Stripped EGR bolt of death.... Out of ideas on how to remove
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by adrtho4, Jun 7, 2025.
  1. adrtho4
    adrtho4 Junior Member
    Houston, TX
    Hey,
    I have a 2014 Gen 3 Prius and I'm in the mist of replacing the head gasket. I've removed the all of the bolts of the egr except one. The one that is in the front. I have the tool to remove the bolt, but when I went to remove, I didn't loosen the nut and the head of that bolt tore. I then removed the nut, tried several tools to get the bolt to release, ended up stripping it. I can't remove the egr due me being unable to remove this bolt. I had to disconnect the inverter cables (and I took a pic before hand when I go to re-attach them) for some more room to operate. At my wits end here.
    I've tried a damaged bolt/stud tool. Think that did more harm than good. Tried to re-thread with my tap and die set, but I think the bolt is hardened and I would need a hardened kit to re-thread. I don't have a welder so I can't tac weld anything to remove the bolt. Literally at peak frustration with this thing and I'm running out of ideas... hence this thread.
    Any other suggestion on how to get this thing removed? Maybe call a specialist? Is there a tool I can get that can give me enough grip to twist this off? With it being stripped, the tools I currently have don't provide enough grip and there isn't a lot of space to insert a anything large in there.
    Also, I have been trying to find this very part but the online manuals I look at, the part number is different and the sites are unable to confirm if it will fit or not. Any help with identifying the right part would also be great.
    Thanks in advance for any ideas I can try.
  2. CatNinja
    CatNinja Member
    58
    35
    Hawaii
    2023 Prius Prime
    XSE Premium
    Try Eagle Malco locking pliers. I got mine from Harry Epstein, under $30. Vise Grips may work too, but the Malco has hardened teeth, and reinforcement so you can really crank it down. I had a similar issue on a stripped rusted bolt in a lawn mower and after struggling for a couple of days, I ordered this and it came off on the first try.
    adrtho4 likes this.
  3. adrtho4
    Houston, TX
    Thanks. I do have some locking pliers that came with a car toolkit and my biggest issue is clearance as it was hard to get a solid grip on anything. I'll order those Malco locking pliers and give it another shot.
    I also see a bolt extractor set that I'll order and give this a try as well. Really screwed myself when I stripped that bolt. This has delayed this repair process a lot.
  4. Mendel Leisk
    40,457
    Can the EGR components come off together with the head?
    that aside: Dremel a slot in the tip of the stud, or weld a nut onto it?
    adrtho4 likes this.
  5. Kenny94945
    Kenny94945 Active Member
    839
    417
    Sausalito
    2016 Prius v wagon
    There are specialty designed sockets for removal that you could hammer on.
    Baring the access, the "vice grip" may work.
    As suggested, welding a nut on may work.
    From your description, you may not have the right tools.
    FWIW - soak with penetrating oil for a day or two and be prepared to use heat before you try again.
    Good luck.
    adrtho4 likes this.
  6. adrtho4
    Houston, TX
    From what I can see.... possibly. I would have to remove some hoses and there would be a couple of screws directly under the egr that I would need to get to.
    I don't have a welder atm. I'll have to get one from harbor freight. But I do have a dremel. I could possibly do that. Thanks for the input.
  7. adrtho4
    Houston, TX
    Yeah, I definitely don't have the proper tools. I've ordered a bolt extractor kit which will arrive today. Hopefully that will do the trick, else I will break out my dremel and drill a slot where I can remove the screw.
    I'll pick up some penetrating oil today.
  8. Mendel Leisk
    40,457
    It’s supposed to be removed with E8 Torx socket
    adrtho4 likes this.
  9. adrtho4
    Houston, TX
    Yeah I have one. I just didn't remove the nut before hand.
    Good news is that a bolt extractor kit I ordered came it and it did the job. I had to resist chunking that bolt down the street.
    Now time to clean this egr and remove the valve cover.
    EDIT: Also where did you get that manual from? Does it contain the part number for that bolt? I'm trying to get a new one ordered.
    #9 adrtho4, Jun 9, 2025 at 4:57 PM
    Kenny94945 and Mendel Leisk like this.
  10. ChapmanF
    17,176
    Toyota Service Information and Where To Find It | PriusChat
    The repair manuals generally don't show part numbers for parts.
    At Toyota dealer parts counters they have an app called EPC (the Electronic Parts Catalog) where they can look that stuff up.
