Just need to vent...
Discussion in 'Fred's House of Pancakes' started by Mendel Leisk, Jul 6, 2022.
  1. Mendel Leisk
    40,682
    Just doing a frequent-for-me chore: painstakingly trimming the top portion off a pegboard bubble pack item, so I can hang it on my pegboard, have it organized and accessible:
    Suspect I’m not alone: would be nice if manufacturers would put some sort of pull strip there.
    51,249
    i've done that, probably a bit more carelessly than you though :whistle::p
  3. AzWxGuy
    AzWxGuy Weather Guy
    1,038
    520
    Tucson, AZ
    2021 Prius
    The manufacturer is only interested in anti-pilferage. In the past, I have on occasion sent email to the Contact address of various manufacturers suggesting improvements. Most of the time I hear nothing back, but sometimes they answer back with a reason why not or a thank you and we will consider.
  4. Mendel Leisk
    40,682
    I would think they're also interested in sales volume. If you've got two choices, otherwise equal, and one comes in a "friendlier" package?
    Case in point: there's two kinds of tinned corned beef we get, both are the kind that use a key to open. Quality's similar, but one has the start point for the key slightly beyond the vertical seam on the can, and it snaps off clean. The other has the start point right on the seam, and every time it hangs up at the end, requires small side-cutters to separate it.
    Flipside: the second one is also a buck cheaper, and I've got the side-cutters. But...
    Isaac Zachary likes this.
  5. ChapmanF
    17,470
    I'm not sure how often I've scrutinized how friendly a package is or isn't while I'm still in the store. It might not have a marketing advantage without more people taking time to do that.
    I usually get home with the package, and then the venting begins.
  6. Mendel Leisk
    40,682
    More for repeat business?
    Packaging that actually can be reused, corrals all the components, is worth something as well. A tale of two plug-repair kits:
  7. ChapmanF
    17,470
    At the rate I go through markers, if I were to buy a package of four at one time, there might never be any repeat business (unless some of them dried out while hanging on my peg, or something).
  8. Mendel Leisk
    40,682
    My “station”:
    bisco and AzWxGuy like this.
  9. ColoradoBoo
    ColoradoBoo Senior Member
    1,156
    758
    Monument, Colorado USA
    The increase in robotics has always been fascinating. From the robot welders you see used at the auto factories to those little floor cleaners that both vacuum and wet mop. (We are on our second, first was just a vacuum but, now, have a Roborock that vacuums and mops and empties itself into the wall unit.) We just got our first window washer since some outside windows are around 12-feet high at their highest point and it's pretty impressive...uses suction to keep itself on there and then goes all around cleaning.
    So they are working on robots to empty our dishwashers and fold clothes for us....how handy will that be? Makes me wonder how many years away we are from bringing our vehicles down to a robotic auto maintenance or repair place where you pull it in and robots do all the work. Will, obviously, take longer but robots can work 24/7.....need a head gasket repaired? Not problem, drop it off after work and we'll get the robot going and you can have the vehicle back by lunchtime tomorrow!
  10. ChapmanF
    17,470
    I'm not sure that sounds like a vent. Unless the robot mechanic is also going to tell me I need to come back and have my blinker fluid replaced.
  11. ColoradoBoo
    1,156
    758
    Ha! "I noticed a slight oozing of oil from your front timing chain cover so here's a $4,400 estimate on resealing it!" "And your 2-year old battery is testing at 80% so let's replace it for $400" (This was my last Toyota service center visit with my Tundra)
  12. PriusTech
    PriusTech Member
    115
    63
    Reno
    Tamper resistant outlets are only required in some rooms. Regular outlets are still available
  13. Mendel Leisk
    40,682
    Yeah I did find some non tamper-resistant outlets. At least at my go-to hardware store they were few and pricey (back when I stared this thread). Also, while they’re easier, they still take at least double the effort to either insert or remove a plug, compared to existing plugs in the house (1980 vintage), I suspect the regulations have been revised for that.
  14. Trollbait
    12,379
    The current outlets could be worn.
  15. Mendel Leisk
    40,682
    Thought the same, but some of them hardly ever used: plugs work like butter. One of the new ones, at the location shown in linked OP video, sees a lot of use, and it’s always a fight getting the plug out. You’ve gotta have bone-dry fingers and rock it left/right.
    could be a bad batch, or: they were the only non-non-tamper outlets in the store at that time, rated “commercial” or something similar, and overpriced. Could be a factor.
    #2775 Mendel Leisk, Jul 7, 2025
  16. BiomedO1
    2,869
    1,531
    SacTown, Ca
    I like the Walmart/Slime one; though you need to remember to replace the tube of rubber cement. There's a good chance it'll be hardened and dry when you try to use it again..
    YMMV
    ETC(SS) and Mendel Leisk like this.
  17. Mendel Leisk
    40,682
    The blackjack kit has a small tub of goop, looks to be some sort of silicon grease, definitely not a glue.
  18. xliderider
    xliderider Senior Member
    8,078
    3,235
    Honolulu, HI
    Yes, it's not glue, it's lube to ease insertion of the string/plug.
    SM-S936U ?
  19. ETC(SS)
    6,967
    I got the Walmart/Slime one and actually used it to fix an actual tyre.
    Worked Well!
    I didn't even have to take the tire (switching to American spelling) off of the rim or the rim off of the car.
    Easy-peasy.
    Yes.
    The blister-pack is 'suboptimal' for photogenic storage.
    I used a 'redneck' solution:
    By the time the bag starts to get 'marginal' it's time to replace the goop anyway.
    MY mileage.
    Nothing you will see on a YouTube hack but hey.....it's a COMPANY car!!!!
    I only keep a plug kit to keep from having to wait for somebody to come and fix the flat. ;)
    #2779 ETC(SS), Jul 8, 2025
    BiomedO1 likes this.
  20. BiomedO1
    2,869
    1,531
    SacTown, Ca
    I had mixed results putting dry rope plugs in w/o the rubber cement. Never had a slow leak using the rubber cement. There was a 50/50 percent chance without the cement - but they may have just been old dried-out rope plugs. I suppose that's why the little tubes of rubber cement are included in these newer packages - old ones didn't have them.
    When the choices are sit there and hope someone stops to help or shove the plug in and go; I usually do the latter. Besides, I don't have the legs or breast for that.;):eek::giggle:
