15. douglasjre
    douglasjre Senior Member
    2,181
    720
    Null, NL
    Flush? It's a drain bolt! Tune up? Fno. That service advisor (glorified name) gives repair shops a bad reputation. Run like hell
    Danno5060 and Grit like this.
  16. douglasjre
    2,181
    720
    Null, NL
    There are a lot of things that dealers do right. It is a feedback loop we're by they learned from warranty process and from repairs after the warranty. They send parts back to engineering they redesign and they retool and they issue tsbs and superseded parts as well as kits and instructions for future mechanics. We get the three ring binder and the hole puncher and the Master tech basically wrote the book on how to do the work. When you go to aftermarket crap from China you invade the hole feedback loop process. You're now saying that the Chinese make better quality crap than the engineers you trusted to make your toyota. You didn't buy a Chinese car. You know why? Because it's crap and you know it. That's why. So now all of a sudden you think your Chinese part is better? LOL. That said, you don't need to go to the dealer to change fluids. And you definitely don't need a tune-up just because of the mileage. There is no mileage on your car. The service advisor is the one screwing you. They make the whole process look like a sham. The owner of the dealer incentivizes them to sell crap. The mechanic didn't do it a lot of shops do this. Name brand chain stores do this crap all the time. Makes the whole industry look bad. For you I'd recommend you find a good trustworthy Mom and Pop shop that cares about the reputation and builds it on great customer service
