2007 model, hybrid warning light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SarcasticFringehead, Jul 5, 2025 at 8:47 AM.
  1. SarcasticFringehead
    SarcasticFringehead Junior Member
    UK
    Last drove the car two days ago locally.
    Drove today on the motorway for just over an hour. Red triangle plus hybrid warning came on.
    I then had to drive for a couple of miles before I could find anywhere to pull up and park.
    The warning lights come on every time I restart the car. It’s not internittent.
    Nothing about the driving experience seemed off. Nothing in the car’s recent history seems like it could have caused this, though what do I know.
    I’m waiting for the tow truck now.
    I don’t have a code reader. I realize that without codes, anything you can tell me is no better than a wild guess.
    But my garage is closed till Monday and I could do with the emotional support. Please come at me with your best most wildest guesses as to the manner and extent of how screwed I am.
  2. fragglestickcar
    83
    43
    New York
    Inverter overheat due to a failed pump which might have died during winter but you'd only learn about it in summer. Car largely functional but loses upper-end power.
  3. SarcasticFringehead
    UK
    Wow! Thanks for that interpretation.
    Assuming you’re right, is it gonna be hell to fix?
  4. SarcasticFringehead
    UK
    Update: the yellow brake system warning light ((!)) is also on. I didn’t notice this before.
  5. SarcasticFringehead
    UK
    Update: following codes came up:
    ABS (Anti-lock Braking System)/VSC (Vehicle Stability Control)/TRC (Traction Control System)
    C1310
    HV System Malfunction
    Current
    CCS (Cruise Control)
    P3000
    Battery Control System
    Current
    HVB (Hybrid Vehicle Battery)
    P0A84
    Hybrid Battery Pack Cooling Fan 1 Control Circuit Low
    Current
    P0A84
    History
    HC (Hybrid Control)
    P3000
    Current
    HC (Hybrid Control)
    P3000
    History
    EMPS (Electronic Motor Power Steering)
    U0121
    Lost Communication With Anti-Lock Brake System (ABS) Control Module
    Current
    AC (Air Conditioning)
    B1421
    Solar Sensor Circuit (Passenger Side)
    Current
    B1400
    Normal
    History
  6. fragglestickcar
    83
    43
    New York
    Yeah, no it's not the inverter pump then.
  7. SarcasticFringehead
    UK
    I bet it’s corrosion of the hybrid battery from the leak last year. There would have been standing water in there for ages.
