What is the BODY ECU?
Discussion in 'Gen 2 Prius Main Forum' started by franken1313, Mar 17, 2018.
  1. franken1313
    franken1313 Member
    216
    27
    US
    What is the body ecu and where is it located?
  2. ChapmanF
    18,469
    It's one of the couple dozen computers in the car; it's responsible for controlling things like the lights, door locks, windows, defrost wires ... general "body" stuff.
    I think it is glommed onto the side of the main instrument panel junction block (driver's side under dash, also houses a bunch of fuses).
    -Chap
    douglasjre and SFO like this.
  3. Austre
    Austre Junior Member
    Hi Chap,
    If Main Body ECU is replaced, does it need to be reprogrammed with information from the old unit???
    kind regards,
    Austre
  4. douglasjre
    douglasjre Senior Member
    2,199
    734
    Null, NL
    Where are you located? What's the vin?
    the main body ECU (or Body Control Module - BCM) can store the vehicle's mileage information.
    Here's how it generally works:
    Odometer: The odometer, located on the instrument cluster, is the primary device that measures and displays the vehicle's mileage.
    ECU/BCM storage: While the odometer displays the mileage, the actual mileage data is stored electronically in various control units, including the ECU or BCM.
    Data transmission: The odometer receives mileage information, and this information is recorded and stored within the ECU or BCM, in most cases, and also in the odometer itself.
    Backup and verification: Storing mileage data in multiple locations within the vehicle's computer systems, like the ECU and BCM, helps to detect tampering. If the data in different modules doesn't match, it can raise a red flag.
    Important Notes:
    Replacing the instrument cluster: Changing the instrument cluster itself will generally not change the mileage because the mileage data is stored in the ECU/BCM.
    Odometer rollback: Tampering with a vehicle's mileage is illegal and is known as odometer rollback.
    Detecting discrepancies: Diagnostic tools used by mechanics can often detect inconsistencies in mileage data stored in different modules, revealing if the odometer has been tampered with.
    Danno5060 likes this.
  5. ChapmanF
    18,469
    Did you write all of post #4 just now from your own personal knowledge, or did some of it come from somewhere?
    As for a gen 2 Prius body ECU, I don't recall seeing anything in the repair manual about any extra steps when changing it. There are such extra steps given when changing the HV control ECU or the one that recognizes the car's key.
    Brian1954 likes this.
  6. douglasjre
    2,199
    734
    Null, NL
    Ai quoted a resource, Embien Technologies
  7. ChapmanF
    18,469
    Thanks. (y)
    I think we're still pretty far from a day when AI results can just be dropped into a post and treated as gospel. The current state of AI seems more like a really talented bullshitter with great google skills.
    So identifying info that came from AI is a good sanity-preserving step.
    douglasjre likes this.
