EGR Cooler Cleaning - PICS
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ArmyChief, Apr 26, 2020.
  1. ArmyChief
    ArmyChief Junior Member
    71
    North Port, FL
    Well, keeping my threads separated between intake manifold and EGR cooler. Here is the EGR cooler after two days soaking in OxyClean & Purple Power. MANY times with the pressure washer both through the inlet and outlet sides. Then half a can of Easy-Off oven cleaner.
    I would say I spent 3 minutes per pressure washer routine. Probably did that for a combined time of an hour !
    LOT's of pressure washer cleaning (almost always would be clean and as I rotated around the tube..would then hit an obstruction and then BAM..black and chunks).
    Wednesday i got to put it all back together and then move on to the next project.
    BTW, as I stated in the other thread, I bought a NEW TOYOTA EGR Valve on eBay from Japan for about $150.
  2. Mendel Leisk
    41,405
    Yeah thought that valve looked super clean. That's maybe a good one-two punch, oxi then pressure washer. Or the other way 'round. (y)
    ArmyChief likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Ah another data point for the pressure washer:).
    Glad you got this sorted(y).
    adrtho4 and ArmyChief like this.
  4. rpieper
    rpieper Junior Member
    VIrginia
    Resurrecting this old string – I have undertaken the cleaning of my 2012, and I have some observations/questions.
    When using the power washer, how does one keep the spray from ‘getting all over’? My first attempt ending up getting some splash back into my eye – tried washing out and ended up with wife taking me to ER for checkup. I had wrap around sun glasses, a hat, long sleeve shirt, etc.
    I had read in one place that someone had used an old bike spoke to help poke out the passage – I tried one but it was too large – sizing it I come up with wire gauge 19 or smaller.
    I am thinking or putting together a compilation of ‘step-by-step for cleaning the cooler. I don’t think I will have to do this again but with Gen 3’s now at about 15 years I believe that more DIY’ers will think about doing this if they can get a head’s up.
    I replaced the EGR valve (old one was hopelessly stuck) cleaned the pipe to the manifold. Price of a new cooler – more than $400 was a little steep so figured I would try to clean mine. I have yet to pull the Intake manifold off.
    I appreciate any thoughts.
  5. ASRDogman
    ASRDogman Senior Member
    7,571
    3,905
    Oven cleaner. It eats the carbon. Then pressure washer.
    Just close your eyes, and look away....
  6. rpieper
    VIrginia
    So I should find a reasonable sturdy 'work bench' that I can secure the cooler to when using the pressure washer. Trying to hold the thing in one hand while holding the washer in the other is just prone to a big mess. Just make sure that the clamping device does not crush the cooler but holds it secure so it does not go flying.
  7. Mendel Leisk
    41,405
    What’s the miles?
    fill the cooler with lye solution (or aforementioned oven cleaner, in a pinch), soak an hour, rinse, repeat as needed. You may need to open up passages some, with a wire. The smaller end hole of cooler is roughly 21 mm ID, #4 stopper appropriate.
    see top two links in my signature (on a phone turn it landscape to see signatures)
  8. rpieper
    VIrginia
    2012 with 298K. Has been a great driver till the shutter - Low oil use (1/2 qt per 1000/1500 miles) no sign of cross contamination between coolant/oil. Changed plugs and coils. Started on EGR. Bought this car as an off lease in 2015 with 32K. Doing my own oil changes, Synthetic every 5K.
  9. ASRDogman
    7,571
    3,905
    I put mine on the ground and put my foot on it, and hold the tip of the pressure washer
    in the opening of the cooler. You can also put it on a chair. Clamping is a good idea.
    The clamp doesn't really need to be too tight.
  10. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    I need to get a pressure washer. Which one do you all recommend?
    NGM. Found this one on sale on amazon. Bought it.
    Electric Pressure Washer, Foam Cannon, 4 Different Pressure Tips, Power Washer. On sale atm on amazon.
    #10 adrtho4, Jun 13, 2025
  11. rpieper
    VIrginia
    Pulled out my WorkMate bench-- it holds -- should have done it earlier
    ASRDogman likes this.
  12. Victorine
    Victorine Junior Member
    Romania
    Just cleaned mine with oven cleaner followed by pressure washing/ rinsing. Folks, DO NOT USE BIKE SPOKES, COAT HANGERS OR ANYTHING MECHANICAL. ONLY CHEMICAL MEANS! The heat exchanger has very delicate fins within the channels and you can ruin them an affect the heat exchanging capacity or worse. I tried, but it's difficult to take good pictures, yet you can clearly see them with naked eye in a clean EGR cooler.
  13. Victorine
    Romania
  14. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    The fins are not delicate, they are made from a pretty sturdy gauge stainless steel.
  15. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,693
    1,739
    Bay Area
    I just stick mine in the rhino ramp hole and wedge it in place and it held up fine. Check out the video
    I also used a gas pressure washer for more pressure than the electric pressure washer, I used the red tip for stronger pressure as well. It cleaned up really well on both sides of the egr cooler.
    adrtho4 likes this.
  16. Victorine
    Romania
    There are 2 types of fins: the sturdy ones that form the channels, and the fine ones INSIDE the channel. These are shorter and stick up to the half of the channel cross section height, like razor blades. At least this is how my EGR cooler is built. They are more visible in the second image. I had plenty of time to observe them last evening after cleaning and drying. I remembered advices to use mechanical means to clean obstructed channels and I told to myself I must say this here.
  17. h1ph0panonymous
    258
    36
    What mileage was this done at?
  18. xliderider
    8,140
    3,276
    Honolulu, HI
    Those secondary fins aren't delicate in the slightest. They will not be damaged as long as you don't try to force a thick gauge wire through the channels.
