Red Square Warning Light
Discussion in 'Gen 5 Prius Main Forum' started by daisy555, Jun 21, 2025.
  1. daisy555
    daisy555 Senior Member
    1,715
    708
    CT
    This is the second time I’ve had a large red square warning light pop up on my dash screen. It takes up almost the entire left side of the screen. Happened a while ago and I thought it was just a glitch but it just happened again. It says something but it turns off too quickly for me to read it.
    Of course I took my manual out of the car to read about the AC and can’t look it up. Just curious if anyone is familiar with this. Googling was NOT a good idea. : } It just flashes on and then disappears. Thanks
  2. Gokhan
    Gokhan Senior Member
    6,185
    2,443
    Paramount CA
    Probably automatic emergency braking (AEB) or automatic parking braking.
  3. daisy555
    1,715
    708
    CT
    While I’m driving? I forgot to mention that detail.
  4. Gokhan
    6,185
    2,443
    Paramount CA
    Yes, that red “BRAKE!!” warning would only come up while driving.
  5. daisy555
    1,715
    708
    CT
    Well there are no cars in front of me when it happens and no auto breaking occurring.
  6. Gokhan
    6,185
    2,443
    Paramount CA
    It can still get confused or detect something you didn’t see.
    daisy555 likes this.
  7. Trollbait
    12,518
    Or detect something that isn't there.
  8. schja01
    schja01 Senior Member
    1,831
    1,220
    Chicagoland
    2024 Prius
    Limited AWD-e
    Doesn’t even have to be in front of you. Thinking garage walls, etc.
  9. daisy555
    1,715
    708
    CT
    This happened on a road I travel often. No one in front of me and no one coming towards me. It seems crazy that it would flash such a large warning so quickly that it can’t be read.
  10. Trollbait
    12,518
    slight curve with a car in a turn lane is where the Subaru has falsely alerted to something in front. The warnings and exceptions in the Toyota manual for these systems is probably longer than the about part.
  11. daisy555
    1,715
    708
    CT
    Thanks for correcting my spelling. I’m often voice typing and don’t catch every mistake. If that warning is for braking or avoiding a collision the sensors are quite confused.
    Gokhan likes this.
  12. Gokhan
    6,185
    2,443
    Paramount CA
    Maybe, maybe not. There are already threads about this such as this:
    Gen5 Prime suffers from phantom brake syndrome. | PriusChat
  13. otatrant
    otatrant Active Member
    330
    204
    San Francisco
    2023 Prius Prime
    XSE Premium
    My 'sub-battery system malfunction visit your dealer message similarly popped up and disappeared'. I keep my phone mounted on the dash so was able to record a video. You could keep your phone camera app open and ready so if happens again you can grab a photo.
    daisy555 and Gokhan like this.
  14. Gokhan
    6,185
    2,443
    Paramount CA
    That sounds like a temporary voltage glitch in the 12-V system, with the DC–DC converter voltage dropping too much due to a high-current demand such as when using the electric power steering all the way to the stops etc. Usually, the system will raise the voltage to 14.3 V to prevent that from happening during high electric loads. You can ignore it unless it becomes a permanent message.
    otatrant likes this.
  15. otatrant
    330
    204
    San Francisco
    2023 Prius Prime
    XSE Premium
    I did ignore first happened in April. Both times it happened while using dynamic cruise control which abruptly turned off. First time soon after it happened I pulled over turned the car off and back on again and the message went away. When it happened another time in May the dealer ended up calling me right after it happened and set up an appointment. They replaced the INTEGRATION CONTROL SUPPLY under warranty.
    Gokhan and daisy555 like this.
  16. Perfectpacman
    Perfectpacman Junior Member
    84
    22
    United Kingdom
    2024 Prius
    ----UK----
    The emergency warning can be illuminated by turning a corner for example and if there's anything even partially in your lane or close proximity. Overall I think the safety sense is excellent, but it can be a little intrusive on the odd occasion.
