How to drain inverter coolant?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lastradakiwi, Jun 12, 2025.
  1. lastradakiwi
    lastradakiwi Junior Member
    22
    Fairfax, Virginia
    2017 Prius c
    Hi everyone,
    I have a 2009 Prius (Gen 2) and I’m getting ready to drain and refill the inverter coolant. I recently replaced the inverter pump, and I want to make sure the whole system has clean coolant and no air bubbles.
    I’m a bit confused about where exactly to drain the coolant. I know there is a drain plug under the car, but where exactly is it? I don't want to accidentally drain the transmission fluid instead of the inverter coolant! If there’s a plug, what socket size do I need to remove it? Will I need a breaker bar?
    Also, is there a socket that fits the bleeder valve for the inverter system? I tried using a 10mm socket, but it wouldn't go all the way down. Do I need a deep socket instead?
  2. dolj
    dolj Senior Member
    8,423
    4,284
    Wellington, New Zealand
    I've attached the repair manual excerpt, which shows the bolt. It is a 24 mm bolt. The Transaxle fluid drain is a (10 mm, don't quote me) hex (or allen key) inset bolt (same Idea as a machine screw) so your 24 mm socket won't fit that one.
    24 mm
    Most likely, if this is the first time it has been undone, and you might need a handle extension as well.
    No, it is better to slip on a closed-ended wrench before attaching your drain hose. A socket is not practical for this.
    lastradakiwi likes this.
  3. Tombukt2
    12,900
    2,315
    The pH test strips of your original coolant that's in that container. Should show good . Top it up . Save for real repairs . Now if the fluids green from mix of orange and blue coolants by all means go ahead
