Potential Head Gasket Issue
Discussion in 'Gen 3 Prius Main Forum' started by issjoe, Jun 10, 2025.
  1. issjoe
    issjoe Junior Member
    27
    seattle
    I have a 2015 Prius with 76k miles. I bought it from the original owner at 72k miles. All required maintenace was done at the Toyota Dealership. Last winter I had a loud rattle for 5 seconds. Never happened again and no codes were set. Is that the dampener between the gas engine and electric motor making the loud noise?
    Is that a definitive a sign of a head gasket leak or are there other possible causes?
    The recommened method of checking the head gasket is to pressurize the cooling system and put a camera in the cylinders and look for a very slow drip from the head gaket.
    I can't do it myself and can't find anyone in my area that will use the recommened method. I feel that it would be thowing money away and not getting an accurate diagnosis.
  2. Brian1954
    Brian1954 Senior Member
    2,222
    874
    South Central PA, USA
    Yes, the noise (rattle) is coming from the damper plate when misfires occur in the engine.
    Why have you created a new thread rather than continuing in the "Death Rattle" thread ( https://priuschat.com/index.php?posts/3540396) that you started already?
    If you only had the death rattle (misfires) once, it was caused by condensation being sucked into the engine from the intake manifold! You do not have a bad head gasket!
    I will request that a moderator merge this thread into the other thread that you created.
  3. issjoe
    27
    seattle
    My other posts for some reason would never show correctly on my computer. I contacted the moderator and had the posts removed.
  4. Brian1954
    2,222
    874
    Your "Death Rattle" thread has not been deleted. Click on the link I provided.
    I repeat. YOU DO NOT HAVE A BAD HEAD GASKET. Just drive your car!
    #4 Brian1954, Jun 10, 2025
  5. issjoe
    27
    seattle
    My apologies I thought the other posts were deleted.
  6. issjoe
    27
    seattle
    I can't see the other two posts on my compter. Iv'e been posting on Prius Chat for years and never had a posting problem untill my death rattle posts.
  7. Tideland Prius
    16,559
    Whoops. Sorry. I've deleted that thread now.
  8. bisco
    51,973
    i don't think it is the head gasket either. these engines do randomly misfire on cold startup from time to time based on several factors.
    one thing to avoid is starting it and shutting down before it reaches full operating temperture and shuts down the engine itself.
    you can help reduce warmup time if necessary by lowering the cabin temp setting
    Merkey and ASRDogman like this.
  9. issjoe
    27
    seattle
    Thank you for your reply. My rattle happened at start up, in the garage in the morning. I didn't shut the engin off and the rattle went away in about 5 seconds. I really appeciate your help.
  10. rjparker
    10,163
    6,317
    Repeating from the other thread, if it happens again then look into a borescope inspection.
    Most conventional non-hybrids never exhibit symptoms at this stage. Most local mechanics know how to deal with those cars.
    Generally conventional car owners drive for months with a slight hg leak before it progresses to an advanced hg leak. Those cars then exhibit traditional coolant loss, combustion gasses in the coolant, white smoke out the exhaust or a blown engine.
    Third gen Prius engines with a spring loaded damper and two powerful electric motors which can and do have an unusual early hg symptom, eg occasional severe rattling that quickly goes away. "Occasional" means now and then - not just once.
    A Toyota dealer knows Prius hg symptoms but their service model is to witness the symptoms before recommending a rebuilt engine. Both of which are not helpful for your singular, one time problem. Assuming it is really just once, months ago.
    A shop that specializes in hybrids will do a borescope inspection for a fee. The diagnostic fee may be as high as a dealer but is recommended as they will offer repair options that a dealer will not. You may have to drive across town and the shop may be small.
    Best advice - don't worry about it until it happens again. If you can't stop worrying then sell or trade it while it's still worth something.
    #10 rjparker, Jun 11, 2025
  11. issjoe
    27
    seattle
    Thats great infomation. Thank you for your insight. Ive heard alot of Gen 3 Prius owners say they have only experienced the rattle during low weather temps. Any input from people who have experienced that symptom would be appreciated.
  12. bisco
    51,973
    hopefully, 2015, with updated pistons and rings will be less prone to the head gasket problem
  13. issjoe
    27
    seattle
    Hi bisco. I bought my 2015 Prius based on The Car Care Nut YouTube channel. He said the 2015 Prius had the piston ring and head gasket problems resolved. But when I called the Toyota dealer parts dept. they said the 2015 Prius had the same head gasket as the 2010 Prius. The 2015 Prius head gasket did have a different part number than the 2010 Prius head gasket. But to him it looked like the same head gasket.
