Symptoms of collapsed oil filter
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Oscar MN, Jun 7, 2025 at 7:25 AM.
  1. Oscar MN
    Oscar MN New Member
    Thursday
    What does that look like ? Thanks
    50,967
    probably no symptoms, unless it completely blocked circulation. then you should get over heating and a blown engine
  3. BiomedO1
    2,694
    1,443
    SacTown, Ca
    Most spin-on filters has a bypass valve, so if it plugs up or collapses - your oil won't get filtered.
  4. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    None as far as I know, changed oem media filters at Prius meet ups and I came away with 2 different Prius with collapses filter. Both owners said no issue with car when I asked and showed them the collapsed filters.
  5. douglasjre
    douglasjre Senior Member
    2,075
    692
    Null, NL
    It will either have the words China stamped on the side or will be an imposter from Amazon that says Toyota but is actually from China lol
  6. Oscar MN
    Oscar MN New Member
    Thursday
    Mine has a cartridge filter
  7. ASRDogman
    ASRDogman Senior Member
    7,096
    3,712
    If you purchase the filter from Toyota, you likely won't have to worry about it.
    If you get them from ebay or amazon, very likely they are the cheap chinese copies....
  8. bisco
    50,967
    what symptoms are you seeing
