Disabling front cross traffic alert
Discussion in 'Gen 5 Prius Main Forum' started by Templeton, Dec 29, 2024.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    I did too, but it still happens.
  2. Humble Bear
    Humble Bear Member
    130
    49
    Arcadia, CA
    2024 Prius
    There is another thing that will default back to the normal mode and that is the Custom Drive Mode. I hated it when it does that, I customized the steering to be harder and eco on the AC and there is nothing that would hurt the safety. Why did Toyota gave me the custom mode but asked me to turn it on every time?
  3. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    And they said I was a nitpicker...
  4. Gokhan
    Gokhan Senior Member
    6,190
    2,445
    Paramount CA
    It is an incredibly useful safety feature. Why would you disable it? I am guessing it only warns when you are signaling or moving with moving cross traffic. It doesn’t beep while you are stopped at a red light, does it?
  5. Templeton
    Templeton Member
    281
    84
    usa
    2024 Prius Prime
    SE
    Why?
    This is why: when l am nosing out into rapidly moving traffic (i.e., how nearly all normal drivers enter a perpendicular roadway with traffic) and am very carefully looking in all directions (as all normal drivers do), the idiotic audio FCTA warning goes off, which then forces me to move my attention from the outside of the car (where it should be) to the inside of the car to see what in the bloody hell is going on.
    Then, l see that it is another spurious FCTA warning and then l must return my attention to the situation outside of the car. And the FCTA system forces me to do this every time, and this stupid unnecessary distraction is terrible for situational awareness and safety. It is a case of 'the boy who cried wolf': constant unneeded spurious warnings (of vehicles that I can easily and readily see with my own two eyes) decrease, they do not increase, safety.
    (That said, I feel totally differently about RCTA system, as it is profoundly useful because it warns me about traffic that I cannot see.)
    Prodigyplace likes this.
  6. Gokhan
    6,190
    2,445
    Paramount CA
    There are also situations that you can’t see the front cross traffic with your eyes. Last but not least, there are also situations that your eye and brain miss the visible front cross traffic.
  7. Templeton
    Templeton Member
    281
    84
    usa
    2024 Prius Prime
    SE
    I am sure that is the case. But I have used my naked eyeballs to operate motor vehicles for many decades and I have never been in need for a system to warn me about what I can already see. And not just see, but see very, very easily, as these cars (the cross traffic) are right in front of the car and right in front of my face.
    The problem is that having a warning system that tells about something that you already see reduces safety, it does not improve it. In the end, it just trains you to ignore the spurious warning. Which is not a good thing.
    Now, if the FCTA system could warn me about vehicles that I cannot see (as the RCTA system does), that would be a different thing. But it does not do this. Hence, my desire to deactivate FCTA because, in this case, doing that would improve driver safety.
  8. Prodigyplace
    12,548
    11,772
    Central Virginia
    At least on my 2025 Camry XLE it appears in the HUD too.
    Yesterday I actually had the RCTA alert me in a parking lot. The car was OK but RCTA let me know it was there so I could check with my eyes..