  14. rjparker
    10,163
    6,317
    The 2015 has better piston and rings than a 2010-2013 including some 2014s.
    Toyota also revised the intake manifold, egr valve and control logic in the engine ecu. There was a revised head gasket with more of the black sealing layer but it's not clear when a production change included them in new vehicles. Your 2015 may have the manifold and egr valve but all gen3s except the 2017 Prius v have revised engine ecu software available.
    There were significant engine and cooling system changes made in gen4 engines which did solve the gen3 hg problems in cars that had not overheated.
    Gen4 Prii still command a premium price. They have an exhaust heat recirculating system that have been known to leak coolant, overheat and blow head gaskets. Primarily in the first two years of gen4s. Drivers often don't recognize the high temperature alert's importance and keep driving to their destinations.
    #14 rjparker, Jun 11, 2025
  15. issjoe
    27
    seattle
    Thank you rjparker. Thats some great information. I know I've seen an image of the head gasket you mentioned. I thought the Toyota parts department guy would have pulled that newer head gasket up in his system. But he didn't. He said said it was the same head gasket through 2015, although the 2015 head gasket did have a different part number. That's very confusing to me. My Prius did get the engine ecu software update done at the dealer. It's in the service records. I've seen a Youtube video of the leaking exhaust heat recirculating system. When the coolant system was pressurized, coolant started flowing into the the catalytic converter. My main source of YouTube videos are posted on The Car Care Nut Channel.
  16. Mendel Leisk
    41,488
    Pretty sure I responded to your previous thread, it’s my bread-and-butter lol. Why oh why delete. Anyway.
    it “could” be head gasket. With your miles, the head gasket failure is unusual, but it’s not an exact science. It doesn’t suddenly fail, say at 150k miles. You maybe drew the short straw. If not head gasket (yet):
    It definitely could be liquid accumulation in the cylinder, for some reason. Another common reason is after a previous short run time, the previous day. Say engine only ran for under a minute on day one. Then on day two it shakes on start up.
    I’ve experienced this, and consensus here is water is drawn into intake on day one (possibly through PCV), and then on day two, that water manages to “present” in a cylinder, or cylinders, causing the engine to stumble during compression.
    I’m guessing “all required maintenance” did not include EGR cleaning.
  17. issjoe
    27
    seattle
    Hi Mendel. My previous thread got corrupted on my desktop computer.The replys displayed all jumbled on my screen. I contacted the admin and he deleted that thread. Fortunately this thread is working correctly.
    I have not done the egr cleaning, because I'm currently not physically able to do it.
    Thanks for sharing your personal experience with the rattle. That makes me feel alot better.
    I do alot of short trips to the store that are less than a mile. Maybe one of those trips I had water drawn into my intake.
    For some unknown reason, the rattle seems to only be happening to Gen3 Prius owners during cold weather. My rattle happened last January.
    The reason that I got so shook up by the rattle, is because I had never experienced it before. I owned a 2009 or 2010 Prius (I can't remembr which year) before my 2015. Had it for 5 years from 60k miles to 100k miles. I had never heard the death rattle on that one.
    I bought the 2015 Prius base on a review on the Car Care Nut YouTube channel. He said the 2015 Prius had the oil burnig a head gasket issues resoved. When I checked with the Toyoat dealer parts dept, they thought the 2010 through 2015 head gaskets were all the same. The 2014 and 2015 head gasket did have a different part number. I then contacted The Car Care Nut's shop in Chicago to get a paid phone conultation. Unfortuntely he dosn't do that. With over a million subscribers to his channel, I can see why he doesn't have time to do it. If I lived in Chicago I would definetly bring in in for a head gasket check. He has another video on how to check for head gasket leaks, specifically on a Prius. I haven't found any one in my area, that I feel would run the test correctly.
  18. bisco
    51,973
    i wouldn't trust a dealer parts guy to know what he is talking about
  19. Mendel Leisk
    41,488
    Could be due to more humidity.
  20. issjoe
    27
    seattle
    Thank you for your post. I am headed to the Toyota dealership were the car was originally purchased. I have a YouTube video of the "death rattle". I'm goig to see what the service advisor thinks the noise is.
