Possible replacement EGR cooler
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by avoice217, Jun 16, 2025.
  1. ASRDogman
    ASRDogman Senior Member
    7,208
    3,771
    I didn't finish typing... :eek:
    Then you posted..... but it's finished now.... (y)
    NutzAboutBolts likes this.
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,591
    1,679
    Bay Area
    :ROFLMAO::ROFLMAO::ROFLMAO: It’s all good! (y)
  3. avoice217
    avoice217 Member
    152
    Hey all so I just bought myself a nice used pressure washer. Tomorrow I'm gonna go get some pump oil for it and then finish cleaning it up before I put it all back together and then test it. If it runs like it's supposed to, then I'll spray the hell out of the cooler to see what I can get out of it. Also per Nutz's comment, I'll go get myself some of that purple power stuff to attack it as well.
  4. NutzAboutBolts
    1,591
    1,679
    Bay Area
    make sure to soak the whole EGR cooler over night in 50/50 purple power and water. Then use the red nozzle to spray in there. I sprayed the front and back of the EGR cooler for a while and carbon flows out.
  5. Mendel Leisk
    40,555
    #4 stopper in the smaller end, prop in corner of laundry sink, pour in lye solution, takes about a cup.
    you may need to preliminarily open up some passages with a wire.
    #45 Mendel Leisk, Jul 5, 2025 at 9:46 AM
