Pass Side Axle Snap Ring Question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriuSocal, Jun 25, 2025.
  1. PriuSocal
    PriuSocal Member
    198
    40
    SoCal
    So I recently got my passenger side axle rebuilt by a local shop and when picking it up, they said it did not have the snap ring axles have at the end of the spline where it connects to the transmission. They installed one that appears to fit loosely and when trying to install it, the axle will NOT go into the transmission fully. It tends to get caught on the snap ring and unable to insert it all the way in. I tried to lightly tap it with a hammer and nothing.
    I called them and they said that they use universal snap rings and that they installed the one sized to that specific axle. I tried everything, removing it and clamping it to close the gap more and even called the dealer to buy a new one BUT they advised this part has been discontinued although it is used on Toyotas from 1981 to 2024. I was able to find one for $2.10 at Bell Toyota in Phoenix, AZ but they are not willing to ship it to me,
    I went to various autoparts and they do NOT carry those rings. They showed me another axle from their stock and that ring is even looser fitting than mine so I am wondering whats going on.
    Below is the Toyota parts diagram and the red arrow is pointing at the snap ring in question. The snap ring part # is 43425-02050.
    Any help with this would be greatly appreciated.
    #1 PriuSocal, Jun 25, 2025
  2. Brian1954
    Brian1954 Senior Member
    2,014
    786
    South Central PA, USA
    What year Prius are you working on. I believe that you own Gen 2 and Gen 3 cars. You have created this thread in the Gen 4 forum.
    PriuSocal likes this.
  3. BiomedO1
    3,156
    1,671
    SacTown, Ca
    I would simply replace that entire axle with a lifetime warrantied one from your local parts store and be done with it. You don't want to chance that replacement ring breaking and getting ground up in your tranny. That can cause other issues.
    That's just me........ Good Luck.
  4. PriuSocal
    PriuSocal Member
    198
    40
    SoCal
    Yeah, not sure why it was posted on gen 4 forum. Not sure how to fix this or should I repost it in the Gen 2 forum again @ChapmanF
  5. PriuSocal
    PriuSocal Member
    198
    40
    SoCal
    Not feasible when you're on a budget. I did some more research and found this video
    I am going to try that with a new snap ring from parts store I ordered and see how that works out.
  6. BiomedO1
    3,156
    1,671
    SacTown, Ca
  7. Brian1954
    2,014
    786
    Do not create a new thread. I will ask a moderator to move this thread to the Gen 2 forum.
  8. PriuSocal
    PriuSocal Member
    198
    40
    SoCal
    Solved either way, Turned out to be the spline on the shaft that was going into the transmission had damage to one of the lines or whatever you call it, so it would not allow 2 of the splines to go in smooth and was hitting there. I ended up replacing the head with the one of my old axle and installed the same snap ring and all is good now.
    Brian1954 likes this.
  9. Tombukt2
    12,689
    2,267
    The snap ring does not have to be there. I have several without it . You need to put the snap open at 6 o'clock for it to go in i promise so on insertion you don't wanna twist shaft more than one tooth to maintain 6 oo been catches at 6 it'll close naturally and drop in . 3 and 9 not too much . No lockring is Otay .. car won't even know and axles come out imed with bolts undone period.
