2007 Prius Suspension Quote?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ZillahG, Jun 18, 2025 at 8:28 PM.
  1. ZillahG
    ZillahG New Member
    Quote:
    All front
    Lower control arms
    Quick-Struts
    Balljoints
    Swaybars
    1300$
    Add front tirerods
    1400$
    Rear struts included
    1600$
    95k miles, 18 years old, suspension is all OEM. My mechanic only recommends the first 1300$ of work, I can do the rest if I want to pay for it. The manual says to do the rear as well at this mileage but he says its good. Are these reasonable quotes?
    Labor is 7 hours, 170x2$ for quick struts, arms & ball joint 130$.
    #1 ZillahG, Jun 18, 2025 at 8:28 PM
  2. Hayslayer
    Hayslayer Member
    184
    98
    Why in the world would your suspension need to be replaced at only 95k miles in Florida? Is this a "because the manual says to" or do you feel a problem when driving?
    ....and he's not going to change the sway bar on a Gen 2. Maybe bushings.
    I have 220k on a (still) oem suspension and the car rides just fine and straight as an arrow.
    My other had 300k when I did all 4 corners and the difference was hardly noticeable, but I don't do a bunch of hot rod curves, either.
    There's just no way I can believe a 2007 under normal use, with no 'damaging' event, with 95k miles would need anything at all done to the suspension.
  3. saneesh8
    saneesh8 Member
    134
    27
    Allen, TX
    Check it and replace if needed. Especially the rubber parts like control arm/tie rod ball joints and bushings.
    Avoid quick strut. Read mixed reviews.
  4. ZillahG
    ZillahG New Member
    I can't get alignments cause the arms are too fucked up
  5. ZillahG
    ZillahG New Member
    Good to know, I might just try that then. The suspension is still bouncy, though I plan on going on a long roadtrip soon so idk if I should keep it as is.
  6. bisco
    51,028
    prices look pretty fair. if you are going to keep it, might as well get everything done
