Engine Shutter @ 45-50 Mph
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TwoPriusInTenn, Jun 28, 2025.
  1. TwoPriusInTenn
    250
    66
    Tennessee
    Greetings,
    Wife's 2010 with 428,021 miles.
    I replaced the head gasket on this car in 2019. My daughter has had it in Florida. Came down this weekend to change the oil and sparkplugs. I also cleaned the EGR Cooler. (preventative).
    When I was done, I took the car for a drive and it shuttered at 40-50 mph. I checked TechStream and tthere was misfires in Cylinders 2 and 3. Switched around the colis and Techstream is still registering misfire in Cylinder 3,
    I'm thinking the headgasket might be gone again.
    Anything else I should check before throwing in the towel on this?
    Tombukt2 likes this.
  2. Tombukt2
    12,898
    2,315
    Nope you pretty much got it we had a persona did this twice . No fun
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,693
    1,737
    Bay Area
    any coolant leak? That should indicate it.
    Any cold start shutter? How are the fuel injectors? How does the spark plugs look?
  4. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Leak down test. If it passes throw parts at it. If it failed, trip down to head gasket replacement again.
  5. TwoPriusInTenn
    250
    66
    Tennessee
    Yes. Cold start shutter
    Sparkplugs replaced - still shuttering.
    Coolant level is going down in reservoir.
    It's not quite toast yet. But all the signs are there. At 427,000, I think it's telling me it needs to rest.
    Thank you for your input.
    NutzAboutBolts likes this.
  6. ASRDogman
    ASRDogman Senior Member
    7,535
    3,892
    How many miles on the new head gasket?
    If it's a few hundred, then it's a good bet it could be the head gasket.
    And with that many miles, maybe a remanufactured engine would be best???
  7. NutzAboutBolts
    1,693
    1,737
    Bay Area
    It’s possible it’s the headgasket leak again. What brand of headgasket did you use?
    I would pull the spark plugs and put a borescope down the tube and see each cylinder to see if it’s wet. Then check for compression in the cylinder and the coolant reservoir.