    Toyota used to run a web site parts.toyota.com that was usable, but apparently it was a problem having customers show up at dealers already knowing what parts they needed. So Toyota ditched that site and put up autoparts.toyota.com, which is useless. You can't search it by finding parts on diagrams (couldn't, anyway, last I checked), and parts you do find come with AI-generated SEO slop where their descriptions should be.
    It's a mess.
    In the repair manual, you might be able to find a good-enough diagram of the head or the EGR system that you could circle the location of the stud on a copy and bring it to your dealer parts counter when you ask them to look it up in EPC. Makes for a shorter conversation and possibly better outcome.
    A few Toyota dealerships may still be running older parts lookup websites that are usable, but that number seems to be dwindling. I would have to guess they are under orders from the mothership to decommission whatever usably works for customers looking up parts, and transition to the BS new website.
    #10 ChapmanF, Jun 9, 2025 at 5:24 PM
  11. Mendel Leisk
    40,457
    Amayama is my go-to site, if only to get part numbers. Easier by far to navigate than Toyota USA parts site. Being in Canada it's difficult to order from the States, and Amayama is often cheaper (even with shipping). Anyway:
    it's likely on this page:
    https://www.amayama.com/en/genuine-catalogs/epc/toyota-usa/prius/ZVW30L/13502/engine/2501
    part no for your damaged stud: 90126-08056
    Details of above here:
    https://www.amayama.com/en/part/toyota/9012608056
    But verify, checking against your "frame number", listed here:
    which is on the driver's door decal, albeit not ID's as such:
    There's several links in my signature likely to be of interest, EGR and head gasket related. Last link is the full engine section from Repair Manual :)
    (On a phone turn it landscape to see signatures)
    Brian1954 and adrtho4 like this.
  12. adrtho4
    Houston, TX
    Nice. Thanks for teaching me how to fish!!!
    My frame no is ZVW30L-AHXGBA. Using your links now to id the parts properly. Thanks again!
  13. ChapmanF
    17,176
    I've known for years Mendel liked Amayama, but this is the first time I've ever noticed the 'epc' in their URL path. So their search is based on the Toyota EPC data, hmm? That right there's worth the price of admission.
  14. adrtho4
    Houston, TX
    I've just ordered the part from them after confirming the frame. The site had a link which said: "This part on this page looks like it will fit better" or something to that effect. I click on the link and it's the same part no. So I ordered. It will be here later this month, and shipping is pretty crazy but hey, I will get the part I needed.
    Soaking that EGR now as we speak. Valve cover is off. Will get to the headgasket tomorrow and finally replace it. Timing chain still looks good, those are meant to last the life of the vehicle irrc, and there is still plenty of paint on the chain left. Made some real progress today. Can't wait until this is done and all the parts i.e. headgasket, water pump, pcv valve, spark plugs, coils, will have all been replaced.
  15. Mendel Leisk
    40,457
    strategy helps. Ordering multiple items, and all from the same country, will reduce overall shipping charge per item.
    What solution?
  16. adrtho4
    Houston, TX
    Yup. Very true. Unfortunately for me, my only use case was that one bolt that I stripped. As long as the part arrives and it fits then I'd happily eat any additional costs.
    Purple Power degreaser. Had to plug one end of the egr, mix some of that in and just let it soak. Will rinse later today and see if I need another pass. I did do an initial blast with brakleen which got out some initial crud.
    The washers, I'm soaking in a separate container and cleaning with a tooth brush.
  17. Mendel Leisk
    40,457
    If you bog down consider lye solution, or oven cleaner in a pinch.
    adrtho4 likes this.
  18. adrtho4
    Houston, TX
    Noted and added to the list. Thanks again!
  19. hurricos
    hurricos Junior Member
    24
    Burlington, Vermont
    For this type of thing I use a pair of Bremen locking pliers from Harbor Freight. They have a 1/4" drive input to the dial. I pull the screw of the locking pliers, add engine oil, put the screw back, clamp down, then use an impact to tighten. To some extent it sacrifices the pliers, but I've been able to put in excess of 100 N*m on a stripped 10mm head, and it's a small sacrifice to get your car back.
    adrtho4 likes this.
  20. adrtho4
    Houston, TX
    Thanks for the tip. Going to head down to HF once the car is back running. Unfortunately, I'm going to reuse that bolt until the new one arrives. I don't drive a lot and I'll just use that same kit to put the bolt back on. The new one should be here in a couple of weeks hopefully. Can't wait.
