Question-2025 Prius in EV Mode: Reply quickly!
Discussion in 'Gen 5 Prius Technical Discussion' started by iRun26.2, Jun 13, 2025.
Tags:
  1. bisco
    51,256
    it's why a lot of us drive ev's
  2. ChapmanF
    17,477
    More-than-tripling the power of the gen 3 version opens an even wider range of possibilities.
    Sure, I could also go buy a 185-watt panel and carry it around and deploy it somehow when wanted. But having it just be there is convenient.
  3. iRun26.2
    iRun26.2 Active Member
    815
    167
    United States
    I bought it (2025 Prius PHEV) today. I have only driven a little way (all in EV). I can see how the range will never be close to 40 miles in model (it was going down pretty quickly though I had the a/c on).
    I do not look at the solar roof as a gimmick. It’s the part of the car I am most curious about. There is lots to explore, though. I’ve never had such a luxurious car.
  4. Paul Gregory
    Paul Gregory Senior Member
    1,668
    418
    Alberta
    2024 Prius Prime
    XSE
    I'm not good at rough calculations, but the battery in a Prius Prime has a capacity of 13,600 watt hours. The Prius Solar Roof has a capacity of 860 watts. You do the math.
  5. iRun26.2
    815
    167
    United States
    I don’t think it is 860W. I think the specification is actually (‘only’) 185W. So, at maximum capacity for my entire trip home (bought the car in Milwaukee and live in Minneapolis), 6-hours I’ll see the power of 1000W-hrs saved to run the air conditioner. That should translate to about 1/13 of the total battery capacity so close to 3-miles, I think that’s right…. I’ll take it!
    Kevin Grant and bisco like this.
  6. iRun26.2
    815
    167
    United States
    Today I drove my new 2025 Prius Plug-in Hybrid from Milwaukee to my home in the Minneapolis area. I couldn’t figure out how to not use the battery at the start (saving it for later) so I just let it use battery power until it was gone. I was quite pleased to see that I got close to 40 miles before the gas kicked in (not even driving that slowly). Then when I got home, I was very pleased to see that my gas mileage (without a depleted battery) was 56.0 miles / gallon. I drove between 65mph and 70mph the whole way! I am delighted by these numbers! I was not expecting anything close to that because my high-end model (I can’t remember what it’s called) is supposed to only get 48mpg in HV mode.
    It wasn’t that terribly sunny but my car reported that it captured 2.2miles worth of Watt-hrs (supposedly used to power the air conditioner and other auxiliary processes while driving). It was really fun to watch the incoming power go up significantly when the sun peaked out from under the clouds.
    I’m looking forward to driving it 22 miles to work on Wednesday (working at home Monday and Tuesday). I wonder if I might have enough battery to go all the way to work and back if I just charge with the solar panel all day. I may not do that, though m, as I don’t want to take the chance of using any gas. I am allowed to charge at work (using the slow 120V charger that it came with) so that is most likely the best routine to ensure a fully EV day of driving.
    Dang this car is so much fun for nerds like me!
    #26 iRun26.2, Jun 15, 2025
    PrimeDan, bisco and otatrant like this.
  7. Paul Gregory
    1,668
    418
    Alberta
    2024 Prius Prime
    XSE
    As I said before, the Solar Roof is a good idea from a fun standpoint.
    PrimeDan likes this.
  8. iRun26.2
    815
    167
    United States
    It is more than ‘fun’. I think it is a practical way to reduce one’s carbon footprint. (Also, it is not just the solar roof that makes the car fun!)
    If you gain even only 2 miles / day for free (from solar power) you gain over 700 miles / year. That’s saves about two tank full of gas!
    Is it cost effective? I think so. Two tanks of gas could easily be $50. That means in 12 years one could get their $600 back (my last plug-in was 13 years old when I hit a deer and totaled it).
    But, the financial portion is not the point: I live in a townhome. I am not allowed to put up solar panels on my roof. The Prius’ solar roof is a great opportunity for me to generate sustainable (green) energy from a solar panel. I’m willing to pay a little extra for that.
    mountaineer and bisco like this.
  9. iRun26.2
    815
    167
    United States
    (Duplicate post…please delete)
  10. AgentPTFC
    AgentPTFC Junior Member
    28
    PNW
    2025 Prius Plug-in
    XSE Premium
    I recently bought a '25 similarly spec'd. I thought the idea of the solar roof was very cool so I worked with the dealer near me to get one shipped there from another dealer. I'm about a month into owning it and have found on sunny days parked at work for around 8.5 hrs I will generate about 1kwh or about 4 miles. It makes a measurable difference and fully intend on owning this car long enough for it to pay for itself. It's not going to do a lot during the winter but knew that going into it. And I'm not much of a sun/moon roof guy to begin with so it wasn't something I would really miss.
    Because it can run on EV nearly all of the time I'm going to run the ICE for one of my commute days probably once a week.
    Kiana and iRun26.2 like this.
  11. bisco
    51,256
    congrats on your new plug in, all the best!
    in your effort not to use gas (i have done so myself) keep in mind that you dodn't want the gas to sit in there forever.
  12. iRun26.2
    815
    167
    United States
    One of the most disappointing things about the solar roof to me is that I cannot get the battery charged through an AC connection and the solar panel at the same time. I can charge at work but I’d like to make better use of the solar roof being parked at work. I’m not quite certain how much electricity it will take to me to work (22 miles away). If I could make it all the way and back with the solar boost, that would be perfect. Although, with declining battery capacity that probably wouldn’t for many years anyway.
    I’m curious about the efficiency of the electric motor in your car. Have you paid attention to the miles / kW-hr efficiency values? It is easy to get 4 miles / kW-hr but I’ve also seen 5 miles / kW-hr. I think the air conditioner makes a big difference here.
    Glad you like solar roof. I love how you see exactly what you’re currently getting in terms of Wattage.
  13. bisco
    51,256
    60-70mph won't likely get you 5 miles per kwh
  14. iRun26.2
    815
    167
    United States
    I wonder how long is too long. During the year of the pandemic, I went virtually 9-months betweeen tanks of gas. My guess is that you are going to say that is too long.
  15. bisco
    51,256
    LOL, i can't really say. the original plug in ran the engine every 124 miles if it hadn't been used. the next gen did not, but had a recommendation in the o/m.
    check yours to see if toyota says anything. 6-12 months is probably fine on these new systems, but it may depend on the quality of the gas as well, idk.
    if you try a search, this may have been asked and answered
  16. Gokhan
    Gokhan Senior Member
    5,799
    2,286
    Paramount CA
    It was probably a great deer, too.
  17. bisco
    51,256
    covered in great ticks
    iRun26.2 likes this.
  18. iRun26.2
    815
    167
    United States
    That’s for sure! I’d be quite pleased if it stayed at 4 miles/kWh.
    Earlier today I had a 7 mile trip where I averaged 5 miles/kWh. I don’t have a good feel yet as to how to get the most out of my battery and solar panel.
    Kiana and bisco like this.
  19. Paul Gregory
    1,668
    418
    Alberta
    2024 Prius Prime
    XSE
    The best I've been able to get with mine is 14kWh of electricity per 100 kilometers (62 miles).
  20. iRun26.2
    815
    167
    United States
    Wow! That is impressive! What kind of driving did you do?
