2016 Prius 3 Touring Brake Actuator Noises
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Iron Man Prius, Jul 1, 2025.
  1. Iron Man Prius
    Iron Man Prius Junior Member
    95
    24
    Fullerton
    Three Touring
    I know the Gen 3 issues with this, but how much pump cycling is TOO much for a Gen 4 if you're parked not pressing the brake? I hear it often, but nothing after the car shuts off (like a Gen 3 would if it was going out). No other brake issues or noises and everything else seems fine, and no codes..just have PTSD from the Gen 3. Car has 170k miles. Just ignore it and give it a brake flush and call it good?
    51,801
    you have nothing to worry about until you get trouble codes. hard to say whe too much is too much before then. you may never have issues.
    Iron Man Prius likes this.
  3. Iron Man Prius
    95
    24
    Fullerton
    Three Touring
    It does run a lot just sitting there, it just freaks me out. If a Gen 3 does it that much, the inevitable is coming.
  4. bisco
    51,801
    it could be coming, but there's no way to know, unless tech stream has a testing procedure
    amos likes this.
  5. ChapmanF
    18,011
    Gen 4 has quite a different hydraulic system, if I remember right. I'm not sure how many lessons from gen 3 even carry over straight.
    amos likes this.
  6. Iron Man Prius
    95
    24
    Fullerton
    Three Touring
    So because it's buzzing and charging up as much as a bad Gen 3 unit, doesn't mean it's bad and it's normal?
  7. ChapmanF
    18,011
    We have a thread somewhere that compares the gen 3 and gen 4 brake hydraulic systems. I'd want to review that before answering.
    IIRC, there's a generation where they did away with the accumulator altogether. but maybe that wasn't till gen 5.
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,034
    1,965
    NJ-USA
    While there are a number of differences between the Gen3 & Gen4 brakes, the basic "it uses the pump and accumulator to run everything" is common across both systems.
    That said, I would expect the pump to not run very often if you do not use the brakes while "ready". If it cycles on just sitting there, (more often than once in 10-20 minutes?), I would think there is "excessive" internal leakage - somewhere.
  9. Iron Man Prius
    95
    24
    Fullerton
    Three Touring
    So would it be the best to change out the master cylinder or the accumulator or both?
  10. mr_guy_mann
    4,034
    1,965
    NJ-USA
    I do not know. How often does your pump run?
    There has been advice to use a mechanic's stethoscope to try and listen for the sound of moving fluid when there shouldn't be any. If the brake actuator makes "gurgle-swoosh" sounds, then the leak could be inside it.
    If only the pump assembly makes noise, then maybe the internal fault is there.
    Here's a basic system diagram (from elsewhere in the forums). The booster pump assembly and the (upper?) brake actuator are the only parts that contain high pressure fluid while the brakes are not in use.
