Bad terribly annoying no good three way coolant valves
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Deveak, Jun 15, 2025.
  1. Deveak
    Deveak New Member
    West Virginia
    I use my Prius for gig work so it gets a lot of miles. Recently I got the p1121 code and ignored it because I read on various forums it wasn’t important and most likely a stuck valve. A few weeks later it turned into p1122 and a red triangle. Luckily I just set out and was only a few miles from home. I drove back slow, mostly in EV and downhill.
    Turned out the three way valve internally failed at the rotary seal and leaked all of my coolant out. Many a hot and sweaty hour later I replaced it with a 4 season third party valve and it’s working again but I can occasionally hear the sound of it hunting from
    The sensor being out of sync or whatever you want to call it. Is it a bad valve or just not very good? If it is a failing part, would it fail catastrophically like last time or can I just keep driving it with the code if it pops up again? I need it for work.
    51,965
    there's no way to know, but we have seen a lot of problems with aftermarket (cheap chinese) counterfeit parts. recommendation here is to buy oem from online toyota dealer of brick and mortar.
  3. Tombukt2
    13,003
    2,330
    I have one gutted right now I want to set it in the Midway point so all three ports just stay open pull out motor or driver gear. So motors on nothing moving. Close up install . See what goes down
    Deveak likes this.
  4. Deveak
    Deveak New Member
    West Virginia
    This was a four seasons brand part from rock auto. I don’t think I’ve heard or rock auto getting knock off parts.
  5. bisco
    51,965
    okay, good luck!
