Traction Battery Questiion
Discussion in 'Gen 2 Prius Main Forum' started by nwpa, Jan 21, 2007.
  1. nwpa
    nwpa New Member
    48
    Erie PA
    I know that the traction battery is air cooled and the air duct is inside the cabin at the right side of the back seat.
    Is there is seperate fan to maintain the air flow to the batterey or is the air flow dependent on the fan in the climate control system?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    There is a fan that comes on when necessary...otherwise (and most of the time) the battery is cooled (and heated) by passive flow of air from the cabin.
  3. nwpa
    nwpa New Member
    48
    Erie PA
    <div class='quotetop'>QUOTE(efusco @ Jan 21 2007, 03:29 PM) [snapback]378758[/snapback]</div>
    Thankyou for your prompt and well-worded replay.
  4. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(Perk @ Jan 21 2007, 12:26 PM) [snapback]378757[/snapback]</div>
    Here is a cutaway view of the battery cooling system.
  5. richard schumacher
    7,664
    1,046
    United States
    Note especially that the traction battery is cooled by cabin air. If you avoid using air conditioning in very hot weather in an attempt to improve your fuel economy you may actually reduce fuel economy and risk damaging the traction battery, because it may be running too hot.
  6. tochatihu
    tochatihu Senior Member
    9,753
    3,761
    Kunming Yunnan China
    2001 Prius
    Following on Richard's point, a few Prius drivers have added equipment that allows monitoring HV battery temperatures with the sensors already installed. In my 2001 Prius I make a point to use A/C whenever the max battery temp reaches 45 oC. Summer driving is a necessary but not sufficient condition for this. What really gets it hot is up and down mountainous terrain. The highest I have yet noted is 51 oC and I went to full blast A/C at that time. The coolling rate is about 1 oC per 5 minutes, and very much slower of the ventilation system is set to 'recirc'. I would not claim that 45 oC is a 'danger level', but certainly there is one, and it may not be very much higher.
    DAS
  7. KMO
    KMO Senior Member
    1,947
    676
    Finland
    2023 Prius Prime
    If the battery's getting hot, you'll know about it because the battery fan in the back will come on full blast... If you can't hear that fan running, then there's definitely nothing to worry about.
    And on top of that, if the battery is too hot for safety, lots of warning lights will come on...
    Don't worry.
  8. Tideland Prius
    16,547
    <div class='quotetop'>QUOTE(tochatihu @ Jan 24 2007, 03:15 PM) [snapback]380336[/snapback]</div>
    How would that work? I thought your vent was outside the vehicle?
  9. richard schumacher
    7,664
    1,046
    United States
    <div class='quotetop'>QUOTE(KMO @ Jan 24 2007, 08:26 PM) [snapback]380369[/snapback]</div>
    Agreed, I overstated the case: the traction battery won't allow itself to be damaged. But if it's too hot (or too cold) it will operate less efficiently. Rule of thumb: if you're comfortable then so is the battery.
  10. tochatihu
    9,753
    3,761
    2001 Prius
    Hi Tideland, in 2001-2003 Prius the HV battery air inlets are on rear shelf, and the outlet is external. Cabin air flows through, especially when not set to 'recirc', and heated or cooled according to heat/A/C settings. On the new model it is similar.
    I am not trying to sound alarms here about HV battery temperature control. Just to note what I have seen, my criteria for action, and the observed results. I would agree completely that under many driving conditions, no operator intervention whatever should be required.
    In general NiMH battery lifespan is reduced by excessive temperatures, but it may also be that my decisions to intervene are on the conservative side.
  11. SomervillePrius
    SomervillePrius New Member
    944
    Somerville, MA
    I think the same is true for low temperatures. For some time I tried not using the heater for cool days. The result where that the engine shut off more but I wasn't getting much help from the battery. The result seemed to better or actually slightly worse then keeping the heater to 65F (for temperatures under 32F)
  12. Frank Hudon
    Frank Hudon Senior Member
    4,147
    on of the advantages of the Classic is when you use the A/C to cool the battery your actually cooling it, the G2 uses the HV battery to run the A/C compressor and that conversion of chemical to electricity makes the HV battery get even hotter.
  13. KTPhil
    KTPhil Active Member
    1,379
    Not really... it CAN use the battery for A/C (like while waiting at a light), but it will simply use the ICE if the battery and motor to generate the current for the A/C if the battery is getting hot. It will not heat up the battery in order to run A/C so it can cool the battery--that would of course not work.
  14. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(KTPhil @ Jan 27 2007, 01:15 PM) [snapback]381742[/snapback]</div>
    sitting in low speed or stopped traffic with the A/C on it'll pull the battery down to 2 pink bars before the ICE will cut in that chemical reaction to produce electricity to run the A/C causes heating of the battery. This summer I'll pay attention to the voltage and amperage draw on the HV battery just to see what temps it'll get the battery to. The G2 A/C pump should have been hybrid like the HAH any time the ICE is running it powers the compressor and when it's off the battery does. That first 5 minute run of the ICE should be driving the compressor.
  15. naterprius
    naterprius Senior Member
    1,843
    My battery drops to two pink bars and the cooling fan comes on full blast every day on the way home from work during the summer. I've tried everything.
    My office recently trimmed the tree I used to park under so it no longer provides shade.
    It really sucks because when I first get on the highway, I have a hill to climb, and the battery drops to one pink bar. After that, the car kind of comes back to normal.
    Nate
  16. naterprius
    1,843
    In the winter, the engine runs to make heat, so the battery is nearly full when I get on the highway.
    Nate
  17. Tideland Prius
    16,547
    <div class='quotetop'>QUOTE(tochatihu @ Jan 26 2007, 08:11 AM) [snapback]381111[/snapback]</div>
    ohh.
    Then where's our exhaust vent? I know it's to the passenger side of the car but where?
  18. seasalsa
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(Tideland Prius @ Jan 28 2007, 05:37 PM) [snapback]382099[/snapback]</div>
    Take a look at the link I provided above.
  19. Tideland Prius
    16,547
    <div class='quotetop'>QUOTE(seasalsa @ Jan 28 2007, 07:22 PM) [snapback]382132[/snapback]</div>
    I have that picture. Like I said, I know it's on the passenger side but where? Don't tell me it just exhausts it to the rear fender lol.
  20. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(Tideland Prius @ Jan 28 2007, 10:49 PM) [snapback]382194[/snapback]</div>
    yes it vents out behind the plastic rear bumper corner behind the rear wheel opening.
